Intersection of Lines: Solving for Intersection Point using Equations
  • Thread starter Thread starter Lagrange21
    Intersection Lines
The discussion focuses on determining the intersection point of two lines defined by their parametric equations. To find the intersection, the equations for x, y, and z from both lines must be set equal to each other, leading to a system of equations. By solving these equations, it is determined that both parameters s and t equal 1/2. Substituting these values back into the original equations confirms that the lines intersect at the point (3/2, 1, 2). The solution demonstrates the method for verifying line intersection through parameter values.
Lagrange21
Show that these lines intersect and what is the intersection point?
x=1+t
y=2t
z=1+3t
and
x=3s
y=2s
z=2+s
I don't know how to start, some help please.
x=1+t
y=2t
z=1+3t
and
x=3s
y=2s
z=2+s
You want x,y and z on the first line to equal x,y and z on the second line. What does that tell you?
RGV
RGV
3s= 1 +t
2s=2t
2+s=1+3t
Good. Normally, you can solve two equations for two unknown numbers while here you have three equations. Solve the first two equations for s and t. Do those values satisfy the third equation? If so, the two lines intersect at the point given by that s and t.
3s= 1 +t
2s=2t
2+s=1+3t
s = t = 1/2
how can I show that the lines intersect?
Lagrange21 said:
3s= 1 +t
2s=2t
2+s=1+3t
s = t = 1/2
Plug the above value for s & t into the following equations for your two lines.
x=1+t
y=2t
z=1+3t
and
x=3s
y=2s
z=2+s
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
