Is 3^n Greater Than n^4 for All n>=8?
  • Thread starter Thread starter lolo94
    Induction Proof
12 replies · 2K views
lolo94
Prove that 3^n>n^4 for all n in N , n>=8
Base case: 3^8>8^4
Inductive step
Assume 3^n>n^4. Show 3^n+1>(n+1)^4
I tried a lot of approaches to get from the inductive hypothesis to what I want to show
Ex:
3^n>n^4
3^n+1>3n^4
3n^4>(3n^4)-3=3(n^4-1)=3((n^2)-1)((n^2)+1)=3(n+1)(n-1)(n^2+1)>3(n+1)(n-1)(n^2-1)
=3(n+1)(n-1)(n+1)(n-1)=3((n+1)^4-(n-1)^4)
It looks like I went too far
My other approach is this. It looks a little bit crazy, but I think it works
3^n+1>n^4+2*3^n
I will show that n^4+2*3^n grows faster than (n+1)^4 by using limits and loopitals rule.
on Phys.org
Base case: 3^8>8^4
Inductive step
Ex:
3^n>n^4
3^n+1>3n^4
3^n+1>n^4+2*3^n
Have you tried to expand ##(n+1)^4## with the binomial formula and then substitute the powers of ##n## by your inductive hypothesis? And remember that ##n ≥ 8##.
Base case: 3^8>8^4
Inductive step
Ex:
3^n>n^4
3^n+1>3n^4
3^n+1>n^4+2*3^n
From ##3^n > n^4## it does not follow that ##3^n+1 > (n+1)^4##, which is what you wrote. If you mean ##3^{n+1} > (n+1)^4##, then use parentheses, like this: 3^(n+1) > (n+1)^4.
yes sorry, so how do I do it?
fresh_42 said:
Read my post.
sorry I just scroll down. Ummm so (n+1)^4=n^4+4n^3+6n^2+4n+1. Do I have to go from what I have to show to the inductive hypothesis?
Yes, here you can substitute the powers of ##n## with the inductive hypothesis, e.g. ##4n^3 < 4 \frac{3^n}{n}##. Plus the lower bound on ##n## gives an upper bound on ##\frac{1}{n}##.
how does that maintain the inequality?. For example, 3^(n+1)>n^4+4n^3+6n^2+4n+1. I am just allowed to replace values smaller than n.
fresh_42 said:
But you can as well start with ##(n+1)^4## and make it bigger as long as you stay below ##3^{n+1}##, don't you?
4n^3<4*3^n/n
n^4<3^n
6n^2<6*3^n/n^2
4n<4*3^n/n^3
1<3^n/n^4
and then you add them, but how do I show that 3^n+1 is greater than the resulting inequality.
lolo94 said:
4n^3<4*3^n/n
n^4<3^n
6n^2<6*3^n/n^2
4n<4*3^n/n^3
1<3^n/n^4
Already said. You have an upper bound for ##\frac{1}{n}##, too. Now go ahead and really add the terms. Is there a common factor? How big are the remaining terms? (Hint: leave the 1 alone there's space enough.)
When you go from ##3^n## to ##3^{n+1}## you multiply by 3; when you go from ##n^4## to ##(n+1)^4## you multiply by ##(\frac{n+1}{n})^4 = ( 1 + \frac{1}{n})^4##. As long as you have ##3 \geq (1 + \frac{1}{n})^4## your induction step should be OK.
It looks using this should work nicely.
##3n^4=n^4+n^4+n^4\ ## Yes, that's pretty much trivial.
Then to show that ##\ 3n^4 > n^4+4n^3+6n^2+4n+1 \,,\ ## compare the following:
##n^4\ ## and ##\ n^4\,,\ ## trivial
##n^4\ ## and ##\ 4n^3+4n\,,\ ## remembering n ≥ 8 .
##n^4\ ## and ##\ 6n^2+1\,,\ ## remembering n ≥ 8 .​
