Inverting a function? f(y) instead of f(x)
  • Thread starter Thread starter iLIKEstuff
    Function
The discussion focuses on inverting a 7th-order polynomial function to calculate the difference in X for a given Y. The original poster has coefficients for two curves and seeks a method to derive f(y) from f(x). They initially attempted a 90-degree rotation of the data but found it ineffective due to altered X values. Ultimately, they successfully used eigenvalues to find the roots of the polynomial equations, filtering out complex and distant roots based on their knowledge of the expected X values. This approach allowed them to achieve the desired comparison between the fitted curves.
iLIKEstuff
I'm trying to compare two fitted curves by looking at the difference in x. Standard regression analysis tools always give you a delta Y (residual) and this is how the fit is done in the first place.
So I have the coefficients of each of the terms for my 7th-order polynomial. it's in the form
y = f(x) = ax^7 + bx^6 + cx^5 + dx^4 + ex^3 + fx^2 + gx + h
The two curves have slightly different coefficients. Now how do I invert this function to get an f(y) so that I can calculate the difference in X for a given Y?
This problem is easy for a simple function like y = f(x) = ax^2 then inverting it you get x = f(y) = \sqrt{y}/a for positive y-values.
Since I have the actual X and Y sets of values, I tried rotating the values 90 degrees (http://en.wikipedia.org/wiki/Rotation_matrix) and then looking at the delta Y, but the problem is the X values aren't the same anymore. Yes, a somewhat pointless attempt, but potentially serendipitous nonetheless.
I have the X and Y data and also have access to a basic PC with MATLAB for number crunching if needed.
Are there any clever tricks I can play to get the difference in X for a given Y? I'm sure I'm missing something here...
Since polynomials are infinitely-differentiable, you can use the inverse function theorem to determine where/if a local or global inverse exists. For one, your function must be 1-1 and onto ℝ (which I assume is your codomain) for a global inverse to exist.
You may want to try 'solving for x' in your equation, see what you get.
Thanks for the help. I managed to figure it out using eigenvalues to find the roots and also the fact that I know roughly what the root should be (since my function is completely arbitrary). Basically I fed in the Y values for both equations, then solved each one for X by finding the eigenvalues. Since I know the X for one set isn't too far off from the X in the other set, I can reject all complex roots and roots that are way off.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 17 ·
