Is a0 Always Equal to the Zero Vector in Any Vector Space?
17 replies · 4K views
1MileCrash
Prove that a0 = 0
Let V be a vector space on a field F. Let x be a member of V and a be a member of F.
Consider that the 0 vector is the unique vector such that
x + 0 = x
Now, apply a scalar multiplication by a to both sides of the equation. Because scalar multiplication is distributive in all vector spaces,
ax + a0 = ax
Thus, we see that a0 has the same property of the 0 vector in V. Since the 0 vector in V is also unique, it must be the case that
a0 = 0
QEDCan I do that?
1MileCrash said:
Prove that a0 = 0
x + 0 = x
ax + a0 = ax
a0 = 0
QED
Can I do that?
I don't think you quite have it. Have you shown that for ALL y you have y + a0 = y?
But if
x + 0 = x
is true for all x (which it is by definition of the zero vector) then
ax + a0 = ax
is also true for all x, and it is true for all a (because scalar multiplication is distributive in all vector spaces), so then it is always true, so it is true for any ax (or y).
Right?
LCKurtz said:
It may be trivial, but you haven't shown that any y can be written in the form ax.
Oh, ok.
So, I need to justify that ax is also an element of V? Am I understanding that correctly?
If so, then can I just say that in all vector spaces, for each element a in F and each element x in V, there is a unique element ax in V, thus, let ax = y, which is a known element of V (and then the result follows)?
1MileCrash said:
Oh, ok.
You have shown that a0 works as an additive identity on all elements of the form ax. If every y in V can be written that way you have it as an additive identity on all of V, which is what you want. Think about ##y = a(\frac 1 a y)##.
As an alternative approach to the problem think about a(0+0) in the first place.
Ok, instead of saying "the result follows" I'll just write it out.
"for each element a in F and each element x in V, there is a unique element ax in V, thus, let ax = y, which is a known element of V (and then the result follows)?"
ax = y
x = (1/a)y
(1/a) is the multiplicative inverse of a and is therefore a member of F. y is already known as a member of V. Therefore any element x of V can be expressed as a scalar multiplication of a member of the field and another member of V.
That's what I was getting at, would you say that is adequate?
Thanks again.
Using LC's hint :
a0 = a(0+0) = a0 +a0
So you have :
a0 = a0 + a0
Hmm what property of vector spaces would help you here now? There aren't too many to consider so I'm sure you will see it any moment.
Zondrina said:
Using LC's hint :
So you have :
a0 = a0 + a0
I'd rather just complete the attempt I've done myself, this is the proof my book gives.
ax = y
x = (1/a)y
Thanks again.
No, I don't think so. At the very least, it is confusing. Summarizing your argument so far you have shown that for any ##a\in F## and ##{\bf x} \in V## that ##a{\bf x} + a{\bf 0} = a{\bf x}##. What you need to show is that for any ##{\bf y}\in V## you have ##{\bf y} + a{\bf 0} = {\bf y}##. You have to start with ##\bf y##. You can't start with ##a{\bf x}## and call it ##\bf y##. Look at my suggestion in post #6 again.
Well you know that ##a \in F## and I would recommend writing ##0## as ##0_V## as to be more explicit.
So really you want to show ##a0_V = 0_V##.
##F## is a field of scalars. Since ##V## is a vector space, it is closed under addition and scalar multiplication. You know that ##\forall v \in V## and ##\forall a \in F## that ##av \in V## because ##V## is closed.
Now, we've shown there are basically infinitely many vectors of the form ##av## inside of ##V##. So if you want to proceed your way from before, add ##av## to both sides :
##a0_V + av = 0_V + av##
Now because ##0_V## is the unique vector such that ##0_V + v = v, \forall v \in V## ( Prove this if you havent! ) we can proceed :
##a0_V + av = av##
I'll let you finish that one if you want to. Your argument in your last post wouldn't work though. All you did was set y=ax and say y was in V. LC stated if you can show every ##y \in V## can be written as some ##ax##, then you know that ##a0## will work perfectly as an identity.
Why can't I call ax, y? It's just an element of V.
Looking at y=a((1/a)y) makes me fall back to the same reasoning. If y is an element of V then so is (1/a)y, so a((1/a)y) is an expression for y that is a scalar multiplication of an element of F and an element of V. But that's exactly what I did before. What is wrong with this reasoning?
1MileCrash: I think you can't say for each ##a## because you are given ##a##. Given ##a##, you must show that a##0_v = 0_v##. I can see a much quicker proof using components.
-edit- Hmm, I suppose this component idea is limited (without choice) to finite-dimensional vector spaces, better to prove this in general.
Because you have to start with an arbitrary ##{\bf y}\in V##. You have all the pieces but your argument should be written like this:
Suppose ##{\bf y}\in V## and ##a \in F##.
Let ##{\bf x} =\frac 1 a{\bf y}##
##{\bf x} + {\bf 0} = {\bf x}##
##a\frac 1 a{\bf y} +a{\bf 0} = a\frac 1 a{\bf y}##
##{\bf y} +a{\bf 0} ={\bf y}##
Therefore ##a{\bf 0}## is the unique additive identity.
Oh, I see, that comes out very nicely. I just thought that since x was an arbitrary vector, then so is ax or y. I don't see a difference between letting ax=y and letting x=(1/a)y.
Thanks again.
EDIT: nevermind, got it backwards.
There is still a mistake here. Given a, we aren't told that it isn't 0.
Gotta keep your apples in order. If you start with a given ##a \in F##, you must be faithful to that.
I have no idea what you are saying. Could you explain how I have not done that? Or what that means?
All I did was define a to be an element of F so that I could use it in an expression without the reader not knowing what it is. What do you mean by "starting" with it?
