Is anyone here familiar with TextPad?
  • Thread starter Thread starter pmb_phy
5 replies · 4K views
pmb_phy
Is anyone here familiar with TextPad? I'm trying to use it as an interface for editing and running Java but I'm having problems. I don't know how to set it up to work with the Java environment.
Thanks
Pete
I use TextPad as a text (ASCII, txt, html) editor, except for Word documents.
Try going into Configure - Preference - and find Document Classes. One of the default classes is Java.
You might also have to set up Associated Files and File Name Filters.
I have no idea what kind of problem you're experiencing. There's really no such thing as a "Java environment." TextPad is a text editor. You can configure some macros to run command-line programs to compile and run your code, but, apart from that, there is no Java environment. Perhaps you could be a little more specific with your question?
- Warren
I use TextPad as an editor too. I used it a few years ago when I was learning C++ and it was a great tool. But now I can't figure out what I'm doing wrong. E.g. I wrote this piece of code
// Fig. 2.1: Welcome1.java.
// A first program in Java.
public class Welcome1 {
// main method begins execution of Java application
public static void main( String args[] )
System.out.println( "Welcome to Java Programming!" );
} // end main method
} // end class Welcome1
Then I selected "Tools->Compile Java" and it took a few seconds and then in another window that popped up behind the code window and read
"Tool completed successfully"
Then I selected "Tools->Compile Java Application" and a DOS window popped up and said
Exception in thread "main" java.lang.NoClassDefFoundError: Welcome1
Press any key to continue . . .
Seems to me that there are some pathways that the computer can't find/doesn't know about. What do I do at this point? I'm not even sure that its compiling. :frown:
Pete
I am not versed in Java, so hopefully chroot can help. I don't know if the syntax of your code is correct or not, but I would wonder if Textpad is using the correct compilation or not, or if it is inserting stuff (equivalent of hidden or control codes?) that is unwanted.
But I am familiar with some TextPad's idiosyncracies. One has to be sure a class of documents is defined and is used when saving a particular class. I am not sure if that is what is happening here. Maybe you found a new one.
