Is a Line Integral Zero if the Vector Field is Not Conservative?
The discussion revolves around the properties of line integrals in relation to vector fields, specifically questioning whether a line integral can be zero if the vector field is not conservative. Participants explore the implications of their calculations and the definitions of conservative fields.
  • One participant calculates the line integral of the vector field F = -xy⋅j over a circle and finds it to be zero, questioning why the vector field is not conservative.
  • Another participant argues that a vector field is not necessarily conservative just because the integral along one closed line vanishes, citing that the curl of the vector field is not zero.
  • Some participants express uncertainty about the correctness of their calculations and the implications of the results.
  • There is a suggestion to try a different path for the line integral, which may yield a non-zero result, indicating that not all line integrals vanish.
  • A later reply emphasizes that for a vector field to be conservative in a region, all line integrals along any closed line in that region must vanish, not just one.
  • Participants discuss a potential misunderstanding of textbook claims regarding line integrals and conservative fields, with some suggesting that the statement about zero line integrals implying conservativeness may be incorrect.
Participants generally disagree on the implications of a zero line integral for the conservativeness of the vector field. There is no consensus on the interpretation of the textbook statement regarding line integrals and conservative fields.
Some participants express confusion regarding the definitions and conditions under which a vector field is considered conservative, highlighting the need for clarity on the relationship between line integrals and vector field properties.
ZARATHUSTRA
calculate the line integral for a vector field F= -xy⋅j over a circle which is c(t)=costi+sintj,
so I used x=cost y=sint and ∫(0 to 2pi) -(sintcost)(cost)dt=(cos^3(2pi)-cos^3(o))/3=0 now here is the problem, if this enclosed line integral is zero then why is the vector field not conservative?
dr(t)/dt=(-sint,cost) then dot with F gets -(sintcos^2t)
cant find anything wrong with my calculation process
and the textbook tells me that if enclosed line integral is zero then vector field must be conservative which means there is something with my work but I checked my work so many times and I just can't find it
Why should it be conservative, if just the integral along one closed line vanishes? It's definitely not conservative, not even locally, because ##\vec{\nabla} \times \vec{F} \neq 0##.
Thanks in advance for anyone who takes time to read it and would like to help me with the problem
right, but the enclosed line integral is zero, which means either I am wrong with the integral calculation, or the vector field is conservative
but I just can't find where I calculated wrong
The line integral vanishes, but obviously not all line integrals. Try
$$\vec{x}(t)=\cos t \vec{i} + (1+\sin t) \vec{j} $$
instead.
instead.
what do you mean it vanishes? is my line integral zero?
instead.
but this doesn't describe the circle, does it?
It describes a unit circle with its center in ##(0,1,0)##. You'll see that it's a closed line for which the line integral does not vanish, and that explains, why the field is not conservative. For a field to be conservative (in some region) all line integrals along any closed line must vanish (in this region).
right, but I was calculating the line integral of a circle centered at (0,0,0)
Yes, your line integral vanishes, as you have correctly evaluated yourself. If you try the other line integral instead, you'll see this one doesn't vanish, and thus the field cannot be conservative!
Please think about what I try to explain with my answers!
vanhees71 said:
It describes a unit circle with its center in ##(0,1,0)##. You'll see that it's a closed line for which the line integral does not vanish, and that explains, why the field is not conservative. For a field to be conservative (in some region) all line integrals along any closed line must vanish (in this region).[/QUOT
and if The region I calculated is a closed curve and it is zero, then it should be conservative, right?
NO! The field is conservative in a region, if the line integrals along ALL closed lines in that region vanish. It's not sufficient that one special line integral along a special closed curve vanishes!
yes of course, the integral I calculated from your region is definitely NOT zero. But the region I calculated IS zero, and the region is still closed curve. But the textbook tells me that if the Line integral of an enclosed curve is zero, then the vector field must be conservative.
Which textbook? If it really claims what you say, find a better one!
Just to give you another example for something really puzzling! Consider the scalar field
$$\phi(\vec{x})=\arctan(y/x).$$
(a) calculate the gradient field ##\vec{V}=-\vec{\nabla} \phi##.
(b) Integrate this vector field along the unit circle ##\vec{x}(t)=\cos t \vec{i} + \sin t \vec{j}##.
(c) Explain the (hopefully) surprising result!
hmm maybe I interpreted wrong
so I guess the statement "if the Line integral of an enclosed curve is zero, then the vector field must be conservative." is false
Thank you so much sir, I think I get it now.
Which book is it? Maybe it's good to avoid it in the future!
It was my bad and hasty interpretation. But the Book name is Calculus Early Transcendentals(2nd E) by Briggs Cochran Gillett
  • · Replies 20 ·
  • · Replies 45 ·
