Inverse function of inequality function
1 reply · 7K views · last reply
xlu2
Find inverse of each.
1. y<x+1
2. y=2x/(x-2)
Switch y and x?
For 1. I switched y and x, so x<y+1. Do I have to switch the sign also?
For 2. I switched y and x, so x=2y/(y-2). But I have to express the inverse function in terms of y. Is there another method I can use?
Many thanks in advance!
There's no such thing as an "inequality function." There are inequality relations. So there's no such thing as an inverse function of an inequality function. Your 1. is an inequality relation.
Also, your 2 is an equation, not an inequality at all.
By "switch y and x" it might be meant to manipulate the relations such that you get x isolated on one side of the relation, as compared to the starting condition where y is isolated on one side.
So, what operations can you perform on an inequality relation such that you keep the smaller side smaller and the larger side larger? For example, if you subtract 1 from each side, what happens?
9 < 10, then subtract 1, you get 8 < 9.
Your 2. is an equation. (Should the = sign be a < sign?) Does it mean, solve for x? Do you know how to do that?
Dan
