Inverse Solubility of Solid Solutes
The discussion centers on the inverse solubility of solid solutes, specifically addressing why some solids exhibit lower solubility when heated. Misha explains that the dissolution process can be exothermic, where the heat released during solute breakdown exceeds the heat required for the process. Borek emphasizes the application of Le Chatelier's principle, indicating that increasing temperature can reduce solubility for exothermic reactions while enhancing it for endothermic reactions. Additionally, the conversation touches on the solubility behavior of gases in relation to temperature.
  • Understanding of Le Chatelier's principle
  • Knowledge of exothermic and endothermic reactions
  • Familiarity with equilibrium constants in chemical processes
  • Basic concepts of solubility and temperature effects
  • Research the application of Le Chatelier's principle in various chemical equilibria
  • Study the temperature dependence of equilibrium constants for different solutes
  • Explore the solubility characteristics of gases in liquids at varying temperatures
  • Investigate the thermodynamics of dissolution processes for various solid solutes
Chemistry students, educators, and professionals interested in thermodynamics, solubility principles, and chemical equilibria will benefit from this discussion.
Misha Kuznetsov
Why is the solubility of some solids lower when the solution is heated? I read that it is because the process is exothermic (heat from breakdown is greater than the heat needed for breakdown). But why would having extra heat from outside sources inhibit the dissolving process, wouldn't it only help it?
My source: http://www.chem.fsu.edu/chemlab/chm1046course/solubility.html
-Misha
Chemistry news on Phys.org
Dissolution can be speed up by the increasing temperature, but the solubility doesn't have to grow. Think in terms of Le Chatelier's principle.
The other thing you'll want to examine is the temperature dependence of the equilibrium constant for the solution process.
-Misha
As Borek noted think about this in terms of Le Chatelier:
solid + H2O --> solute + heat (exothermic) ---> Increasing T will reduce solubility
solid + H2O + heat ---> solute (endothermic) --> Increasing heat will increase solubility
Interestingly, gases typically have reduced solubility in water with increasing temperature -- one reason why warm soda tastes bad...
19K
  • · Replies 23 ·
  • · Replies 29 ·
12K
