Intersection of surface and plane.
The discussion focuses on finding the vector function for the intersection of the plane y = 5/2 with the elliptic cylinder defined by (x^2)/4 + (z^2)/6 = 5. The correct parameterization for the resulting ellipse is derived, leading to the equations x = √20 cos(t) and z = √30 sin(t). The initial approach involved dividing the cylinder equation by 5 and using trigonometric identities, but there was uncertainty about the final steps. A clarification was provided that for the parameterization to hold true for all t, specific relationships between the parameters must be established. Ultimately, the correct parametrization method was confirmed as essential for accurately representing the intersection curve.
Jimmy5050
Parameterizing vector function for intersection of cylinder and plane
Problem asks us to find the vector function of the curve which is created when the plane y= 5/2 intersects the ellptic cyl. (x^2)/4 + (z^2)/6 = 5
I know its going to be an ellipse formed...
I took the given ellptic cyl. equation, and divided by 5 to get (x^2)/20 + (z^2)/30 = 1.
***I parameterized by using x=cos(t) and z=sin(t) and got ((cost)^2)/20 + ((sint)^2)/30 =1.
Now, by looking at examples that are somewhat similar, I could tell the answer by looking at number relationships. However, I am unsure of the true way to go about getting my final solution.
My "made up way" of solving was to set either x or z to zero before parameterizing.
My final answers are x=(sqrt[20])cos(t) y=5/2 z=(sqrt[30])sin(t)
I checked my answer using a graphing program, and it is correct, but I am just unsure about going about the TRUE way of solving once I get to the part labeled *** above.
Thanks.
Any takers? I'm sure I have the answer right, just not sure of the "correct" last couple steps to get to that answer so that I can show work properly.
This step seems flaky to me.
The correct parametrization is, I believe, x = a*cos(t), z = b*sin(t). Then you have
\frac{a^2 cos^2(t)}{20} + \frac{b^2 sin^2(t)}{30} = 1
For this equation to be identically true for all t, it must be that a2 = 20 and b2 = 30, which makes the parametric form of the ellipse (in the x-z plane)
x = \sqrt{20} cos(t)
z = \sqrt{30} sin(t)
I think this is the right way to go about it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
