Intersection of a sphere and plane problem
3 replies · 33K views
prace
Hello,
I was wondering if anyone could offer some advice on this one. I have a multi-part problem, in which I can't get the second part. It starts like this:
(a)
Find the equation of the sphere passes through the point (6,-2,3) and has a center of (-1,2,1).
So I did this find and came up with:
(x+1)²+(y-2)²+(z-1)² = 69
(b)
Find the curve in which this sphere intersects the yz-plane.
So this is where I am stuck...
The zy plane is the set [itex]\Pi_{zy}[/itex] of all points (x,y,z ) of R^3 for which x=0.
and your sphere (I haven't checked if you found the correct radius) is the set [itex]\mathbb{S}_{\sqrt{69}}[/itex] of all points (x,y,z) of R^3 that obey the equation (x+1)²+(y-2)²+(z-1)² = 69.
So, if you define the set [itex]\mbox{Intersection}(\Pi_{zy},\mathbb{S}_{\sqrt{69}})[/itex] of as the points (x,y,z) of R^3 that obey both to the x=0 and the (x+1)²+(y-2)²+(z-1)² = 69 condition, then points of this set are both the plane and the sphere. Logical?
Hmm.. This is a little confusing for me. Sorry about that. So... I am not sure what the notation [itex]\Pi_{zy}[/itex] means, but I am guessing that it means the set of points on a sphere in the zy plane? But what you are basically telling me to do, or to think about, is to let x = 0, then I can solve a system of 2 equations and two unknowns to solve for y and z when x = 0. How does that sound?
First, do you understand that the intersection is a curve- one dimensional- and so can't be written as a single equation in 3 dimensions?
Yes, you can let x= 0. But then you can't "solve a system of two equations and two unknowns to solve for y and z when x= 0" because, first, you don't have two equations, and second, the intersection is not a single point!
letting x= 0 you get 1+ (y- 2)2+ (z- 1)2= 69 or
(y- 2)2+ (z- 1)2= 68. That's the equation for a circle. A standard parametrization for a circle is to let [itex]\theta[/itex] be the angle a radius makes with an axis. In particular, what must y and z be, in terms of [itex]\theta[/itex] so that your equation becomes
[itex]68cos^2(\theta)+ 68sin^2(\theta)= 68[/itex]?
