Interference Pattern versus SR
154 replies · 18K views
DaleSpam said:
And you are claiming that there is some inconsistency in the calculations. So show it.
Have you actually performed the calculations? If so, then why are you unwilling to post the details? If not, then you don't know that they contradict each other.
your calculation and mine is right and shows that the time difference depends on s
The matter will be much easier if there is no relativity, as from the diagram, the light sphere reaches A and B at the same time both for the ground and the slit observer,,, The phase will be equal too
thttps://www.physicsforums.com/attachment.php?attachmentid=43214&stc=1&d=1327756868oo
That isn't a contradiction, unless you have some other calculation which shows that it does not. Show your math, how you determined that there is a contradiction.
OK,,,
consider the last diagram post in 88, and the attached diagram ( the left hand diagram is for slit A and the right hand is for B)
The source is also moving relative to the slit-FOR with -vt`
(cta`)^2 = s^2 + (ab`/2 - vt`)^2
(ctb`)^2 = s^2 + (ab`/2 + vt`)^2
where ta`and tb` are the time received by A and B relative to slit observer
after some transformation the quadratic equation yields the value of ta` and tb` as follow:
ta`= -ab` v +/- √[(ab`v )^2 + 4 (c^2-v^2)( s^2 + (ab`/2)^2] / 2(c^2-v^2)
tb`= +ab` v +/- √[(ab`v )^2 + 4 (c^2-v^2)( s^2 + (ab`/2)^2] / 2(c^2-v^2)
So clearly the s will disappear from the difference as you said,,,
But still the time difference Δt` = ab`v/(c^2-v^2) = ab`v/c^2 / 1-v^2/c^2
But for LT , Δt`= abv/c^2 / √(1 - v^2/c^2)
sorry for the bad shape,,, again you are right that s will disappear but still there is a difference
https://www.physicsforums.com/attachment.php?attachmentid=43216&stc=1&d=1327760313
I got it :
Still ab` should be transformed also according to LT and the final time difference will be the same Δt`= abv/c^2 / √(1 - v^2/c^2)
Final i suppose :)
in conclusion:
1) The time difference between 2 slits is the same as measured by LT where no s appears
2) The phase is the same at A & B
Oh at last it becomes clear,,, thanks DaleSpam for inspiration
But Still I believe QM has a different opinion
I appreciate your comment please on my calculation ( although on bad shape)
For you to claim to have found some inconsistency in SR is a HUGE claim, on the Nobel prize level. You better have some math to back it up, and the math had better be correct.
:) But SR is still not plausible for me. It used a circular logistic to yield the same result. Like the quadratic equation where u solve the equation and then substitute the root in the former equation to yield zero :)
It is a trick in math rather than a true physics
What do you mean by this? Quantum theory today is QFT, which include SR and the LT. So all analysis of slit timing, phase, etc. would carry over. Only the interaction theory would change (QED versus Maxwell), but the results and interpretation here would be essentially identical.
I mean Quantum information eraser effect where the information of state of an entangled photon at 2 slits will change the appearance of the pattern as long as the time is different
It is just a broad map idea but I think it works
So shall we congratulate OPERA team?
If the OPERA result holds up, there will be Nobels for sure. That's the question, though.
I wish so, I got tired from that circular logistic that called Special Relativity
It's a good idea to sort out what is physical in SR and what is just "a trick of math".
Lorentz transformation is just changing coordinate system - it's just relabeling of points in space and time. So you can call it just "a trick of math".
But there is physical part as well. It's when you say that two identical objects look and behave the same way in their respective rest frames and that these reference frames (coordinate systems) are related to each other by LT.
You are welcome! The set up equations look good, but the follow up calculations got too messy to follow on my mobile device. But the conclusion is reasonable, so I have no reason to doubt the intermediate steps.
Modern QM (QED and QFT) is fully relativistic, so I would doubt it. Again, this is something you need to work through the math on.
No circular logic is involved. Start with the two postulates, derive the Lorentz transform, make experimental predictions. Where is the circle?
As far as a math trick vs true physics, the difference between math and physics is experiment. The experimental evidence supporting SR is overwhelming. To protest about SR being math tricks rather than true physics is somewhat like a five year old closing their eyes and sticking their fingers in their ears so as not to hear something they don't want to hear.
http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html
JDoolin said:
I've been discussing this with Mentz114
The Number of Wavelengths is NOT an Invariant.
This is loosely based on Mentz114's proof, but with corrections and clarifications in the definitions of β, βobs, and βAway.
I have to say that JD's article is incomprehensible to me. In my little work I just transform 2 points and recalculate L, the coordinate distance between them, which turns out to transform like wavelength. So the ratio L/λ is the same in both frames. Only one β appears in the transformation of L and λ.
In JD's article there are two velocities (?) which baffles me.
This quote from JDs article
In short, the number of wavelengths that FIT between two EVENTS varies with Lorentz Transformation. However, the number of waves that actually EXIST between two WORLDLINES does not vary with Lorentz Transformation.
seems to disagree with the title of the article.
If anyone can point out an error in my calculation I'd be grateful.
http://www.blatword.co.uk/space-time/srphase.pdf
zonde said:
Haven't you changed signature of spacetime from (-,+,+,+) to (+,+,+,+) in your transformation?
The problem is that if you use the (-,+,+,+) spacetime signature to determine the distance of a null interval, you get zero.
There is a bit more discussion in Mentz114's earlier copy of the proof, in Post #52 of this thread.
You will see somewhere in the first couple of paragraphs a mention of a constant of proportionality k, relating Δx and ΔL and [itex]\sqrt{\Delta x^2 + \Delta t ^2}[/itex].
If you use the (+,+,+,+) spacetime signature to determine the distance of a null interval you get an observer dependent quantity which is proportional to the spatial distance, Δx, between the two events.
So he has defined ΔL to be a quantity which is proportional to the spatial distance, rather than exactly the spatial distance.
Since in the end, we are simply looking for whether or not ΔL/λ is an invariant, the extra constant factor does not make a difference, so long as that factor is also invariant. Since that factor is only a function of c, which is invariant, it does indeed work.
Now referring back to Mentz114's earlier proof, you will see he mentions a parameter k. Feel free to check my math, but I believe it can be calculated as follows. (And if something doesn't make sense, ask for more explicit definitions of the variables!)
[tex]\begin{align*}<br /> \Delta x &= \Delta L \\ <br /> \Delta t &= \frac{\Delta L}{ c}\\ <br /> \Delta x^2+\Delta t^2 &=\left ( 1+\frac{1}{c^2} \right )\Delta L^2\\<br /> k \left ( \Delta x^2+\Delta t^2 \right )&=\Delta L^2\\<br /> \therefore k&=\frac{c^2}{c^2+1}<br /> \end{align*}[/tex]
In Mentz114's later proof, he changes the definition of ΔL, so it is no longer equal to Δx, but just proportional to it, although I'm not sure he makes this entirely clear.
Here is your error, sir. There are two β's.
They are different equations, different contexts, different definitions, and most importantly, different sign conventions.
In the Lorentz Transformation equation, (the usual form with negative signs) β is the speed of the observer in the source's reference frame.
In the Doppler shift equation, β is the speed of the emitter AWAY from the observer.
Is this still baffling you?
I've just remembered that radar distance transforms exactly like wavelength between inertial frames, so obviously (radar distance)/wavelength is the same invariant as the one I showed earlier.
It is more intuitive because if the radar is moving towards the sender/receiver then the wavelength looks smaller, as does the distance, by the same factor. And both look longer if the radar is moving away.
[Edit] JDoolin, your post above is wrong, as demonstrated by the above.
Anyhow, I think this is hijacking the thread so we should keep this to PMs.
This seems very clear argument why number of wavelength between two events remains the same after LT.
Who are you quoting here?
If you go back to your source for this, I'm sure you'll either find that they mean something different than you by radar distance, or wavelength, or inertial frames, or, they've made the exact same error you did.
Since "radar distance" and "wavelength" and "inertial frames" seem like pretty unambiguous terms to me, I suspect the most likely explanation is that they've made exactly the same error you did, which is using β in the LT and β in the Doppler shift equation without paying attention to the sign convention.
Specifically, they miscalculated the radar distance, not recognizing that it must go up as the observer accelerates toward the source.
This is VERY counterintuitive. This is such a common mistake among General Relativity Experts, I can't really blame you for it.
But please see
http://www.spoonfedrelativity.com/pages/Galilean-Transformation.php
and
http://www.spoonfedrelativity.com/pages/SR-Starter-Questions.php
and
http://www.spoonfedrelativity.com/pages/coordinate_concept_quiz.php
And TRY to understand!
For example
http://www.phil-inst.hu/~szekely/PIRT_BP_2/papers/pierseaux_09_ft.pdf
Page 9 equation (26) and following. Especially,
... the transformation of length and wavelength are the same
I'm not so you can. Here's me making some more mistakes,
http://www.blatword.co.uk/space-time/radarlc.pdf
Yes, it is. It isn't intuitive that the spatial coordinate difference should transform the same way, but I can't see an error in the (trivial) calculation I did.
[Edit]In flat spacetime, radar distance is coordinate distance, so that solves that one. Dear me, is that the kind of mistake general relatvists typically make :biggrin:
Mentz114 said:
For example
[tex]\sqrt{\frac{1+\beta}{1-\beta}}+\sqrt{\frac{1-\beta }{1+\beta}}=2 \gamma[/tex]
assuming β is a real number between -1 and 1,
and assuming
[tex]\gamma = \frac{1}{\sqrt{1-\beta^2}}[/tex]
Is that equation
(a) Always true?
(b) Sometimes true?
(c) never true
Let's make a small modification to that equation:
[tex]\sqrt{\frac{1+\beta}{1-\beta}}+\sqrt{\frac{1-\beta }{1+\beta}}=\pm 2 \gamma[/tex]
Is that equation
(a) Always true?
(b) Sometimes true?
(c) never true
Now I don't mind looking stupid so long as I can learn something, so I'm going to ask the stupid questions. Where does radar time appear in the equation? Where does wavelength appear in the equation? What relevance does this equation have to our conversation up to this point?
[tex]\sqrt{\frac{1+\beta}{1-\beta}}+\sqrt{\frac{1-\beta }{1+\beta}}= 2 \gamma[/tex]
The left hand side is symmetric in β. Changing its sign will not change the rhs which is always 2γ.
The sign convention for the LT - if two observers are separating then the relative velocity is +beta. If they are approaching the relative velocity is -beta.
This is true in both frames. Doing an LT can't make converging obervers begin to separate. My calculation is for positive beta ( separating) and gets the right result.
Yeah, that's pretty close! "the kind of mistake general relatvists typically make" is to first say "the meaning of distance is arbitrary" and then not to acknowledge the different definitions of distance.
So, obviously my list of "definitions of distance and length" is not complete since I have not included this "radar distance" in the list.
You have defined what you mean by radar distance here:
This looks pretty good to me. I haven't worked through it in close detail, but the way you've defined radar distance, L, here, you will be correct in saying the quantity
[tex]\frac{L}{\lambda }[/tex]
is invariant IF you say L is the radar distance and λ is the wavelength of the reflected signal.However, in my understanding, the problem we've been working on is what happens to
if L is the spatial distance to an event currently being observed, and λ is the wavelength of a NON-reflected signal.
This is an entirely different problem-set-up.
To clarify:
Spatial distance (to an event)
I look at my dresser, 10 feet away, and see an event that happened to it 10 nanoseconds ago, and say, "That event looks about 10 feet away."
More mathematically, if we have two events (x0,t0) and (x1,t1) then the spatial distance between those two events is |x1-x0|.
Radar distance (to an object)
I flash a light at an object, and see the return flash about 20 nanoseconds later, divide 20 nanoseconds by the speed of light and say, "I calculate it to be about 10 feet away."
So at least I understand now that we are definitely talking about two different situations; different contexts; different problems; different definitions of the same variables. With one definition of the variables, it is true to say L/λ is invariant. With another definition of variables, it is true to say L*λ is invariant.
Say sender is sending short pulses of light toward receiver. Number of pulses in transit between two spacetime events (one on wordline of sender other on receiver's wordline) does not change with LT. I think this works as a model for number of wavelength as well.
And if we take your picture from post #50 and imagine performing LT with it I would say that number of light wordlines crossing horizontal line will change with LT. So that number of wavelength between wordlines of sender and receiver should change with LT.
