waynexk8
- Messages
- 397
- Reaction score
- 0
D. wrote;
I will try to help Wayne by simplifying his question.
Let's say two weightlifters lift 100 pounds.The first one lifts them in 1sec and the second in 10sec.Obviously the first weightlifter used 10 times greater power than the second.
For that reason Wayne somehow believes that the first weightlifter also used greater force.
This is clearly not true in my opinion.When you lift a weight(regardless if it's in 1 or 10sec) the starting and ending velocity is zero hence the average acceleration is zero too[a=(V2-V1)/t=(0-0)/t=0].So the average force that you use is (F=mg+ma=mg) equal with the weight regardless the lifting speed.
Do you understand what average means ? Its only all the numbers added up. But what it misses, is that the higher high forces in the faster rep, and the higher peak forces are higher.
The higher high forces are 20 or we can say 25% higher, and the peak forces are 60 or we can say 75% higher.
So the higher high forces and higher peak forces are higher, that’s what I have been saying from the start, the total or overall forces are higher, but you will not comment on this or register this ?
D. wrote;
As for the energy that was used...from physics POV the work is identical in both cases.But since the second weightlifter(10sec lifting) used the same average force for 10 times longer I believe it's obvious that he spent more energy.
You have now done something VERY wrong, you have changed the debate.
The debate is, I lift a weight 1 second up, 1 second down 5 times = 10 seconds, you lift the weight 5 seconds up, 5 seconds down.
SO PLEASE, why did you say I only lifted at 1 second up and 1 second down once, but you lifted 5 seconds up and 5 seconds down ? YOU KNOW VERY WELL THIS IS NOT THE DEBATE, AND HAS NEVER BEEN THE DEBATE ?
So now, HOW is the work equal ? If I move the weight 1m up and 1m down 6 times to your 1 time in the same time frame, I have moved the weight 10m more, so more work has been done,
D. wrote;
Now specifically in Wayne's example.
He tries to compare the force and energy in two cases.Either you lift and lower a weight 6 times in 6 seconds or once in 6 seconds again.
As I believe I proved above the average force is the same in both cases.As for the energy that was used...the work done in both cases is zero from physics POV.But since the same average force was used for 6 seconds in both cases my guess is that also the energy expenditure is the same or with biomechanics terms the time-force integral is identical.
I don't know which part of my post you didn't understand to say something like that and to be honest I don't really care.
I won't continue in this discussion.Try to understand what I wrote cause I believe it's really simple.
SORRY, I read it wrong.
Look D. Energy is not all to do with just average force, how are you working out energy ?
And if you look back on this thread, they have worked out quite plain with physics that the faster rep uses more power = more energy, so please tell me why you think their calculations are wrong ?
look on every nutrition site or book. Just borrowed this from your other friend.
Energy Expenditure and Nutrient Oxidation will and have been established in a room calorimetry. Many Statistics will be measured eg; Heart rate, oxygen consumption, fat consumption, protein consumption and carbohydrate consumption, to determine the effects of exercise at different intensities. On every occasion when an activity has been practiced at a faster rate, the heart rate, oxygen consumption, fat consumption, protein consumption and carbohydrate consumption, has been higher, therefore energy expenditure, nutrient oxidation will be higher.
The increase in the rate of energy expenditure/cost will be due the increase in the intensity/force of muscle activity. When a muscle is subjected to a greater acceleration, speed or velocity, EMG reading will go up, when muscle uses more force, more force will equal more acceleration, speed, velocity, equals more energy.
Wayne
