Is an isometry always a bijection?
  • Thread starter Thread starter 3029298
    Isometry
6 replies · 11K views · last reply
3029298
A function from the plane to itself which preserves the distance between any two points is called an isometry. Prove that an isometry must be a bijection.
To prove that an isometry is injective is easy:
For an isometry: [tex]||f(x)-f(y)||=||x-y||[/tex]
If [tex]x\neq y[/tex] then [tex]||x-y||>0[/tex] and therefore [tex]||f(x)-f(y)||>0[/tex] and [tex]f(x)\neq f(y)[/tex].
But to prove that an isometry is surjective... how should I do that?
Have you thought about what all this means in terms of high-school Euclidean geometry?
Well, I tried to make some drawings in the plane, but they do not seem to lead to a solution...
Well, at least have you found other things that must be preserved by an isometry?
Well, if you have three points with [tex]||f(x)-f(y)||=||f(y)-f(z)||=||f(z)-f(x)||[/tex] this is also true for [tex]||x-y||=||y-z||=||z-x||[/tex]. This means that a triangle remains a triangle. But I do not know what first step I have to see to do the proof...
Consider the tiling of the plane by regular triangles with all edges 1. What does your isometry do to its vertices? Once you know that, consider a general point (it is in one of those triangles) and see what you can say about what the isometry does to it.
