Interference fringes, what if you sample them?
53 replies · 7K views
David Byrden
Imagine a standard Young's Slit experiment using photons. We obtain large, distinct interference fringes on a target screen.
Then, we embed into the target screen a telescope focused on and capable of resolving the slits. The width of the lens must be greater than about one fringe to obtain this resolution. So we use a nice big lens with two or three interference bands falling upon the lens glass.
The telescope's display gradually builds up an image of the two slits.
Now, the interesting part. We paint our lens surface with opaque paint, leaving only some narrow strips unpainted. These have the same spacing as the interference bands. They are too wide to cause significant diffraction in any light passing through them.
We place our telescope in two positions;
1. the unpainted strips on the lens coincide with dark interference fringes
2. the unpainted strips on the lens coincide with bright interference fringes
A naive person might expect the telescope to register a higher rate of photon detection in [2] than in [1]. Personally I expect the rates to be the same.
But I would appreciate if somebody who really knows the subject, would tell us what will result here?
Thank you.
David
My immediate response was going to be that in single-photon "interference" experiments, when you count the photons and plot the counts vs position, you get the classic double-slit pattern building up over time. So that's definitely "higher rate in [2] than [1]".
But hold on, things are a little more complicated than that.
https://sciencedemonstrations.fas.harvard.edu/presentations/single-photon-interference
"The experiment is designed to also make it possible (in principle) to know which of the two slits the photons are passing through. In this so-called which-path case, the Young's double-slit interference pattern does not manifest itself. This can be followed by a quantum eraser (to erase the which-path information) to recover interference. Thus, the act of measurement and the design of the experiment affect what is being measured. Even if not actually measured, the mere possibility that an observer could determine which slit the photon passed through causes the interference pattern to switch to non-interference."
So you can set it up so that you do not get the classic pattern.
Single-photon interference is an experiment where you have light intensity so low that photons arrive at your detector individually, and you can count the individual photons.
In my scenario, there is an interference pattern on the target screen, and simultaneously I think there is not an interference pattern detected by the telescope which is embedded in the target screen, sampling photons functionally equivalent to those that hit the screen.
I don't think that you need QM to predict the outcome in my scenario, I expect that classical wave theory will tell us the correct answer. I hope that somebody knows the outcome for sure.
What I am hoping to highlight is that interference does not occur in the quantum particles while they fly from the slits to the target; it occurs in the environment after they hit the target.
David
What you describe here is called spatial filtering - which google.
Then you will be severely disappointed.
Anyway, this is not the way it works: experiment decides. A simple laserpointer and a lens on an improvised optical bench can teach you a whole lot.
Any basis for this speculation ? Any ideas for experiments to verify/falsify this ?
Vanadium 50 said:
Such a thing does not exist.
There is no such thing as a telescope capable of imaging Young's slits from, say, two meters away?
Is this because the slits would be very close together? If so, why could we not resolve them by using a sufficiently large lens? I'm not seeing the show-stopper here.
David
This is the basis; the particles, while crossing the gap to the target screen, still bear directional information. Therefore they can in principle be distinguished. Therefore interference (addition of wave functions) is not occurring in that gap.
Yes; the thought experiment that I just described.
David
If it helps...
Many people have asked what happens if you set up a double slit experiment then make holes in the screen to see what appears on a second screen located behind the first. The hole being either on a fringe or in the dark area between fringes. Google it.
Your speculation here is not correct. You could simply move the target screen up to see that there is interference occurring.
That line of thinking doesn't work (unless you move the detector/telescope so close to one of the slits that there is no appreciable amplitude for the paths to it from the other slit, in which case the lack of interference is to be expected). The problem is that the interaction with the slits leaves the particle with an uncertain transverse momentum so there's no directional information in the sense that you're thinking.
(This is a heuristic argument from Ghirardi. You can arrive at the same conclusion by doing the sum of paths thing).
I'm sorry if I did not make myself clear.
As I see it, there is no interference in the air gap, but when the particle's wave function interacts with that of the target screen, then momentum, charge and most other properties are preserved but directional information is erased.
The interference, as I see it, occurs only after that interaction, because only when directional info is removed do the wave functions pertaining to the two slits become indistinguishable. They add (as complex amplitudes) only from that point on. Their interactions with the environment then also interfere.
So, if you ask me why there are few photons in the "dark" band, I say it's because there are two indistinguishable versions of you who do see impacts there, but the two "yous" almost cancel out.
Moving the screen up closer to the slits will of course not affect this process.
Am I looking at this wrongly?
David
Doesn't that imply that no lens, no optical intrument of any kind, placed at the target screen, could possibly resolve the two slits as such?
Which, at first glance, would make astronomy an impossible pursuit... ?
David
No (and that confusion may be behind the talking-past-one-another exchange between you and Vanadium50 farther up in this thread). Forming an image of the slits, or of an object on the source side of the barrier, is a different thing than assigning a path to a particular photon detection in the region illuminated by both slits.
David Byrden said:
As I see it, there is no interference in the air gap...
Depending on your perspective: this is either wrong (there IS interference there) or meaningless (because you can't meaningfully discuss what happens when no measurement is made).
Well, now you have me totally flummoxed. I'll spell it out as I see it, please indicate my mistake;
1.An image of the slits looks like two bright lines.
2. It is obtained by summing many, many impacts of individual photons.
3. Every photon that arrives on the detector screen contributes to either one line or the other.
4 That photon therefore appears to have transited one slit or the other - the slit whose image it contributes to.
No?
David
If you have the conditions for interference, and you stand in the light zone and look back at the slits, you will not see two bright lines. I couldn't find a picture with lines, but with dots (figure from the University of Tennessee at Knoxville) it will look like the figure on the right, not the left:
On the experiment presented by the OP, suggestion is to use a lens as opposed to a telescope. ## \\ ## If the paint stripes on the lens are placed on the bright stripes of the interference pattern at 2 meters, the energy is basically wiped away, so very little energy will be observed past this region. Any observations done in the region beyond the lens will receive very little energy. ## \\ ## If the opaque paint stripes are placed in front of the dark regions of the two-slit pattern at 2 meters, they will have little effect, and the results would be similar as if there were no paint stripes at all. ## \\ ## It's all a completely classical description.
Vanadium 50 said:
If you have the conditions for interference...it will look like the figure on the right, not the left:
Thank you. But my proposal was to substitute a larger lens/telescope/instrument until the image resolves. Is that not possible?
David
Charles Link said:
...the results would be similar as if there were no paint stripes at all. ## \\ ## It's all a completely classical description.
Thank you. That sounds reasonable. It's also completely contrary to my understanding of QM, so I need to think about it.
Can you refer me to any experiments demonstrating this?
David
I don't think your problem is with QM. I think it goes back to classical waves and optics. For example, if you have a diffraction limited system, adding a lens doesn't make it clearer. It just makes the fuzziness bigger. You might want to review that before going on.
Everything that I read about telescopes today seems to agree with this statement;
"The minimum angular separation of two sources that can be distinguished by a telescope depends on the wavelength of the light being observed and the diameter of the telescope. This angle is called the DIFFRACTION LIMIT."
Therefore, the diffraction limit (which you apparently referred to) can be arbitrarily reduced by increasing the diameter of the lens, as I did suggest. (I never mentioned "adding a lens")
No?
David
Vanadium : this disagreement is no mere tangential issue. It is central to the point that I am making, to the demonstration that I proposed.
You said that an observer, standing among Young's fringes, could not possibly resolve the two slits. Why not?
I suspect that you deduce this from the principle that interference occurs only if which-way info is absent.
The ability to resolve the slits would imply the info is present, therefore interference could not occur.
And (I think) you assume that there's already interference in the photons while they cross the air gap.
Have I correctly summarised your thinking?
Anway, the point that I wanted to make, is that interference does not exist in the air gap. The photons (or particles) do carry which-way info.
Interference occurs only within the detector after this info has been erased.
Now, here are my supporting equations. Multiple, seemingly competent articles about telescopes tell us this;
"The diffraction limit is θ=1.22 λ/D, where θ is the angle you can resolve, λ is the wavelength of the light, and D is the diameter of your lens."
And it's easy to see that λ = θ F where F is the fringe spacing and θ is the angular distance between slits as seen from the central fringe.
So, a telescope embedded in the target screen, among the fringes, will be able to resolve the slits if its lens diameter is at least 1.22 fringes.
Needless to say, if you can resolve the slits, you can see which slit was used by each photon.
The which-way information is present and you have extracted it.
David
So you are planning to place a telescope at one of the interference fringes (a spot that wouldn't get any light if there were no interference), And you think you can resolve to "see" which slit it came through?
Logically, the interfering light paths are meeting at the same point where it enters the telescope. And that light has but a single path through the telescope to your eye. It's not as if the photon went through one slit or the other. There is nothing to resolve at this point.
Sorry if I didn't make my notation clear; by "fringe spacing" I mean bright-to-bright, i.e. the "wavelength" of the pattern. A lens that's 1.22 fringes wide will have both a bright and a dark band impinging on it, regardless of how you shift it around in the illuminated area. It can't be placed in a dark band.
I really don't understand this comment.
I intended to put the lens near the center of the illuminated area, but really, I think that the whole area illuminated by interference bands will get light when the interference is not present.
Where is the "spot that wouldn't get any light if there were no interference" ?
Yes.
Refer to the experiment that Zonde linked to, in post 22. That experimenter claims to have resolved the slits almost exactly as I proposed. And others have repeated the experiment.
No, that's not how telescopes work.
David
