Integration using the reduction formula
1 reply · 3K views · last reply
studentxlol
Read the math in the image below
Handwritten derivation on lined paper of the integral of x^2 over the square root of 4x+5 dx, using a reduction formula, with steps ending in a squared bracketed expression of 2x^2 times the square root of 4x+5 over 20, minus 4/20.
Is it possible to integrate the rational function using that reduction formula. If yes, how do I go about doing it?
Keep it simple, I'm new to this (And I missed a lesson)
Thanks!
You have
$$I_n = \int \frac{x^n}{\sqrt{ax+b}}\,dx$$ so you're starting with n=2. When you apply the formula and simplify, you should get
$$I_2 = \frac{x^2\sqrt{4x+5}}{10} - I_1$$ You made a mistake in the coefficient of I1, so recheck your work getting the second line. Now apply the same formula to expand I1. You'll end up with an expression with I0 which you should know how to integrate.
