Iron Oxidation States: Fe+2, Fe+3 & Fe- Explained
The discussion focuses on the oxidation states of iron (Fe), specifically Fe+2 and Fe+3, and the confusion surrounding their electron configurations and bonding behavior. Fe+2 forms when iron loses two electrons, while Fe+3 results from the loss of three electrons, leading to a stable configuration of 3d5. The conversation clarifies that Fe does not donate electrons in the traditional sense but rather gives them up to achieve a more stable ionic state, particularly in compounds like FeCl3, where Fe3+ interacts with Cl-. The octet rule is less applicable to transition metals like iron, which can exhibit multiple oxidation states due to their unique electronic structures.
  • Understanding of oxidation states in transition metals
  • Familiarity with electron configurations, particularly for d-block elements
  • Knowledge of ionic bonding and compound formation
  • Basic grasp of the octet rule and its limitations
  • Research the electron configurations of transition metals, focusing on iron and its oxidation states
  • Study the formation and properties of iron(III) chloride (FeCl3) and its applications
  • Explore the concept of lattice energy and its role in ionic compounds
  • Learn about the differences in bonding behavior between s/p block and d block elements
Chemistry students, educators, and anyone interested in the behavior of transition metals and their oxidation states, particularly in relation to ionic compounds.
ProjectFringe
I saw on Wikipedia that Fe has both positive and negative oxidation states.
I know that Fe will willingly give up its 2 electrons to form an ionic bond with O for example, making it Fe+2.
1. But how can Fe+3 exist? This means it gives up three electrons right? Does this mean the Fe atoms electron configuration would resemble something like vanadiums?
2. And in what situation would Fe gain an electron to form Fe-? This means it has three electrons instead of two correct?
Chemistry news on Phys.org
1. No. Vanadium is 4s2 3d3; Fe3+ is 3d5.
2. The Wikipedia article on iron gives some examples of negative oxidation state compounds. Why not look them up?
I guess what was (is) confusing me is the different electron configurations for Fe ions.
I watched a video about it and my confusion is why Fe3+ is able to donate 3 electrons to form a compound like FeCl3 when it has 5 electrons in its outer shell (d)?
Fe3+ doesn't donate any electrons. Fe gives up 3 electrons to become Fe3+
Sorry for my ignorance. What is the difference between 'donate' and 'give up'?o_O
I still can't understand why Fe would want to give up 3 electrons. So far I have only studied smaller elements (Ca and smaller) and everything made sense because, with the exception of hydrogen, all the elements wanted 8 electrons in their outer shell. So they would give up or gain electrons to reach this state.
But now for some reason (if I'm understanding correctly, which I assume I'm not), Fe would rather have 5 electrons in its outer shell (as Fe3+) rather than 2 electrons (as Fe). Why would Fe do this?
And is Fe becoming Fe3+ as a result of its interaction with Cl3, or is Fe3+ being used as a reactant to create FeCl3? In either situation, I'm still confused because I don't see the 3 electrons needed to bond with Cl3 in the outer shells of either Fe or Fe3+!o_O
The octet (or noble-gas-configuration) model works reasonably well for the s and p block elements (though not perfectly, what about e.g. SF6 or ClF3?), but you can't apply it to the transition metals. When you increase the oxidation state, you have to balance the energy input of removing an electron with the energy output in bonding or lattice energy (mutatis mutandis for reducing the oxidation state). For s and p block elements, the noble gas configuration often constitutes a natural stopping point - going beyond this is energetically unfavourable, as the large increase in ionisation energy is not fully compensated by increased bonding energy. For d block elements, which are generally far from a noble gas configuration, the difference between successive oxidation states is not as great, and these elements often have multiple stable oxidation states. As a beginner, you are better off just learning what these are for each element, and rationalising them afterwards as you learn more about the electronic structures.
PS There is no such thing as Cl3. There is a Cl3- ion, but it is not involved here. FeCl3 is Fe3+(Cl-)3 not Fe+Cl3-.
Okay, thanks for your help!:biggrin:
  • · Replies 21 ·
