Is a Circle Considered a Function?
  • Context: High School
  • Thread starter Thread starter Loren Booda
    Circle Function
10 replies · 58K views
Loren Booda
I was brought up believing that when a mapping had more than one ordinate (y) for a particular abscissa (x), it did not describe a function. So is a circle not a function?
Mathematics news on Phys.org
The so-called "vertical test" will always tell u the answer.In the case of the circle,there are an infinite number of portions/arches (is this the word?? :confused: ) which are functions.
Daniel.
<pointing out what a function is> A function from where to where?
There is some semantics involved.
Since a circle is a geometrical figure, the wording: 'is a circle a function' has no meaning.
For the same reason, a parabola is not a function, but the graph of the function is.
...doh, I `m getting old and picky. Nevermind... :redface:
Indeed, even if we interpret "is a parabola a function" to mean "is a relation whose graph is a parabola a function" we would have to specify the coordinate system. A parabola whose axis is parallel to the y-axis corresponds to a function but exactly the same parabola, in a rotated coordinate system would not be.
(Notice I switched from "circle" to "parabola". A circle, in any coordinate system, does not correspond to a function.)
In any carthesian coordinate system.
In a polar coordinate system, it does.
I mathematics, a function is a sort of black box - you put something in, and it spits something out. (There are other ways to think of them as well.) Now, you ask whether a circle is a function, and the answer is clearly no, since a circle is typically a set of points.
In the familiar (I suppose it could be called cartesian) system, there is no function that whose plot is a circle. In a polar or parametric system functions can readily have circular plots.
It is also relatively easy to see that:
[tex]f(x)=\sqrt{1-x}[/tex]
generates the plot of a half circle - which can often be used instead.
That is: [tex]f(x)=\sqrt{1-x^2}[/tex]
The plot of
[tex]f:[0,2\pi) \to \mathbb{R}^2[/tex]
[tex]f(x)=(cos(x),sin(x))[/tex]
is a circle.
Or is this cheating?
This is the "non-cartesian function" people were mentioning. The question, from what i can tell, boils down to the fact that the OP thinks a graph and a function are the same thing.
