Does Iron Lose Mass When Exposed to Water and Oxygen?
Iron loses mass when exposed to water and oxygen due to the corrosion process, where it loses electrons to oxygen, forming iron ions and hydroxide ions. These ions can react to create iron hydroxide, which may flake off the surface, leading to a decrease in mass over time. Initially, the mass of the iron object, such as a nail, may increase due to the accumulation of corrosion products, but as these products flake off, the overall mass will decrease. Passivation does not occur in iron as effectively as in materials like aluminum or stainless steel, due to the porous nature of iron oxide.
  • Understanding of electrochemical corrosion processes
  • Familiarity with the concepts of oxidation and reduction
  • Knowledge of iron hydroxide formation and properties
  • Basic principles of passivation in metals
  • Research the electrochemical mechanisms of iron corrosion
  • Study the properties and formation of iron hydroxide
  • Learn about passivation techniques in metals, focusing on aluminum and stainless steel
  • Explore methods to prevent corrosion in iron, such as coatings and galvanization
Material scientists, corrosion engineers, and anyone involved in metal preservation and maintenance will benefit from this discussion.
GuMing
When iron corrodes in water, it loses electrons to oxygen and becomes iron ions. The oxygen retrieved the free electrons and along with water molecules formed hydroxide ions. Eventually, the iron ions and hydroxide ions react to form iron hydroxide. So based on this, would the iron loses mass when i weigh it, since iron hydroxide flakes off and would not stay on the surface of the iron? Am i right? Please correct me if i am incorrect! Thank you !:)
Chemistry news on Phys.org
A lot depends on what is the real question - does it ask about a mass of the object, or mass of the iron?
Some of the corrosion products will flake off, some will stay on the surface. Hard to tell what would be the net effect, as it may change with time. In general I don't think it will flake off substantially, at least in the beginning, so the mass of the object (say nail) would go up.
Thank you for answering my question!
One more thing, if the oxide film (which is the corrosion products)stay on the surface of iron, would it slows down the corrosion process?
To some extent it should.
This is a process called passivation, that can completely stop the oxidation reaction. That's why aluminum or stainless steel don't corrode. For passivation you need oxides to adhere very strongly to the metal surface, which is why it doesn't work for iron.
there is no surface pacification for iron because the iron oxide formed is porous.
Agreed, I should be more clear. There is no passivation in the exact meaning of the word, but presence of oxides still slows the corrosion.
  • · Replies 17 ·
12K
13K
