Integration constants, gravitational potential of sphere
20 replies · 3K views
Vir
So I'm calculating the gravitational potential of a sphere at at point P. R = radius of sphere, r = distance from center of sphere to point P. I'm looking at two scenarios; r > R (1) and r < R (2). So I have the following integral:
\begin{equation} V(r) = \int \frac{-GM}{Rr} ds
\end{equation}
Now, for (1) I integrate from r-R to r+R. However for (2) I'm thinking I have to integrate from -(R-r) to R+r, but this gives me the same constants as in (1). To my understanding the potential is supposed to be constant for all r < R, but then my constants are giving me the wrong answer.
If I remove the - and integrate from R-r to R+r I get a correct answer, but this makes no sense to me. That would mean I was integrating from the center of the sphere out to the edge, effectively ignoring half of the sphere? What am I missing?
\end{equation}
I'm confused about what you are trying to do. ##\frac{-GM}{r}## is the gravitational potential for a solid sphere at a point outside the sphere, a distance r from the centre.
What are you trying to calculate?
I'm trying to arrive at the gravitational potential at a distance r < radius of sphere(R). The integral is
\begin{equation}
V(r<R) = \int \frac{-GM}{2rR}ds,
\end{equation}
but I'm not sure how to select my integration limits.
Yes, a hollow sphere. I'm integrating small circles of the surface of the sphere. I guess this image describes it well.
That's a point r outside the sphere. In that diagram, you first need to work out the gravitational potential of the ring marked in blue. So you're going to need to take θ into account and calculate dM as well.
Ok. So
\begin{equation}
dV(r<R) = \frac{-GdM}{S}
\end{equation}
\begin{equation}
dM = \frac{M}{4\pi R^2}d \theta R Sin \theta R 2 \pi
\end{equation}
\begin{equation}
dM = \frac{M}{2}Sin \theta d \theta
\end{equation}
\begin{equation}
S = \sqrt{R^2+r^2-2Rr Cos \theta}
\end{equation}
\begin{equation}
\frac{dS}{d \theta} = \frac{Rr Sin \theta}{S}
\end{equation}
Inserting in dV(r<R):
\begin{equation}
dV(r<R) = \frac{-GM Sin \theta S ds}{2SRr Sin \theta}
\end{equation}
\begin{equation}
dV(r<R) = \frac{-GM}{2Rr} ds
\end{equation}
\begin{equation}
V(r<R) = \int \frac{-GM}{2Rr} ds
\end{equation}
Is that right?
When the ring is to the right of P the force points left, and vice versa.
Yea, ok. I was thinking since each point on the circle has a point on the opposite side where the perpendicular component of the forces would cancel out the net force would be parallell to the axis through the center of the circle and P. Not so?
That would depend on the mass at P right? In any case it's
\begin{equation}
F = -\frac{GMm}{(r-R Cos \theta)}
\end{equation}
Take a look again at your diagram and make s a vector. That's the direction of the force. So, you have a "vertical" component and a "horizontal" component. The magnitude of the horizontal component is not the magnitude of the full force.
Then I don't know. You asked about the magnitude of the remaining force, isn't that the horizontal component of the total force?
Yes, but the vertical force is ##Fsin(φ)## and the horizotal force is ##Fcos(φ)##
Right. So what do I do with this?
I don't know. My integral gives me the right answer for R>r:
\begin{equation}
V(r>R) = \frac{-GM}{2rR} \int_{r-R}^{r+R} ds
\end{equation}
Simplifies to:
\begin{equation}
V(r>R) = \frac{-GM}{r}
\end{equation}
I think the point is that when r<R then the rings both to the left and right of P have a positive distance to P, since the potential is supposed to be negative. I guess one has to think more in terms of polar coordinates? Thus, when r<R you have to integrate from R-r(closest side of sphere) to R+r(far side). This gives
\begin{equation}
V(r<R) = \frac{-GM}{2rR} \int_{R-r}^{R+r} ds
\end{equation}
Simplifies:
\begin{equation}
V(r<R) = \frac{-GM}{R}
\end{equation}
I think you've got two mistakes cancelling out for the problem outside the sphere. But, they won't cancel inside the sphere.
You've got ##dV = -GdM/S## but that assumes that all the mass in the ring is concentrated at one point a distance S. You need to take cos(φ) into account. The potential must be:
##dV = (-GdM/S)cos(φ)##
If you imagine being very close to the ring, then there would be almost no potential. In fact, when φ = π/2, the potential will be zero.
So I checked my book:
The potential dV(x) at P from dM, that is now a small part of the ring, at distance S is given by:
\begin{equation}
dV(x) = \frac{-GdM}{S}
\end{equation}
\begin{equation}
dM = \frac{M}{2 \pi R}Rd \theta
\end{equation}
So
\begin{equation}
V(x) = \frac{-GM}{2 \pi S}\int_0^{2 \pi}d \theta = \frac{-GM}{S}
\end{equation}
So when S = R the potential is not zero, it's just the lowest possible value for any point on the axis through the ring's center. However the gravitational field will be zero, since g(0) = -∇V(0) = 0.
I think you are right about the cancelling though. Gravitational potential doesn't cancel out. The potential is exactly the same for every dM on the ring so the potential from the ring is just the sum of potential from all the dMs. So for the hollow sphere the gravitational potential is just the sum of the potential from all the rings in the sphere. So since the inside of a sphere is a equipotential region(source: wikipedia) V = constant for any point inside the sphere. I believe this is correct.
Thanks for the help!
