Is 'charged black hole' an oxymoron?
  • Level: Graduate
  • Thread starter Q-reeus
    Black hole Hole
382 replies · 50K views · last reply
Q-reeus said:
Conservation of charge is actually a different thing - that charge always comes in pairs with equal and opposite sign.
Okay, so you accept conservation of charge, but you are skeptical of what? That charge has the same value in every coordinate system? "Invariance" means "having the same value in every coordinate system".
I'm trying to tease apart what parts of your question are mathematical--having to do with how one does calculus in curved spacetime--and what parts of your question are empirical--what experiments tell us.
If charge is conserved, then that means that the charge inside of a closed surface is a matter of counting. Counting can't give different answers in different coordinate systems. So of course it's an invariant. So I think the real question is about the various integrals that are used to compute the charge?
The following equivalence is provable, for any vector field E:
∫E . dS = ∫(∇.E) dV
(The flux of E through a surface is equal to the integral of the diverge of E over the volume enclosed by that surface)
In relativity, the electric field is not actually a vector, but 3 components of a 6 component tensor Fαβ, but there is a corresponding fact about tensor fields. The equivalence of the two integrals is a coordinate-independent fact that's provable using calculus, and it works the same in curved spacetime.
So, is your question really about Gauss's law: Are you asking whether we have proof that
∇.E = 4∏ ρ
where ρ = the charge density? Or are you asking whether the electric field E is really part of a tensor field Fαβ?
There are a lot of interrelated concepts that are involved in the conservation of charge in curved spacetime, some of them are provable using calculus, and some are empirical.
The empirical part I think is captured by Maxwell's equations, together with the Lorentz force law. If those hold (or rather, their generalization to curved spacetime), then conservation of charge and invariance under coordinate changes is a matter of pure mathematics--if they are true, then it's provable using calculus in curved spacetime. I think that they are true, but the detailed proof is not something I have personally have worked through.
Turning that claim around, if charge is not conserved, or if it is not an invariant, then I believe that is only possible if Maxwell's equations or the Lorentz force law are false. Those have only been tested near Earth, which only has fairly mild gravity, so there is no guarantee that they hold in regions of very strong gravity.
PeterDonis said:
After more cogitating, I have a few more items to throw out for consideration.
Those are interesting facts about charged black holes and the trajectories of test particles, but it seems to me that Q-reeus is asking a more fundamental question, which is whether total charge inside a surface is an invariant under changes of coordinate systems. The details of what happens to a test particle near a charged black hole doesn't seem relevant to that question. Or does it?
jartsa said:
The first equation we learned at school: E =F*S, that's very useful.
Energy is redshifted in gravity field. When a vertical rope is tugged from it's lower end, at the upper end tugs of reduced energy are observed. The force F is reduced, not length S.
If the lower end of the rope has a negative charge, and a posive charge is brought under the lower end of the rope, then at the upper end an increase of weight of rope is observed, and this increace is reduced by the redshift factor.
So we conclude that the constant pulling force, transmitted by the rope, of that positive charge is reduced when observed at higher altitude.
BUT the pulling force that the positive charge exerts on a negative charge at higher altitude is not reduced. Conservation of charge requires this.
BUT at lower altitude it is observed that charges that are being lifted seem to gain more charge, and charges that are being lowered kind of lose charge. Seems the charge of outside universe may change as seen from a gravity well. Interesting. If this needs some justification, then I'll think up some justification.
Keep at it - we seem to be on about the same wavelength!
PeterDonis said:
The Q contributions decrease with increasing r because as r increases, less of the stress-energy of the static electric field is above you.
That makes sense if M does not just represent the neutral mass but is in some way inclusive of the total mass/energy contribution from Q. I may have misunderstood what you were intending in that regard in #14:
This means that the "mass" M of the hole does *not* represent the entire "source" of gravity associated with the hole, as it does for Schwarzschild spacetime; there is an additional effect due to "stress" associated with the charge Q, which is not accounted for in M.
So do we interpret R-N expression as that M = Mn+MQtot (Mn the strictly neutral mass, MQtot the net contribution from Q)? Kind of a funny way of then including effect of Q by hiding net contribution in M then deducting the exterior portion as func{Q(r)} but there seems little other way to see it.
All that is more an issue of quantum field theory than GR, IMO. In classical GR, objects that fall through the horizon don't leave an "imprint" there.
Even if the object is large enough to measurably increase the BH's mass and therefore expand the horizon, that is the only change it makes; there's no other "residue" of it left, classically.
Well, ok, if 'fossil' EM field is exempt from definition of residue! Best to avoid further discussion on that one - likely to side-track. :-p
Yes - I'm sceptical based on the implications as I see it for e.g. scenarios in #1 or say that charged-balloon-and-mat example in last para of #20. No higher maths, just following a comparative trend to it's logical conclusions. Others can come in and either translate or refute that using higher maths - and Internal cosistency is king.
As said last time, afaik there is no empirical evidence either way as to charge invariance holding when gravity is involved. So it's down to I suppose the correct calculus in curved spacetime yes. And I have no training in that arena - line of query is as presented earlier.
Agreed about charge counting. As to correctness of various integrals, it must imo be guided by or at least concur with logical conclusions from the sort of scenarios I have given.
∫E . dS = ∫(∇.E) dV
∇.E = 4∏ ρ
Well your previous statement implies there is no effective difference particularly for static field case a la charged static BH or charged static mass in general. As per my closing comments in #21, on a straight basis (gravitational acceleration at constant r = 'gravitational flux density') the divergence law does fail for 'gravitational charge'. I again draw your attention back to the charged mat-and-ballon case in #20 - not noticing any obvious parallels?
Right - and we are stuck for the forseeable future with use of internal consistency arguments as said before. Which most here consider to be superfluous. You have made no comment on examples I gave you last time, nor attempted to detail where any previous scenarios go wrong. Which is hardly unique to yourself here but is a source of some personal chagrin. If my conclusions are wrong, it should not be too hard to show precisely how in each case. Still waiting.
I think that's right; I may not have been fully clear about it in earlier posts.
I'm not sure you can separate out M_n, because the "contribution from Q" varies with radius. At any finite radius, there will be *some* amount by which the Q term in the metric reduces the effect of the M term. And the Q term continues to change all the way down to r = 0; so there's no point at which you could say that *all* of the Q contribution has been "subtracted out" and what's left is M_n.
If a charged object were falling in, yes, the EM field "left behind" in the exterior vacuum region would not be "residue" in the sense I am using the term here. It would be analogous to the Weyl curvature left behind by the object's energy. Basically, the stuff that isn't "residue" is the stuff that is allowed to be "hair" on a BH, which means conserved quantities: mass-energy, charge, and angular momentum.
I don't believe that you have pointed out any internal inconsistency in General Relativity or the theory of electromagnetism, or the two together. Charge and mass are actually different, because charge is a scalar, while mass is not. The total is just the sum of the charges of the pieces, but that's not true of mass, because interactions change the mass.
That's a weird way of putting things. I would say exactly the opposite---we have plenty of evidence of charge invariance in gravitational fields, and no evidence to the contrary.
I really don't think that the scenarios you have brought up have any bearing on
the invariance of charge. The current theory, which does have invariance of charge, works perfectly fine in all cases that we are capable of analyzing--there is no reason to believe that there is any problem. Of course, that doesn't mean that our current theories are correct, but there is no indication of any inconsistency in them (which is what I thought you were claiming).
There is no such thing as "gravitational charge", according to General Relativity. The source of gravity is not mass, it is energy-momentum. That makes a technical difference. In the nonrelativistic case, gravity seems a lot like the electric field, but they are very different in the relativistic case.
Well, there is no consistency problem with invariance of charge.
I can't really make sense of them, but they seem to be motivated by a misunderstanding
of relativity theory. So it seems to me that it would be more productive for you to understand relativity better, rather than for me to understand your misunderstandings.
I wish that you could put your argument in a form that is a logical deduction of whatever contradiction you think you've discovered. I didn't see a contradiction in anything you said. For a black hole with charge, the charge Q is equal to the sum of all the charges that have fallen into the black hole. The mass M is not equal to the sum of all the masses that have fallen in, because mass is not conserved, while charge is. But what do you think is contradictory about that?
That's really not correct. Charge is not affected by being dropped into a black hole.
I apologize if my response was a little grumpy. I guess I'm being a little impatient. I guess I should read what his been said more carefully before replying.
Q-reeus said:
1: Matter of proper mass m gently lowered towards the EH reduces in coordinate measure as m' = fm, with f the usual redshift expression f = √(1-2GM/(rc2)). In keeping with that conservation of energy applies and work is being extracted in the lowering process. Now suppose that m also carries a charge q. it makes no difference to the net reduction in m as all forms of energy reduce the same. Locally there is no variation in the proper charge-to-mass ratio q/m. How can that local invariance of q/m (no free-fall case) not be also reflected as remotely observed - i.e. q' = fq? Certainly the locally invariant q/m will show remotely as a proportionately equally redshifted reduction in the Newtonian gravitational and Coulombic forces of attraction/repulsion between two adjacent such charged masses. The implication is obvious - as vanishes coordinate mass, so vanishes coordinate charge.
I guess the reason that I didn't respond specifically to this scenario is because it seems to start with a number of assumptions that I don't think are true at all. First, what does it mean to say that when you lower a mass, it "reduces in coordinate measure as m' = fm, with f the usual redshift expression". Where did you get that idea, that mass reduces by the redshift formula? I think that you are starting with an inconsistent notion of what GR says about mass.
Q-reeus said:
A balloon is tethered on a string to the centre of a large mat. Both are electrically charged with the same sign of charge - just sufficient to have the balloon float against Earth's gravity. For a distant observer, the mass of Earth and balloon are redshifted wrt to that locally observed
Where are you getting this idea that mass is redshifted? That doesn't make any sense to me.
If "mass" is interpreted to mean "energy at infinity", then it does "reduce" as described if you lower a mass slowly, by means of a rope, let's say, as opposed to letting it free-fall. I agree that "mass" is not a good term for this.
Let me explain:
1: A hydrogen atom is lowered into a deep gravity well. Then a photon of visible light is dropped onto the atom, which becomes ionized, although visible light does not normally ionize hydrogen. That happened because the field that keeps the atom together weakened as the atom was lowered.
2: A hydrogen atom and a photon of visible light are both gently lowered into a gravity well. Now the photon does not ionize the atom. The reason for this is that the electric field of the photon weakened as the photon was being lowered, as did the electric field in the atom.
So a photon in a gravity well, observing an atom being lowered into the gravity well, will say that the force that keeps the atom together is weakenig, kind of like the charges in the atom were becoming smaller.
(if photon does not have an electric field, then replace photon with a EM-wave pulse) (photon can be lowered using a mirror lined elevator)
No, it happened because the photon was blueshifted as it dropped into the gravity well. A visible light photon emitted locally, at the same altitude as the atom, won't ionize it, so the field of the atom is not "weakened" at all according to local measurements. The difference that lowering the atom gently makes is that it is at rest deeper inside the well, so it "sees" the blueshift of the photon. To see why that's important, consider an alternate experiment where you let both a hydrogen atom and a visible light photon free-fall into the gravity well, in such a way that they meet up somewhere much deeper into the well than where you released them (you time the release of the atom and the photon from your much higher altitude to ensure this). Will the photon ionize the atom? No, because the atom is not at rest in the field; it is falling inward at a high speed, so there is a large Doppler redshift when it absorbs the photon that cancels the gravitational blueshift.
No, the reason is that, by hypothesis, the photon of visible light did *not* blueshift, because it was "gently lowered" instead of being allowed to free fall. (Actually, I'm not sure how you would "gently lower" a photon. What do you do, attach a rope to it? But for purposes of a thought experiment I'm fine with assuming you can somehow do it.)
Well this is what I think:
A person that has spend some time in a deep gravity well will be observed having aged abnormally slowly, after he has been winched up from the well. He has produced some EM-waves by waving his slightly charged hands. Not very many EM-wave crests have been observed outside the gravity well, and the person does not report that he waved his hands very many times.
So the EM-waves that came up from the gravity well had just a few wave crests, because the person waved just a few times. And this is the reason the EM-waves that came up were slowly waving waves: Few crests during a long time, because of the slowness of the wave source.
The waves become longer at higher altitude, because light moves faster at higher altitude.
The case of free falling atom and photon I have to think about a bit.
I would not describe that situation with the terminology "Mass is reduced according to the redshift formula". I would say, rather, that if you extract energy from a system, then the total energy of that system becomes smaller. There's nothing surprising about that. In a situation in which energy is being extracted, but charge is not, I don't understand why anyone would believe that the ratio Total Energy/Total Charge would remain constant.
jartsa said:
Let me explain:
I don't think that's a very good explanation at all. I would not say that "the field that keeps the atom together weakened."
Look, the same thing happens in Newtonian gravity. If I throw a small stone at a car, it won't do much damage. But if I drop that stone from a great height, it can do a lot of damage. I would not describe this as "the forces holding the car together get weaker when the car is deep in a gravitational well".
The only meaningful notion of the "strength of forces holding an object together" is what you measure at the object, in the (local) inertial frame in which the object is at rest. That is not changed by dropping the object into a deep gravitational well.
What changes between high in the well and lower in the well is the translation of vectors. A velocity vector that is a small velocity high up in the well translates to a much larger velocity deeper down.
Of course, General Relativity understands gravity in a different way than Newtonian physics, but in neither case is it appropriate to say that "forces holding an object together get weaker when the object is lowered in a gravitational field".
General Relativity is about curved spacetime. There are two different ways to think about curved spaces, and each is useful for different purposes. The first way is to use curvilinear coordinates. For example, on the surface of the Earth, you can use longitude and latitude as coordinates. This is convenient, except that there are some weird effects: For example, in terms of longitude, objects at the North Pole seem "stretched out" compared with the same object near the equator, because the same object can cover more lines of longitude. Another effect is that if a plane attempts to fly as straight as possible, his path in terms of latitude will look "curved"; the shortest path from Montreal to Seattle is not to fly straight west, but to go northwest half the trip and southwest the second half.
An alternative way of thinking about curved spaces is in terms of gluing together lots of approximately flat spaces. Imagine taking the surface of the Earth and breaking it up into lots of triangles of size 10 miles on a side. Now, within each little triangle, Euclidean geometry works fine. Straight lines look like straight lines on a map for that triangle. The "curvature" part is captured by how the various triangles are glued together. If a traveler leaves one triangle, you need to figure out which triangle he enters next, and what angle his trajectory makes in the second triangle.
So there is a "translation" process to translate vectors from one region of a curved space to another. In GR, a photon's momentum is a certain vector, that has to be translated when that photon moves from one region to another. That's what the redshift/blueshift formula is doing.
Nobody seems to know how the total energy of a falling rock changes. Obviously that energy that is responsible of car crushing does increase.
Light is more simple: When light enters a gravity field of a planet, the light slows down and the planet starts to move in the same direction as the light. So light loses energy when falling. Or as an extremely good aproximation the energy stays the same.
There was a long and technical discussion in this forum about the energy change of falling light, and those were the conclusion. The light losing energy is my own idea though.
So it must be the objects becoming weaker at lower altitude, which causes them to break more easily, when light from above hits them.
Hey I have one more scenario again: A charge in a gravity well is accelerated from 0 m/s to 100 m/s. Radiation energy is proportional to velocity change. As seen from higher altitude the velocity change was smaller than 100 m/s, and there is the reason why the radiation energy coming from the gravity well is smaller too.
Hi Q-reeus, I would not over-interpret the M and the Q as representing some particular mass or charge. I would think of them simply as parameters of the metric. The M term can include rest mass, energy (including energy in EM fields), pressure, stress, etc. And Q could be an E-field boundary condition at the edge of the manifold rather than some charged particles actually located in the manifold.
I'm ignoring your earlier posting #37 and later one in #41 (but accept the nice sentiments in #39), as it all hinges on getting right what you say here. Maybe you have already changed again - I say 'again' because in #22 there is "I was mistaken in my first response--allowing a dropping mass to do work does change the total mass/energy." - which was a seeming backflip from your earlier position, and amazingly you seem to have done another 180 and it's back to the original stance. [Stop press: just now read your #46. Evidently then you believe the energy gain/loss is to be considered a wholly delocalized affair - shared amongst the entire system more or less equally?] Then consider the following:
Suppose that mass/energy in a slowly lowered mass m is in the form of an unstable matter/antimatter doublet that self-annihilates and escapes entirely 'to infinity' as gamma rays. We surely agree that in escaping the gravitational potential well of central mass M, those rays - which carry all the energy tied up originally in m(r), are redshifted in coordinate measure. Annihilate the same matter/antimatter doublet out there in distant space, and obviously the gamma rays are not redshifted at all. This little experiment of the mind imo nicely indicates it is proper to consider the energy loss/gain in lowering/raising matter/energy of mass m(r) in a grav well as essentially confined to just that mass m(r) - provided m(r) << M. Unless that is one wishes to argue transporting matter/energy from a resting position at one potential to a resting position at another potential can be anything but a path independent process - assuming of course central mass M is taken as static. Again if one argues those gamma rays are not 'resting' just remember we are free to have them absorbed by nuclei in a massive block of matter etc. which then constitutes resting position.
You might also care to look again at the parallel-plate capacitor situation of last para in #24. We agree that locally, it only makes sense to ascribe energy loss (transfer of energy to higher up via electrical line) upon capacitor discharge to be confined essentially to the capacitor field-charge system, not say the planet of mass M as a whole. Again, haul the charged capacitor up to higher potential, then discharge. More power available - gained via the hauling process - and to be located in the capacitor field. It's only when masses are roughly comparable that delocalization/sharing becomes significant.
There has been some nitpickery over fine distinctions between mass and energy but let's recall the scenario 1: in #1 to which you have at least specifically addressed in #40 as quoted above - it's one of slow lowering. For which it's then perfectly appropriate to treat the mass/charge as momentarily resting at a given height. What then is the distinction between rest mass and total stress-energy? Sure there must be stress in the matter involved (it feels 'g' forces) and yes technically that comes under a different part of the stress-energy tensor contribution to total gravitating mass m(r). It will though be typically extremely small compared to the rest energy part, and anyway acts here simply as a scalar additive term. So can we please just take it that m(r) is inclusive of rest energy and stress without further fuss and ado?
Re your's and to some extent PeterDonis's criticism of jartsa over his description of atoms being 'weaker' further down. The local perspective is not the only legitimate one and from a coordinate viewpoint I would agree with his thrust. There is something similar in SR. A slab of dielectric lies immersed in an E field of a parallel plate capacitor. Both dielectric and capacitor are stationary in lab frame S', and E' there is below dielectric breakdown value. Now propel that slab to a relativistic velocity in S', normal to direction of E' such that in proper frame S of slab, E exceeds breakdown value and there is catastrophic failure and discharge. It is not legitimate to say that in S' the slab can be viewed as having 'weakened', since E has not changed in S'? Notice too that in jartsa's scenario if an atom spontaneously decays radioactively releasing a gamma ray, it is redshifted as seen from outside of potential well. That can legitimately qualify it as a 'weaker' atom with weaker internal EM and nuclear fields in my book - it's all a matter of pov.
There is a potential can of worms I'm uncovering or rather rediscovering in working through all the ways of looking at how mass, energy, momentum, field etc. should be evaluated in coordinate measure - more later. Maybe much later.
Interesting perspective there DaleSpam. A bit out of my league and maybe Peter is best one to comment further there. As you will be aware, my real focus is on logical reason for any external E for a BH. Cheers.
We agree on the actual observable results, so I can't say that this view is "wrong". But it seems to me that taking this view often leads you into confusion, because it keeps you from applying common sense reasoning to disentangle causes. You have objects that "look different" whey they are far away than they do when they are close up, but instead of taking the obvious route of attributing the differences to the effect of the spacetime in between, you insist on saying that some "intrinsic" property of the objects has changed. And this prevents you from adopting a simple method of distinguishing the two possibilities: look at what local measurements say about the objects in their new location.
A simple analogy: two people, A and B, are standing next to a cube, and both of them agree that it looks white. Now the cube is moved to the other side of the room, and both of them agree that it now looks red. A says that the cube must have "changed color"; B says no, something about the space between must be altering the light reflected from the cube, changing it from white to red. They both agree on how the cube looks, but they disagree on why.
In one sense, the difference between A and B is just a "difference in pov"; after all, they both agree on all the experimental results. But suppose they now ask their friend C, who is standing on the other side of the room next to the cube, what color the cube looks to him. C answers that it looks white. B says, "You see? The cube is still white, but something about the space between us is making its apparent color change." How can A respond? If he tries to claim that the cube somehow "really has" changed color, even though it looks white to C, the one standing right next to it, won't he seem foolish? Wouldn't it be more reasonable for A (and B) to look for something in the middle of the room that could be changing the color of the light from the cube--a large red filter screen, perhaps? They could even shine some white light from their end of the room and ask C how it looks to him, and find that it looks red. In short, they could apply standard scientific techniques to figure out the causes of what they observe.
You can see the analogy, I hope. Consider the hydrogen atom that's slowly lowered into the gravity well. An observer, C, right next to it will not be able to ionize it with visible light; he will find its ionization energy to be exactly what it was when it was far away from all gravitating bodies and that energy was measured locally. Now observers A and B, at a much higher altitude, emit visible light and find that it ionizes the atom. A claims that the atom has somehow "weakened"; but B says no, it must be something about the spacetime between that is altering the light. After all, C finds the ionization energy to be the same as always. Furthermore, if they ask C how the "visible" light they are shining down looks to him, he will say it looks like gamma radiation; so obviously something about the spacetime between is changing the light. This is all standard scientific reasoning, but of course if you refuse to avail yourself of it, you will continue to be confused by these types of scenarios.
I would agree with what DaleSpam said. It is true that you can measure M and Q by looking at the behavior of test objects at very large radii, as I described in an earlier post; but doing that does not commit you to any particular belief about "where" the "mass" or "charge" being measured is located. It just means you've measured global properties of the spacetime.
What do you mean by that? Explanations come in layers--you explain phenomena at one level by showing how it works in terms of a more fundamental description. Sometimes that more fundamental description itself can be explained in terms of even more fundamental laws, but sometimes it can't.
We know how the energy of a rock changes as it falls, in the sense that it is perfectly described by General Relativity. We don't know, in any deep sense, why GR is true.
No, that's a very poor explanation, in my opinion. The General Relativity explanation, as I suggested, is in terms of parallel transport of vectors, and that applies both to a rock falling and a photon falling.
That's a very misleading conclusion.
That's not what General Relativity says. What you're doing is taking the predictions of GR, and reinterpreting them according to a different model. There certainly can be two physical models that produce the same predictions (an example is Special Relativity and certain variants of aether theory), but talking in terms of forces getting weaker in a gravitational field is completely contrary to the General Relativity way of understanding gravity.
Curved spacetime can be thought of as taking a bunch of little regions of flat spacetime and "gluing" them together on the edges. Inside each little region, the laws of physics work almost exactly the same as they would in gravity-free space. The "curvature" comes in when you try to glue neighboring regions together. The vector corresponding to a slow-velocity rock or a low-energy photon in one region becomes a high-velocity rock or high-energy photon in another region.
It's exactly like trying to describe the surface of the Earth using flat maps. If each map only covers a small region of the Earth, say 100 x 100 kilometers, then you don't notice the curvature. But when you try to glue one map together with a second map, you will find that vectors don't precisely match up. A vector that is vertical on one map corresponds to a vector that is slightly tilted from parallel on the second map.
I don't think that's a very good description at all. To go from "the light from the event is red-shifted" to "the velocity change must have been slow" is very dubious.
Imagine light from some event (say, a charged particle accelerating) comes to you from two different directions; for example, suppose there is a very massive star, or black hole between the event and you, and the light can go around in one direction, or the other. When the light gets to you, the two images can have different amounts of redshift. You can't explain that in terms of weaker or stronger electrical forces down in gravitational well. The way to explain it is to realize that light has to travel from the event to your eyes. Depending on the path it takes, the light is changed by its journey.
This is a different type of scenario: the large relative motion between capacitor and dielectric is a local effect, not an "at a distance" effect. There is no "spacetime in between"; everything happens locally. Even if you make the capacitor and the dielectric each a light-year long, the local field at any point in the dielectric, in the dielectric's rest frame, can still be attributed to the "local" part of the capacitor; it doesn't have to be transmitted over a distance.
Maybe you don't know, but that doesn't mean nobody knows. If the rock is freely falling, then its total energy is constant; as it falls, it gains kinetic energy and loses potential energy, but the sum of the two remains constant. (Strictly speaking, this is only true in certain spacetimes, such as Schwarzschild spacetime, but that's general enough to cover what we've been discussing.)
Yes, that's the kinetic energy. The potential energy decreases by the same amount.
If this happens with light, wouldn't it also happen with the falling rock? Why would the two be different?
One could adopt a viewpoint in which both the rock/light and the planet moved; this is just the center of mass frame. But the planet is so much more massive than either the rock or the light that the center of mass frame is not measurably different from the frame in which the planet is at rest. So that's the conventional approximation. The description I gave of the rock's motion above was in that approximation; and in that approximation, the light also "falls" towards the planet in such a way that its total energy, kinetic plus potential, remains constant. A light ray's kinetic energy is proportional to its frequency, so as the light falls, it blueshifts; or if it's rising, climbing out of a gravity well, it redshifts.
The total energy, kinetic plus potential, stays the same. You have the kinetic energy backwards: it increases when falling and decreases when rising, just as a rock's does.
Do you have a reference? I think you must have misinterpreted something.
I agree that if you get work out of lowering a mass toward a black, then the total energy of the system (the black hole + the mass you are lowering) will be less than if you don't extract work from it. It's not correct to describe this as "mass is reduced by the redshift formula"--it's that expression that seems completely wrong.
At an informal level, the total energy of a black hole is equal to the energy you dropped into it, minus the energy you pulled out of it. The total charge of a black hole is equal to the charge you dropped into it.
I would say that it's a matter of trying to understand what you're saying. I would not say that dropping an electron into a black hole changes the mass of the electron. That's just a weird thing to say. Dropping an electron into a black hole changes the mass of the entire system, black hole + electron. Exactly how much the mass of the system is changed depends on how you lower the electron into the black hole. But I would not say that the mass of the electron changed. The definition of the mass of an electron is the total energy of the electron as measured in a local inertial frame in which the electron is at rest. That is not changed by lowering it into a black hole.
Yes, in general, energy is a function of an entire system. Mass is the energy as a measured in a frame in which the system is at rest (has zero total momentum).
Yes. The way I would say it is that the particle/antiparticle pair annihilate to produce a pair of photons with a characteristic frequency, as measured in the local rest frame of the pair. These photons then travel up out of their gravitational well and escape to infinite. Their frequencies are changed by their journey (according to the redshift formula).
Right.
No, I don't agree. When two particles annihilate, they produce two photons that go off in opposite directions. These two photons could have their paths warped by the gravity of a massive star or black hole, and then come back together. When they come back together, the two frequencies need not be the same. It doesn't make sense to attribute the difference in frequency to differences in the masses of the particles that produced the photons. Instead, the differences should be understood as a change in the momenta of the photons as they travel from where they are produced to where they are measured.
Parallel transport of vectors is certainly path-dependent. In general, you can't compute redshift by noting where the photons started from, you have to take into account the path taken by the photons.
You can certainly describe things using whatever coordinates you like, but you have to be careful not to attribute physical effects to artifacts of your choice of coordinates.
The relevant value of E is E as measured in the frame in which the dielectric is at rest.
That's a very bad way of looking at it, in my opinion. The insight that Einstein formulated as the equivalence principle is that in any small region of spacetime, most phenomena--the ticking of clocks, the decay of particles, etc.--work exactly the same as they would in the absence of gravity. The complexity comes in when you try to relate phenomena in one region of spacetime to phenomena in another region. That's where the technical tool of "parallel transport" comes into play.
Are you picking on me now Peter? :cry: We both agreed earlier that there is legitimately a reduction in mass/energy when matter is lowered into a potential well. And it shows remotely - the gravitational contribution felt 'out there' is not that owing to plugging in the locally observed proper mass but the redshifted coordinate value. Agreed?
