Inverse matrix notation question
The discussion centers on the interpretation of the notation (M_{ij})^{-1} for a matrix M with elements m_{ij}. The consensus is that this notation typically refers to the inverse of the matrix, not the reciprocal of individual elements. While a component-wise interpretation is possible when defining matrix multiplication in a specific way, it is not commonly accepted. The example of a diagonal matrix illustrates that even in that case, the notation does not equate to 1/m_{ij} for off-diagonal elements. Overall, the participants express a preference for clearer notation to avoid confusion.
SamanthaYellow
I'm hoping that you can help me settle an argument. For a matrix \textbf{M} with elements m_{ij}, is there any sitaution where the notation (M_{ij})^{-1} could be correctly interpreted as a matrix with elements 1/m_{ij}?
Personally I interpret (M_{ij})^{-1} in the usual sense of an inverse matrix, where it would have the property \textbf M \textbf M^{-1} = I, but perhaps there are other interpretations that I don't know about. Thanks!
The only interpretation I can think of is when you define matrix multiplication component-wise. In this case, the invertible matrices would be the ones with non-zero values, and the matrix you describe would be the inverse. Note that the identity matrix would be the one with 1's as values. I don't think this is commonly used.
I'm not a fan of the notation ##(M_{ij})^{-1}##, mainly because ##M_{ij}## should refer to the component on row i, column j, not the matrix itself. I'm also not a fan of using a lowercase m for the components, because that prevents us from writing the definition of matrix multiplication in what I consider the obviously best way: ##(AB)_{ij}=\sum_k A_{ik}B_{kj}##. I find it very puzzling that some authors go out of their way to avoid this notation, by writing things like "if ##C=AB##, then ##c_{ij}=\sum_k a_{ik}b_{kj}##".
If M is a diagonal matrix, for example
\begin{pmatrix}2 & 0 & 0\\ 0 & 3 & 0\\ 0 & 0 & 4\end{pmatrix} then its inverse is simply
\begin{pmatrix}\frac 1 2 & 0 & 0\\ 0 & \frac 1 3 & 0\\ 0 & 0 & \frac 1 4\end{pmatrix} But even if M is diagonal, and we use horrible notation, we still don't quite have ##(M_{ij})^{-1}=1/m_{ij}## because the off-diagonal elements of ##M^{-1}## aren't 1/0.
This is helpful. The matrix in question isn't diagonal, and that's a good point about 1/0. Hopefully I can convince this other person to change their notation!
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 0 ·
