What is the Flow Velocity in Irodov's Motorboat Problem?
The discussion focuses on calculating the flow velocity in Irodov's Motorboat Problem, where a motorboat travels downstream and then returns to a raft. The boat overcomes the raft at point A and, after 60 minutes, turns back, passing the raft again 6 km downstream. Participants analyze the relative velocities of the boat and the current, concluding that the total travel time for the boat is 2 hours, leading to a flow velocity of 3 km/hour. The key insight is to consider the problem from the raft's perspective, simplifying the calculations. Understanding the relative motion is crucial for solving the problem accurately.
razored
1.1. A motorboat going downstream overcame a raft at point A; T=60 minutes later it turned back and after some time passed the raft at a distance l=6.0 km from the point A. Find the flow velocity assuming the duty of the engine to be constant.
|------------------------------------------------------------------------------|<< Distance S, the entire length
A ---------------------B(where the two boats meet) ---------------C,( the farthest point the motor boat went)
|------------------------| << this is l which is 6km
B= boat
W=water, or raft
E=earth
When I write B/E i mean boat relative to the earth.
Tau is equal to 60 minutes.
http://mathbin.net/equations/8710_0.png
No matter how many times I manipulate the three equations up there, I do not get the answer which is 3 km/hour.
Consider it in terms of relative velocity.
When the boat passes the raft, then it is moving off at a relative speed of ... the Velocity of the boat. It goes some distance (60 min * Vb in relative terms) and then turns around.
As it returns it is still going at the same relative velocity isn't it, since they are both still in the same frame of reference of the moving water?
So the return time will be the same as the trip down stream won't it? That makes the total time 2 hours? And from someone looking from the shore they have both ended 6 km down the river?
So ...
Doesn't the relative speed change because it goes against the current--the speed of the raft--on the way back?
Could you post an additional mathematical equation or revise one? Sorry, I understand things better in equation form sometimes.
Well in the frame of reference of the river there is no current. If the motorboat moves with constant velocity, then the distance the boat travels from the raft,
d = v*t
The time to travel back then is same d, same v so ... same t.
t + t = 2 t
Distance the river traveled in 2 t is 6 km.
6 km /2 t = 6 km / 2 hr = 3 km/hr.
d = v*t
t + t = 2 t
Thank you! I did not realize to figure out the problem you had to think from the perspective of the raft.
  • · Replies 21 ·
  • · Replies 16 ·
