Is 'Airwolf' possible with our current technology? (Supersonic Helicopter)
69 replies · 37K views · last reply
phinds said:
Asking a question that makes no sense doesn't make any point that I can see.
Maybe someone else does seem to understand
But i really dont want to bring out the crayons to make you understand
Please watch the attitude. Thanks.
I appolagice
So if i stil may continue?...
The main fusalage is the main displacer/mass body.
It will create the mach angle (at mach 1 its around a 90 degree angle at mach 2 its around a 30 degree angle)
In most cases the rotor is mounted at the top helicopter and the blades sticking beyond the nose of the main fuselage
So even when going under the speed of sound the blades are past and out mach angle
And that fine i guess until we reach certain speeds.
After this speed the blades needs to be in the angle and if possible the tips need to trace the maximum allowed angle the be still a aficient control surface
phinds said:
What on Earth is your point with that statement? LOTS of airframes would go over mach 1 if reshaped and with no rotors, just jets engines.
Hell, if you reshaped me (it would take some work) and put a jet engine on me, I could probably go over mach 1.
So if we did this head first rocket strapped and you would keep your arms at 180 degrees at mach 1 they would be at 90 degrees or 45 degree angle each and at mach 2 30 degree from the tip of your head or going of your center bodyline 15 degrees each side
phinds said:
This has gone beyond ridiculous. I'm outta here.
Ah Come on i am trying to explain my point of vieuw nicely now 😲😳
@airwolflover -- PF is not a playground where you can throw out ideas and personal speculation. This thread is in the technical forums, so all discussion needs to be traceable to the mainstream scientific literature. There have been some good posts in this thread over the years (and some not-so-good ones), but for this thread to be reopened it would require valid references. If you or others have such references, please send me a PM (click on my avatar and "Start a conversation"). Lacking that, the thread will remain closed.
