Is 3500 lb/in Referring to Force per Inch of Width?
  • Context: Undergrad
  • Thread starter Thread starter Corsan
    Confusion Force Units
The discussion centers on the interpretation of a failure load of 3500 lb/in for a composite piece made of CFRP (Carbon Fiber Reinforced Polymer) with dimensions of 10" x 1" x 0.138". Participants clarify that the 3500 lb/in measurement likely refers to the load capacity per inch of width, suggesting that a 2-inch wide section would theoretically withstand 7000 lb/in. The conversation emphasizes the importance of understanding the material properties and the context of the load measurement, particularly the distinction between the load capacity of a single ply versus multiple plies of CFRP.
  • Understanding of composite materials, specifically CFRP (Carbon Fiber Reinforced Polymer).
  • Familiarity with tensile testing procedures and failure load concepts.
  • Knowledge of material properties, including ply properties (E1, E2, etc.).
  • Basic grasp of load measurements and unit conversions in engineering contexts.
  • Research the tensile strength and failure load characteristics of CFRP materials.
  • Learn about the significance of ply properties in composite materials.
  • Explore the methodologies for conducting tensile tests on composite materials.
  • Investigate the implications of load distribution across different widths in composite structures.
Engineers, materials scientists, and composite material specialists involved in testing and evaluating the performance of CFRP components.
Corsan
Hi all,
I have a spreadsheet which says failure will occur in my composite piece when a load of 3500 lb/in is applied.
If I were to tensile test this piece and the thickness has already been input (0.138 in) does this mean for every inch wide the piece can take 3500lb of force?
That seems high?
I'm confused about the units of measurement and if someone can clarify this I'd appreciate it,
Regards
This is impossible to answer the general question without a complete description of what you are calculating.
For the particular number you got, it's impossible to say whether 3500 lbf is a sensible load to apply over a 1 x 0.138 inch area unless you tell us what material the test piece is made from.
Ah right okay, its a 10" x 1" x 0.138" thick piece of CFRP (12 plies).
I'm planning on tensile testing unti failure and a spreadhseet I have from the internet says the failure load is 3500 lb/in but nowhere on this does it state the width/length of the piece so its obviously working it out from the ply properties (E1,E2...etc).
What I'm asking is, if that is the 'failure load' then does that mean that for every 1" width that the plies can take 3500 lb/in force?
I would have thought a 1 x 0.138 section of CFRP would take a lot more than that 3500lb. Even mild steel would do that.
Possibly your "3500 lb/in" is for one ply of CFRP, not for 12 ... ?
Okay, I'll keep that in mind during the test.
Am I right in what I say though?
i.e. the 3500 lb/in refers to the width of the cross section, so if it were 2 inches wide the predicted failure would be 7000 lb/in?
Regards
That seems a reasonable guess, but without seeing the complete spreadsheet (or at least the relevant equations) and understanding how it works, it is only a guess and I don't accept any responsibility if it turns out to be wrong!
12K
  • · Replies 0 ·
