What is Solving a Statics Problem: Finding the Resultant Force?
  • Thread starter Thread starter findley
    Intro Statics
The discussion centers around solving a statics problem involving resultant forces and moments. The user initially struggles with separating forces into components and applying the moment equation. Participants suggest using the vector cross product to find moments, explaining its relation to force and position vectors. They clarify that the direction of the moment is important and can be defined as clockwise or counterclockwise. Ultimately, the user reports successfully finding the solution to the problem.
findley
Here is a link to the problem that I am having issues with.
http://tinypic.com/r/8zfb5h/7
F x perpendicular distance
http://tinypic.com/r/1tamma/7
I have no idea where to go from there, or if I am even on the right path.
I separated the force into components but I have no idea what to do next.
I tried to for the equation 500 Nm = -Py (1.3164m) - Px (1.2276m) but got stuck.
Any help would be greatly appreciated!
Thanks
You can do it that way, just note that Px, Py, and P are trigonometrically related, so you can solve for P using that relationship.. Usually, using the definition of M = F times perpendicular distance works well, but in this case, try the equivalent definition of a moment using the vector cross product M = r X F
Unfortunately I have not done the vector cross product. Is it something I could teach myself in a few days?
Thanks!
You can teach yourself the cross product in less than 5mins, it kinda like a cofactor expansion to find a determinant
Thanks!
The vector cross product r X F is (r)(F)(sintheta), where r is the magnitude of the position vector from the point about which you are summing moments to the point of application of the Force , F is the magnitude of the Force itself, and theta is the smallest of the angle between r and F. If M acts clockwise about the point you are summing moments about, then the moment is negative, and if it is ccw, the moment is positive (or vice versa, depending on sign convention you use). The moment has a direction, cw or ccw, or, mathematically speaking, a direction perpendicular to the plane in which the moment acts. Depending on the problem, one method is easier than the other, but they both lead to the same result.
Thank you both very much. I have found the answer to the problem.
  • · Replies 42 ·
