Adel Makram
- 632
- 15
yes B will see what A saw. But as long as A and B are not moving, they must see the 2 slits open at the same time
Adel Makram said:yes B will see what A saw. But as long as A and B are not moving, they must see the 2 slits open at the same time
I don't believe there is any experiment that shows this. There are experiments that show that two slits which have been open for a long time show interference, and there are experiments which show that if one slit has been open a long time there is no interference, but I don't think there are any which show that if you have two slits and you quickly close one that you instantaneously lose the interference. And that statement is certainly not justified by theory.Adel Makram said:But in y experiment, the double slit experiment tells us that unless you let the 2 slits open at the same time, you will never get a pattern.
Adel Makram said:I posted this thought experiment in a previous thread before 4 months or so, but I would like to reiterate it now:
A frame of reference (FOR) has double slits moves relative to a ground FOR. Let`s make an arrangement so that when the 2 ends of FORs coincide, 2 small slits of moving FOR are opened at the same time relative to the ground observer for a brief moment to allow just 2 photons to enter from an electromagnetic source put on the opposite side of him. Let `s make the distance between the 2 slit small enough comparable to the wave-length of the photons to cause an interference pattern.
For the ground observer, he sees 2 slits open at the same time and therefore the 2 photons entering the 2 slits and create an interference pattern on a screen on his frame.
But according to SR interpretation, the moving FOR`s observer sees the front slit opens for a brief moment and then shuts before the rear one opens,,, so at one time, only one slit opens and therefore no interference pattern could ever occur. But when he looks at the screen from his window, he will see an interference pattern on the ground screen.
Can the train observer now explain why this interference pattern occurs when just the slits open one at a time?
I don't think that this is correct. Can you derive the wavefunction and show this?Adel Makram said:Seeing the slit-A opens and closed before slit-B opens relative to the slit-observer is the exact way to know which slit allows the light photon to go through and consequently will destroy the pattern.
jartsa said:In this experiment a wide photon is needed. How is a wide photon created? One side first, then the other side, as seen from some suitable FOR.
Adel Makram said:The idea behind my experiment lies not just on the expected classical explanation based on the light transmission but instead on the expected puzzle enforced by Quantum Mechanics Interpretation. If the interference pattern forms because of the invariance of wave-phase or the coincidence of 2 worlds line representing the photons and the screen as in Mentz work, the issue might be easier, yet not solved still
The challenge is what QM predicts that no pattern could ever be formed if one knows which slit the photon passes through. This can be inferred from the famous Wheeler`s Delayed Choice Experiment or Delayed Choice Quantum Eraser Experiment which both of them have been confirmed. Seeing the slit-A opens and closed before slit-B opens relative to the slit-observer is the exact way to know which slit allows the light photon to go through and consequently will destroy the pattern. There is no counterpart in the classical physics, therefore attempt to explain the pattern based on light transmission is either incomplete or wrong
Furthermore, the QM allows the experiment to be done on electrons for example and still has the same result regardless the need to use photons because of its possible exploitation in synchronization of the time the slit open
JDoolin said:The point is, though, that the frequency goes up as the distance goes up, and the frequency goes down as the distance goes down. So the number of wavelegths is not invariant.
Mentz114 said:For a light beam traveling from one observer to another, the number of wavelengths on the path is invariant. The diagrams show this happening from the perspective of both frames. It would be the same under an arbitrary LT.
The diagrams are coventional ST plots with time on the vertical axis ( you've used my program so you'll know how I made them )
JDoolin said:Yes. I think I see what you are doing.
Are you showing 7 explicit events on the null-path interval, and how those events do not disappear when you do a Lorentz Transformation?
Are those events are tied to nodes and peaks of the wave-form of a single photon?
Or are those nodes and peaks marking the locations of 7 individual photons along the same null-interval?
Mentz114 said:No photons, please. We're doing classical wave optics.
Yes, those events are equally spaced along the null direction representing complete wavelengths.
[edit] removed a non-sequitur. Phase must be invariant because it is a scalar.
When you place events equally spaced along the null direction, are those wavelengths? I don't think they are wavelengths. They seem like wavelengths at first, but...
A wavelength involves a span over a distance. A span over a distance implies a space-like interval. We have no space-like interval here. We have a null interval.
Oh, I should be asking what you mean by phase. Because the interference pattern is going to be the same, whatever the reference frame, so wherever peaks are meeting, you get a bright line, and wherever peak meets trough, you get a dark line. This must be invariant, because you get the same bright and dark lines regardless of reference frame. Is this sort of what you mean by phase?
Mentz114 said:The spatial separation ( look at the x-axis) between the events is equal ( and so is the temporal because its a null direction). There could be a set of observers at those events.
That is exactly what I meant. Interference between waves is determined by phase differences. In the 2-slit experiment, the phase difference is because the path lengths of the 2 beams is different.
I think this thread is done. The OPs question has been answered by several people.
Mentz114 said:I think this thread is done. The OPs question has been answered by several people.
Adel Makram said:I don`t think so :)
As per your calculation about the invariance of phase difference ΔL/λ = ΔL`/λ`, the total path length that coming from the slit A is different from that path from slit B relative to the slit-observer. But they are always equal in length relative to the ground observer ( especially regarding the central peak ). Therefore, the ground observer will always sees the phase-difference between the 2 paths = 0 at the spots of light forming peaks ( the Central peak is the ideal one), while for the slit-observer, the 2 paths are different by amount depends on the distance between the 2 slits and the velocity of the ground
And even if you consider the path of light from A is shortened than the distance between the location of slit A and the location of the peak on the screen because of light photon has to leave slit A earlier than slit B, then the point of calculating the path ΔL between the source ( slit A in this example) and the receiver ( peak on the screen) in your calculation becomes irrelevant
Mentz114 said:Path length is never irrelevant in interference calculations.
I'm done here.
[JD - PM me if you have a problem with the calculation]
