Integration by substitution (I think)
The discussion revolves around integrating the expression involving d.cos j with respect to d.sin j, where d is a constant. A substitution of u = d.sin j is proposed, leading to confusion about the integration process. The conversation shifts to the Riemann–Stieltjes integral, highlighting that using d as a symbol for a constant may be problematic in calculus contexts. The user also reflects on a previous mistake involving the integration of sqrt(a^2 - b^2) with respect to b, ultimately clarifying the correct substitution and integration steps. The user successfully resolves their query by the end of the discussion.
tomwilliam
Integral of d.cos j with regard to d.sin j
Where d is a constant.
I don't know how to approach this. I can substitute u=d.sin j
Then I have
Integral of dz/dj with regard to dz, but not sure where to go from here.
Any help appreciated.
do you mean a Riemann–Stieltjes integral?
\int f(j) dg(j)
with
\int f(j) = sin(u)
\int f(j) dg(j) = cos(u)
First its probably a bad idea to use d as a symbol for constant in this context, based on its calculus context
Now if f and g has a continuous bounded derivative in a Riemann–Stieltjes integral the following equality holds
\int_a^b f(j) dg(j) = \int_a^b f(j) g'(j) dj
Thanks,
Ok, the complexity of your answer tells me I've made an earlier mistake. I was trying to integrate the expression
sqrt(a^2 - b^2)
With regard to b. I used the substitution b=a sin theta so that
Sqrt(a^2(1-sin^2 theta) = sqrt(a^2 cos^2 theta) = a cos theta
Now I have to integrate
a cos theta
With regard to a sin theta. I've changed the variables, but I think that's equivalent to my original post. Did I make a mistake?
Thanks again for your time.
ahh ok so you mean
\int \sqrt{a^2-b^2}db
now let b = a.sin(t)
b = a.sin(t)
db = a.cos(t).dt
subbing in
\int \sqrt{a^2-a^2 sin^2(t)}a.cos(t).dt
\int \sqrt{a^2(1- sin^2(t))}a.cos(t).dt
\int \sqrt{a^2cos^2(t)}a.cos(t).dt
so the integral should be with respect to t (short for theta)
i always do those steps with b & db to keep it clear, similar with limits if the integral has limits
by the way if you ever want to write tex, you can right click on the expression to show source and see how its written
Thanks, that's exactly it.
I'm writing on an iPad, which makes it difficult (impossible?) to type tex without putting it into a separate application first.
Thanks for your time.
yeah know the feeling
EDIT: It's ok, I've solved it now!
  • · Replies 28 ·
