Is a Matrix with a Zero Column Invertible?
A square matrix with a column of all zeros cannot be invertible. This is due to the linear dependence of its columns, as a zero column implies that the columns are not linearly independent. The determinant of such a matrix will also be zero, confirming its non-invertibility. Additionally, if a matrix has a row of all zeros, it faces the same issue. Therefore, a matrix with a zero column or row is definitively not invertible.
lolimcool
Can a square matrix with a column of all zero's be invertible?
It's not looking like it will be. How did you form the matrix in the first place?
i didnt form a matrix, I am just wondering is it possible for a square matrix to have a column and be invertible
If you try to calculate the determinant of a matrix with a zero column by using minors, you will quickly see that a regular inverse does not exist. The same situation will apply if you have a matrix containing a row with all zeroes.
The answer is a definite no.
There are many ways to show it is not possible.
Do you know the link between invertibility and determinant? If so, think about the quickest way to calculate the determinant of a matrix with a column (or row) of zeros.
Determinant-free answer:
In order for a square matrix to be invertible, its columns have to be linearly independent, which is clearly not the case if one of the columns is all zeros. (Why?)
Yet another way of looking at it (though almost the same as jbunnii):
If A has its "ith" column all 0s, then Av where v is all 0s except for the "ith" position, is the 0 vector. A cannot be invertible because there are many different vectors (differing in the "ith" place) that are all mapped into 0.
