Ionisation by a magnetic field?
7 replies · 6K views · last reply
Kael42
Is it not possible that, given a powerful enough magnetic field, the binding energy of an electron in a stable, neutral atom could be overcome from the tearing of the negatively charged electrons in one direction, and of the positively charged nucleus in the other?
I have searched online, and there doesn't seem to be a mention to this anywhere...
If this were to be true, I imagine that it would have been used already to form otherwise unobtainable negative ions, and make brand new compounds. Such a revolution has obviously not happened, so what is the problem with my logic?
If the problem is that it requires too strong a magnetic field to be produced by human technology, how could the theoretical power required be calculated.
Cheers, Kael.
Do you understand what a magnetic field is and how charged particles are affected by them?
I was fair sure I did, but it has been a while since I dealt with them, and your question seems to imply I don't. I'll google them to refresh my memory.
Took a look. Nothing seems to contradict the logic I found. Positive and negative particles are pulled in circles in opposing directions. In the case of an atom, It would simply be a fight between the pull of the field and and the binding energy of the electrons... wouldn't it?
No. Electric fields pull electrons and nucleii apart, and you can field-ionize atoms this way with sufficiently strong electric fields. What this has to do with "otherwise unobtainable negative ions", I do not have the slightest clue, but magnetic fields are not electric fields - they can change atomic structure and affect emission and absorption spectra, but they do not by themselves ionize atoms.
I'm a bit late here, but I think an enormously strong magnetic field could indeed ionize some atoms. The problem is that as far as I know the ones we obtain in the lab (see there: http://en.wikipedia.org/wiki/Orders_of_magnitude_(magnetic_field )) are too small or they seem to blow up material.
I think we can use the formula [itex]\Delta E =m_l \mu _B B[/itex] (although I am not 100% sure, maybe this formula instead : [itex]\Delta E =(m_l+2m_s) \mu _B B[/itex]. Can someone tell me which one to use for a huge magnetic field?). For example we can take [itex]m_l=1[/itex].
In any case I suggest you to read about the Paschen-Back effect.
Hey guys, I was wondering if anyone could expound on this question, even though it's old, I wanted to add into the question here on whether a magnetic field could be strong enough to propel the atoms into collision with some ferromagnetic element such as Iron.
