Interactive Minkowski diagrams tool
34 replies · 10K views
Insights Author
2025 Award
This is a little toy I put together that I thought might be of interest:
http://ibises.org.uk/Minkowski.html
It's an interactive Minkowski diagram. You can add events and connect them up with straight-line paths, then Lorentz boost either to a specified velocity or to the rest frame of a time-like path. Below the diagram there are instructions (which I hope make sense) and some buttons that create some textbook diagrams.
The page uses HTML5 features, so you'll need a fairly up-to-date browser - if you don't see axes and a grid, that's bad. Also, I gather that not all browsers implement the <input type="color"> tag. I think the page will work anyway, but you may require a resource such as this one to set the colours if you're not familiar with hex triplet notation.
Any comments (physics or otherwise) welcome.
I bet that took more than 10 min to put together. IE does not support colour inputs as far as I know. Works fine in FF.
I use firefox, but for me, all the pre-selected diagrams work, but no actions on the grid itself work: click, shif-click, drag all do nothing for me.
I've been debugging and on line 437 (in the canvasClick event handler) 'event' is undefined. I can't see why because the code is the same as we all use to get the event parameters.
I hope Ibix can sort it out.
[later]
I found a solution. The 'onclick' attribute should be written ' onclick="canvasClick(event)" '. This applies to all the event handler attributes. Include the event in the declaration.
I changed them and the clicking and dragging works fine now. Looks good and I'll try it properly soon.
Thanks Mentz. I'll aim to fix it this evening. I must say that events in Javascript seem to Just Happen in Chrome/Opera. Presumably their Javascript engines are slightly more permissive in how events are handled than Firefox's (?).
It did take more than ten minutes to put together, yes, although the actual physics took a lot less. That's entirely contained in the LT and LTv functions, which boost events and velocities. The rest of the program is book-keeping and user interface.
Neat! It reminds me of something I have thought of doing but never found the time to.
One thing that would be nice would be to include an auto button for making a space-time grid (i.e., just lines parallel to the time and space axes). I think it would be instructive to see how it changes under boosts.
Another thing that might be more difficult would be the possibility to draw hyperbolae and to see how they don't change under boosts.
The grid is easy. To the extent that you can approximate a hyperbola by a set of straight lines connecting a relatively small number of events lying on the hyperbola, that's not too hard either.
Interesting. I have a picture in my mind of a hyperbola on an ST diagram with a straight line (ICMIRF) touching it at a point E. Now if we boost the diagram to make our ICMIRF stationary ( ie vertical) won't the parabola have to rotate to still go through point E ?
Or have I just drunk too much coffee ?
Yes making interfaces is a pain and you've done decent job of it. With the changes you'll have all the major browsers covered.
Of course different points on the hyperbola will be at different points after the boosts. The hyperbola will be left invariant in the same sense as a circle is invariant under rotations.
Right, I see what you mean. I have a program that boosts hyperbolas and now that I look carefully I can see the shape is the same.
You seem to have a javascript error - you are setting up event handlers without an event parameter. That only works in IE and Chrome as they have a global event variable, but not in Firefox or any browsers that stick to the standards.
Edit: I should've read a few more posts before commenting. I see you are already aware of this issue, so just disregard my post. And sorry for the hasty posting.
I've installed Firefox, corrected the bug and added grid and hyperbolae buttons at Orodruin's suggestion. I think I can make the events along the innermost hyperbolae a bit more evenly distributed (they're very clustered in the middle), but my brain doesn't seem to be able to handle such complex maths tonight (I know it's not complex, I'm just tired).
Lesson learned, anyway. Test in as heterogeneous environment as humanly possible. I see there's a Safari for Windows - I should probably test that at some point.
Ibix said:
hyperbolae
You might want to add in the description that the hyperbolae crossing the x-axis correspond to the world lines of constant proper acceleration, perhaps identifying them with a different colour.
I assume you simply took equal hyperbolic distance between them? I think this is fine, it transforms well and you need more points in the middle because the hyperbolae are more curved there.
Good idea.
The events along each hyperbola are generated by boosting either (x,0) or (0,t) into the frame moving at v=0.99j, j=-10,-9...,9,10. I'm not precisely sure what you mean by hyperbolic distance - the integral of ##\sqrt{ds^2}## along the hyperbola?
The events seem a little more tightly clustered than is warranted by the (not extreme) curvature of the hyperbolae. I might have a play with it tomorrow. Going to bed now...
Ibix said:
The events along each hyperbola are generated by boosting either (x,0) or (0,t) into the frame moving at v=0.99j, j=-10,-9...,9,10. I'm not precisely sure what you mean by hyperbolic distance - the integral of ds2‾‾‾√\sqrt{ds^2} along the hyperbola?
Yes. That should be the same as doing consecutive boosts with the same velocity.
You would get better spacing by parameterising each hyperbola as[tex] t = r \cosh (a \tau)\\<br /> x = r \sinh (a \tau)[/tex]where [itex]r[/itex] is constant for each hyperbola and [itex]a[/itex] is constant across all of them. (Or equivalently [itex]v = \tanh (a \tau)[/itex] in your method.) This way, the local event density won't change. I've never programmed in Java, but a quick Google shows that it has sinh, cosh and tanh functions.
I'm boosting my initial point every time, rather than consecutive boosts. I see there's a typo in my last that may be confusing things. The correct statement is that for each j, j=-10,-9,...,9,10, I'm starting with the point (x,0) or (0,t) in the frame S, which is the initial frame of the diagram, then boosting it to v=0.099j, and adding an event using the boosted coordinates (in frame S).
I'll try your way, starting with (0,t) or (x,0) and boosting it to v=0.1, then boosting that to v=0.1, etc. I'll also try @Dr. Greg 's method, which I suspect (without actually having done the maths) will give the same result since we're talking about hyperbolic rotations.
Yes, they are equivalent. If your are more comfortable using boosts from the original frame, go with that.
Just one point. When I boost the hyperbolae to near c, its revelead to be too short. You should make a much longer hyperbolae to show that it remains invariant when boosted to arbitrarily high speeds.
That would involve infinitely many points per hyperbola ...
Yeah, my bad wording. I just meant right now, even when boosted to v=0.5c, the hyperbolae appears to be short. He can just choose a higher maximum speed and correct the length of the hyperbolae for that maximum speed.
I've switched to DrGreg's parameterisation, changed the colour of the time-like paths and added a note about their physical meaning as Orodruin suggested, extended the hyperbolae as Shyan suggested (you can boost to 0.99c once without seeing them; you can't do it twice though) and added the pair of null paths through the origin for completeness.
At the rist of complicating the diagram too much, you might also like to consider drawing lines from the events through the origin -- the events along different curves are already lined up for this. For the green area, this would then be a grid for Rindler coordinates -- see the first diagram in the Wikipedia Rindler coordinates article.
The whole diagram would then be the Minkowski geometry equivalent of a rotating wheel with spokes in Euclidean geometry.
Selecting a scenario doesn't choose a velocity to boost, at least for me.
I think you should include an example of how to read the diagrams for some of the secarios, and how the diagram explains or not the paradox.
Looks good on my chromebook and is pretty interesting to play around with!
