Originally Posted by Austin0
In this context ,,what do you mean by the coordinate speed?
=DaleSpam;2298089]Most coordinate systems have three space coordinates and one time coordinate. The coordinate velocity is then the derivative of the three spatial coordinates wrt the time coordinate. This value is dependent on the coordinate system used, particularly the synchronization convention defined by the time coordinate.
Hi Would I be mistaken to say that basically physics boils down to clocks, rulers, and gauges. They embody the metric and that "coordinate systems" are simply a way of providing a global context, specifc locations (space +time) and directions (angles,vectors) for the clocks and rulers and the measurements they provide. They are invaluable for comparisons of disparate measurements and events and for comparisons between different systems, but in the end, all calculations are simply predictions of measurements of clocks and rulers,et al.
So in this context ie: on board this hypothetical ship. The assumption is the clocks were synchronized by SR convention while inertial, prior to initiating acceleration.
There are two clocks and one long ruler between them. They
are the whole coordinate system as far as this question is concerned.
So I am still unsure what you mean by coordinate speed wrt this situation. Are you
also implying that there is more than one coordinate system to be considered here?
A couple of more questions:
1) Would you agree that as far as
establishing synchronization between separated, unsynched clocks is concerned ; the One way method is absolutely equivalent to the two way, reflected method . That it in all cases it would establish the same actual readings and synchronization (simultaneity) as the standard convention ?
2) Would you agree, or not, that regarding
testing synchronization of clocks already in place ; Two, one way, measurements between clocks A--> B B-->A is a sure test.
That two reflected tests with mirrors , from two locations, cannot itself provide information regarding the synchronization of the two clocks??
thanks
