Irrational+Irrational=Rational (deeper)
  • Context: Graduate
  • Thread starter Thread starter Monkfish
The discussion revolves around the question of whether two independent irrational numbers can add together to yield a rational number. Participants explore the nature of irrationality, independence, and the relationships between numbers, focusing on theoretical implications rather than established results.
  • One participant suggests that while one can create a "mirror" irrational number to add to another (e.g., pi and 4-pi), this is trivial as the second number is derived from the first.
  • Another participant points out that if x + y = r (where r is rational), then y can be seen as a "mirror" of x, implying a dependence between the two.
  • A participant argues that for two independent irrational numbers to add to a rational, every digit in one would need to match the other, which seems improbable given the nature of irrationals.
  • One participant challenges the notion of independence, stating that the equation x + y = r implies a form of dependence that needs to be defined more clearly.
  • A participant reflects on their own reasoning, suggesting that if two irrational numbers sum to a rational, they cannot be considered independent or disparate.
  • Another participant introduces the concept of algebraic versus transcendental numbers, noting that transcendental numbers like pi cannot be expressed in terms of unrelated rational or irrational numbers.
  • One participant expresses gratitude for insights shared, indicating a desire to further explore the topic.
  • A final participant raises concerns about the difficulty of precisely defining "irrationality," suggesting that this complicates the discussion.
Participants express differing views on the definitions of independence and irrationality, with no consensus reached on whether independent irrational numbers can sum to a rational. The discussion remains unresolved with multiple competing perspectives.
The discussion highlights the complexities of defining independence and irrationality, as well as the implications of these definitions on the relationships between numbers. There are unresolved assumptions regarding the nature of irrational numbers and their generation.
Monkfish
Obviously one can create the "mirror" to an irrational number which itself is irrational and add these two irrationals to get a rational: e.g. pi and (4-pi) are both irrational and add together to make the rational number 4. However, I would call this a trivial solution because the second "mirror" irrational is generated from the first, which is cheating.
So my question is...
Are there any two irrational numbers that are entirely independent, that add together to make a rational? By "independent" I mean that their generation is not related.
This is a far deeper question as it is not always easy to determine if the irrational nature of one number is dependent upon the irrational nature of another. I suppose two such irrational numbers can only be said to be "independent" if their relationship is itself irrational, with all three irrationalities being distinct and unrelated.
For example, can the irrational number (4-pi) be generated in a way that is not related to pi?
If all mirrors to irrational numbers have no independent generators, then although in theory the addition of two irrational numbers can make a rational, in practice there are none where the irrationality of the second isn't spawned directly from the irrationality of the first.
If x+y=r, r rational, then y=r-x, so it is a "mirror" of x in your sense.
That's right, but the irrationality of y derives from the irrationality of x (or vice versa) so both x & y have the same irrationality. I'm asking whether two independent irrational numbers can ever add to make a rational.
Thinking about it, I'm sure there are no examples. Because for a completely independent irrational number to add to another and make a rational, every single digit in the second would have to match with every digit in the first to make the rational result. As irrational numbers extend to infinity, the chance of finding an independent match (mirror) to the first is zero. If there is a match (mirror), then its irrationality must be spawned by the irrationality of the first. In other words, it's the same irrationality... as in your example above.
Then YOU are going to have to define what YOU mean by "independent". The very fact that x+ y is equal to some specific number gives them a kind of "dependence". You question makes no sense without an a-priori definition of "independent".
Yes, I think you're right. I think I am talking nonsense. If two irrational numbers (or even their generating functions) add to form a rational, then by definition those numbers (or functions) are mirrors. So how did I get sucked down this road? I guess, I wanted someone to come up with an example where say the root of a prime added to pi squared produced a rational, or some such example of a pair of disparate irrationals that produce a rational that aren't just linked by the fact that x+y=r. But I think that even in this case, if x+y=r then f(x)+f(y)=f(r), so they can't be disparate functions. If they are disparate functions then we simply have the case where the two irrationals sum to form a third. So yes, you're right, I'm talking nonsense.
For fun, let's apply the cubic formula to the polynomial
x3 + 6x -20​
Via the cubic formula, one of the roots is
[tex]\sqrt[3]{10 + \sqrt{108}} - \sqrt[3]{-10 + \sqrt{108}}[/tex]​
more commonly known as
2​
An algebraic number is a number that is a root of a non-zero polynomial in one variable with rational (or equivalently, integer) coefficients. Numbers such as pi that are not algebraic are said to be transcendental and ¨almost all¨ irrational numbers are transcendental.
Since pi is not a root of a polynomial with rational coefficients, there´s no way to express pi in closed form in terms of anything rational and/or irrational unrelated to pi. Anything reasonable you want to write on the RHS of the equation will have to contain at least one number from a field extension of the rational numbers containing pi.
Likewise, in order to express a rational number in terms of irrational numbers, it will be necessary that the ¨irrationality¨ involved cancels out as described in the previous paragraph.
Thanks FaustoMorales. I think that is what I was trying to grasp with my fuzzy brain. I will investigate in the direction you have pointed.
The problem with that is that it requires as precise definition of the "irrationality" of a number- and I doubt that it can be done.
  • · Replies 33 ·
  • · Replies 0 ·
