Integration by substitution with bounds and integrating velocity with initial height
  • Thread starter armolinasf
    Integration
2 replies · 3K views · last reply
armolinasf
I'm having a bit of difficulty with these two integration problems:
1. Suppose [tex]\int^{2}_{0}[/tex]f(t)dt=3 calculate the following:
a) [tex]\int^{.5}_{0}[/tex]f(2t)dt
b) [tex]\int^{1}_{0}[/tex]f(1-t)dt
c) [tex]\int^{1.5}_{1}[/tex]f(3-2t)dt
The second problem is this:
If we assume that wind resistance is proportional to velocity, then the downward velocity, v, of a body of mass m falling vertically is given by:
v=(mg/k)(1-e[tex]^{(-kt)/m}[/tex])
where g is the acceleration due to gravity and k is a constant. Find the height, h, above the surface of the Earth as a dunction of time. Assume the body starts at height h[tex]_{0}[/tex]
For 1, I know that there is some sort of substitution that I'm just not seeing.
For 2, I basically treated it like a differential equation where v=dh/dt and I get as an antiderivative: (mg/k)(t-(m/k)e[tex]^{(k/m)t}[/tex]
I'm not sure how to get the height equal to 0 so that I can incorporate the h[tex]_{0}[/tex]
Any help is appreciated
Point 1. In your hypothesis, make a change of variable: t=2p. What do you get ?
Point 2. You may want to revise your integration. One of the signs is wrong.
Are you sure this is correct? With this information, you can't come to any conclusion about the following integrals. If it were
[tex]\int_0^1 f(t)dt= 3[/tex]
then they are easy.
?? Nothing is said about the height being 0. The height when t= 0 is [itex]h_0[/itex].
(Actually, two signs are wrong in your integral.)
