Is a Heightfield a Scalar or a Vector and How Many Dimensions Does it Have?
  • Thread starter Thread starter hexa
    Scalar Vector
A heightfield is classified as a scalar because it assigns a height value to each point defined by coordinates (x, y). This means that for every pair of x and y values, there is a corresponding height, making it a 2-dimensional representation in a 3-dimensional space. The confusion may arise from visualizing heightfields as vector fields, but they do not possess direction in this context. Therefore, heightfields are best understood as scalar functions describing a surface. Overall, they illustrate a 2D surface within a 3D framework.
hexa
Hello,
I've been wondering if a heightfield is a scalar or a vector, and how many dimensions in space it has.
Sure, if it's a scalar it only has a magnitude, and as a vector magnitude and direction but I cannot see either, or keep them apart in this case. Density or gravityacceleration are easier I guess.
Dimensions: 2 would work out: h=(x,y) but would 1d and 3d possible as well?
Hexa
Hello Hexa,
in the case of h=h(x,y) you get for each set of values x and y a corresponding height h, which is a scalar. Or to put it another way: For every point on the x-y-surface you get a certain height h. So altogether the function describes a 2-Dimensional surface in a 3-Dimensional space.
I hope that was helpful for you.
Hi David,
that was also my intuition. I got confused by an old exam question about visualising such heightfield as vectorfield:confused: and could not find a direction.
Thanks a lot
Hexa
DavidBektas said:
Hello Hexa,
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
