Is 'charged black hole' an oxymoron?
  • Context: Graduate
  • Thread starter Thread starter Q-reeus
    Black hole Hole
382 replies · 46K views
PeterDonis said:
This is a different type of scenario: the large relative motion between capacitor and dielectric is a local effect, not an "at a distance" effect. There is no "spacetime in between"; everything happens locally. Even if you make the capacitor and the dielectric each a light-year long, the local field at any point in the dielectric, in the dielectric's rest frame, can still be attributed to the "local" part of the capacitor; it doesn't have to be transmitted over a distance.
Actually there are other factors to consider in that case and I jumped in too soon (dielectric polarization field transformation, plus effect of motion through the induced magnetic field in S'. There is cancellation but it gets messy). A cleaner example would be: same capacitor and field E' in S', but now there is a charge q lying at the end of a cantilever arm - oriented mutually orthogonal to both E' and later applied relative velocity v. We suppose initially the arm, at rest in S' barely resists the force on q from E'. Now set it in relative motion such that arm breaks under higher E in proper frame S of arm+charge. In S' we attribute no higher force on q owing to v. How to explain breakage? To say the material has relativistically weakened seems about ok to me. There is imo this much commonality with gravitational case - situation is viewed from differing proper frames in both cases.
Q-reeus said:
Are you picking on me now Peter? :cry: We both agreed earlier that there is legitimately a reduction in mass/energy when matter is lowered into a potential well. And it shows remotely - the gravitational contribution felt 'out there' is not that owing to plugging in the locally observed proper mass but the redshifted coordinate value. Agreed?
I don't think it's appropriate to talk about mass being redshifted. You can talk about the frequency of a photon being redshifted, and maybe that's what you mean?
That seems like a very bad way of looking at it, in my opinion.
jartsa said:
I've read that thread, and I don't see how you got the following out of it:
jartsa said:
When light enters a gravity field of a planet, the light slows down and the planet starts to move in the same direction as the light. So light loses energy when falling. Or as an extremely good aproximation the energy stays the same.
There was no talk at all in that thread about the planet moving in the same direction as the light. You said the light losing energy when falling was your own idea, and indeed that's not in the thread either. Nor is the energy staying the same "to an extremely good approximation"; Jonathan Scott said that the frequency of the light stays the same, but he meant something different by "frequency", and he specified that that was relative to a particular coordinate system, the global Schwarzschild coordinates.
Let me try to summarize what the technical posts in that thread were actually saying. A photon emitted at a particular event in any spacetime will have a 4-momentum vector [itex]k^{a}[/itex] associated with it. Since photons travel on null geodesics, that 4-momentum vector will be parallel transported along the photon's worldline; this is the sense in which the photon "does not change" as it travels.
However, the observables associated with the photon are determined, not just by the photon's 4-momentum, but by geometric objects, vectors and tensors, associated with the observer. For example, the energy the photon is measured to have by that observer is the contraction of the photon's 4-momentum with the observer's 4-velocity [itex]u^{b}[/itex]:
[tex]E = g_{ab} k^{a} u^{b}[/tex]
So even if [itex]k^{a}[/itex] is unchanged as the photon travels, its observed energy can still change if either the metric [itex]g_{ab}[/itex] or the observers' 4-velocity [itex]u^{b}[/itex] changes. (We actually measure photon frequency, not energy, but the latter is just Planck's constant times the former.)
In the case of the standard Doppler shift, the measured energy (frequency) changes because the 4-velocity of the observer [itex]u^{b}[/itex] changes relative to that of the emitter, which determines the photon's 4-momentum [itex]k^{a}[/itex].
In the case of a photon falling into or climbing out of a gravity well, the energy (frequency) measured by static observers--observers who are "hovering" at a constant radius r--changes with r because the metric [itex]g_{ab}[/itex] changes. (The 4-velocity of "hovering" observers is the same at all r--all their 4-velocity vectors point "in the same direction".)
The "frequency staying the same" that Jonathan Scott was talking about was a different sense of "frequency": if I have a blinker, say, emitting flashes of light deep in a gravity well, such that it emits N flashes between Schwarzschild coordinate times t = 0 and t = 1, then an observer much higher up in the gravity well will also count N flashes between coordinate times t = 0 and t = 1. The two observers will differ in how much *proper* time they experience between those two coordinate times, so they will assign a different proper frequency (flashes per second of proper time) to the blinker; but the frequency relative to *coordinate* time is the same. This is all consistent with what I said above.
I agreed that there was a reduction in *energy at infinity*, because you are extracting work during the lowering process. But if you measure the rest mass of the object locally, you will get the same answer after it has been lowered as before.
Yes, but that doesn't mean what you think it means. :devil:
Taking on board your comments in #59 and what I just read in #63, it seems we just have fundamentally different outlooks in matters discussed and best to just agree to disagree methinks. Have a nice day.
Okay, but I think that you are deeply confused about these topics, and you are interpreting your confusion as a contradiction in General Relativity. The contradiction is in your own head.
Peter - where did your last post go - I so looked forward to saying 'gotcha'!
If you are right that there is higher E in frame S, so that the force on q is higher in frame S, then it must be higher in frame S' as well. The force on q, meaning the proper acceleration it experiences times its rest mass, must be invariant. Instead of waving your hands, you should actually do the calculation.
See my new post; somehow "submit" got clicked while I was still thinking it over.
Easy - 3-force F = qE in both frames (using appropriately transformed values for E naturally). The magnetic field seen in S exerts no force on q there, and there is no B field in S'. It is a fact motion of charge at any speed through a given fixed E field of any orientation has no effect on the 3-force on moving charge in that frame. Accelerations are a different matter. And ipso facto, transverse 3-force component is frame variant. You should be very familiar with SR 3-force transformation relations - only the force component parallel to relative velocity is frame invariant wrt v. Now when it gets to 4-vectors etc I get crossed eyes, but the 3-force stuff I do know here. I stand by previous 'relativistic weakening' comment as a legitimate viewpoint on that basis.
Exactly--*transformed* values for E. Which means your notation is obscuring the physics.
Adopting a better notation, define "E" as the electric field in the rest frame of the capacitor. Then, if gamma is the Lorentz gamma factor due to velocity v, the velocity of the charge q relative to the capacitor, then the electric force on q is F = q * gamma * E in the rest frame of the capacitor. If we transform to the rest frame of q, then E' = gamma * E and the force on q is F' = q * E' = q * gamma * E, i.e., the same actual, physically measured force calculated in both frames.
So the reason the arm breaks when it's in motion relative to the capacitor, instead of at rest, is that the electric force on q, and hence the force on the arm, is higher when q is in motion relative to the capacitor. No weakening of the arm at all.
Sorry Peter - your turn to experience a brain snap it seems. I've given up finding a website explicitly dealing with the type of scenario discussed here, but not needed. Lorentz force law F = qE + vxB is quite explicit - if there is no applied B field present, the purely electric force in a given frame is thus totally independent of the charge velocity in that frame. Basic stuff. Yes as we both agree the force is higher in the rest frame of q when set in motion relative to the capacitor. But transverse 3-force and transverse E field transformations cancel each other out such that, in keeping with vanilla Lorentz force expression, force in a given frame has no input from v there (zero applied B field) - period. To ease your pain a little, let me make a confession. Remember that ongoing thread about shell metric transition? Well guess what - I lately came to realize I was mistaken and standard SC's do not after all imply any unphysical jumps in radial metric - at least to first order locally observed. But then it was a certain someone's earlier erroneous claim that got me started on that wrong track in the first place...:devil: Must go. :zzz:
Q-reeus said:
As you will be aware, my real focus is on logical reason for any external E for a BH.
I am not sure exactly what the source of the logical concern is, but maybe this will help clarify the real point of disagreement. I know that you are not into the math, but do you understand what is meant by the term "boundary condition"?
If you do, then you can simply take the EM field just outside the event horizon (on the edge of the Scwarzschild coordinate chart) as a spherically symmetric boundary condition. Then the question is: what is the EM field and the spacetime curvature in the rest of the chart? The EM field is given by Maxwell's equations and the curvature by the Einstein field equations. The two sets of equations are coupled due to the fact that the EM field has its own stress-energy tensor. The solution to the EFE is the RN metric which is described by two free parameters.
Do you see any of that as illogical? If not, then it seems that the only real question is under what physical conditions the boundary conditions can arise. Basically I am trying to "localize" the disagreement to inside or outside the EH.
That's the non-relativistic approximation; it only holds if v << c. The correct relativistic law can be found in many places, for example the Wikipedia page:
http://en.wikipedia.org/wiki/Lorentz_force#Relativistic_form_of_the_Lorentz_force
As you will see, there is a gamma in there, just as I posted.
Nope--see above. Also, after looking at how the EM field tensor transforms, I'm no longer sure the induced B field due to the motion of the charge q relative to the capacitor has no effect on the force observed, but I'll save that for a separate post.
Thanks for the feedback, but as you can see from the above, I don't need any consolation for this discussion. :wink:
Also, that "to first order locally observed" is not strong enough: there are no "unphysical jumps" to any order. Seems like you still have a bit of thinking to do. :devil:
False alarm--I was forgetting that, even though in the rest frame of the charge there is an induced B field (because that frame is moving relative to the capacitor), the charge is not moving in that frame, so the v x B term is zero anyway. Move along, nothing to see here. :redface:
stevendaryl said:
Imagine light from some event (say, a charged particle accelerating) comes to you from two different directions; for example, suppose there is a very massive star, or black hole between the event and you, and the light can go around in one direction, or the other. When the light gets to you, the two images can have different amounts of redshift. You can't explain that in terms of weaker or stronger electrical forces down in gravitational well. The way to explain it is to realize that light has to travel from the event to your eyes. Depending on the path it takes, the light is changed by its journey.
Nope. There is a certain potential difference between two points. You plug that into some equation, and out comes certain redshift. I mean, redshift is determined by gravitational potential difference.
Well, "frequencies" and frequencies must stay proportional. Probably that was the point of the talk about "frequencies" there in the other thread. So frequencies stay constant, because "frequencies" stay constant.
But the constant of proportionality changes as the metric changes. In the case of a gravity well, the constant of proportionality changes as you go deeper into the gravity well. So "frequencies" in the sense Jonathan Scott used the term in the particular post I referred to stay constant, but frequencies in the sense of local measurements do not.
Well, anyway frequency of a falling photon cannot increase, because it decreases slightly. When a fast moving object (photon) hits a still standing object (black hole) the kinetic energy of the still standing object increases, so the kinetic energy of the photon must decrease.
The reasoning you are about to give is incorrect (see below), but even if it were correct, it would certainly not apply while the photon is still above the hole's horizon. As it "falls" in that region, its frequency as observed by static observers (observers who maintain a constant altitude) increases. This has been experimentally measured; see, for example, here:
http://en.wikipedia.org/wiki/Pound–Rebka_experiment
The above reasoning is incorrect. A photon will not "hit" a BH; it just falls into it. A BH is not a "still standing object" in the sense you are trying to use the term here. It is better to think of the BH as a region of spacetime with properties very different from what we can intuitively picture.
No, that is not true. It is true in a static, symmetric case (black hole), but it isn't true in general. If a photon passes near a massive object that is itself moving, the photon can pick up additional energy, in exactly the same way that the slingshot effect can send a space probe shooting out of our solar system.
In general, two different photons that start off identical, and take different paths can have different frequencies.
PeterDonis said:
No, it happened because the photon was blueshifted as it dropped into the gravity well. A visible light photon emitted locally, at the same altitude as the atom, won't ionize it, so the field of the atom is not "weakened" at all according to local measurements. The difference that lowering the atom gently makes is that it is at rest deeper inside the well, so it "sees" the blueshift of the photon. To see why that's important, consider an alternate experiment where you let both a hydrogen atom and a visible light photon free-fall into the gravity well, in such a way that they meet up somewhere much deeper into the well than where you released them (you time the release of the atom and the photon from your much higher altitude to ensure this). Will the photon ionize the atom? No, because the atom is not at rest in the field; it is falling inward at a high speed, so there is a large Doppler redshift when it absorbs the photon that cancels the gravitational blueshift.
Hey now think I have thought about it plenty enough.
1: Let's consider photon gas in a mirror lined elevator that is going down at constant speed. Photons redshift when bouncing from the floor, and blueshift when bouncing from the ceiling. A photon that moves upwards along a gently sloping path will be deflected downwards by the gravity, before it hits the ceiling. Therefore there is a net redshift of the photon gas, and the force that the gas exerts on the walls is decreasing.
2: Let's consider photon gas in a mirror lined elevator that is free falling. No gravity is felt in the elevator, so no net blue or redshift of the photon gas happens, and the force that the gas exerts on the walls does not change.
In case 1 the radiation weakens, so we can conclude that the atoms of the elevator weaken equally.
In case 2 radiation does not change, so we can conclude that the atoms of the elevator don't change either.
In this case you are extracting energy from the system--you have to, to keep it from freely falling. Since you're modeling the photons as a gas, that means you are decreasing the temperature of the gas. There's no "weakening" of the atoms in the elevator; they stay the same, because the forces that hold them together don't depend on temperature.
(Strictly speaking, the temperature of the elevator walls will decrease as the photon gas temperature decreases, which means the atoms will be jiggling around less energetically. But that only affects the motion of the atoms as whole atoms; it doesn't affect the internal binding energy of the atoms that holds them together.)
Here you are not extracting any energy from the system, so of course the temperature of the photon gas stays the same. Again, that has nothing to do with whether or not the atoms are "weakening".
Generally. Like in EM where we say specify the vanishing of tangent E field component at a conductor surface etc. But impression is 'boundary condition, can get rather abstract in GR.
I understand in broad outline your point. My point is that maybe improper assumptions have been made in coupling the two, and gedanken experiments in #1 and subsequently are intended to be taken as potential counterexamples to be carefully thought through. Apart from dealing with a side issue here, what currently looks like a confusing mess getting full consistency working in SC's needs sorting out and haven't devoted much time to that.
Well if we take the view charge has fallen onto the EH of a previously neutral BH, there it asymptotically exactly resides in 'frozen free-fall' from coordinate perspective. And it's from coordinate perspective 'charged BH' is supposed to make sense ('Inside' EH is essentially a meaningless concept imo). Which boils down to, as said times earlier, implying infinite redshift at EH has no effect - exterior E is as though no BH is swallowing the infalling charged matter. Hence my take in example 3: in #1, and the others there. Maybe that clarifies a little more. Before it was moved, I argued in the earlier thread this one forked off from, on the matter of whether from virtual photon view things made any better sense, but probably best to entirely avoid that angle here.
You are referring no doubt to the *covariant* expression for Lorentz force in vector form shown on that Wiki page as:
dp/dtau = qγ(E+uxB) - (1),
and claiming it represents the 'relativistically corrected' version of the usual 'low velocity' expression:
dp/dt = F = q(E+uxB) - (2),
that is somehow only an approximation. I'm flabbergasted! Check the vector expressions earlier in that Wiki page, or any reliable articles such as:
http://arxiv.org/abs/1205.1080
web.mit.edu/sahughes/www/8.022/lec10.pdf
The usual 'low velocity' expression (2) is in fact exact and good for any velocities whatsoever. Provided it is applied as intended. Forces, fields and velocities all evaluated in the one frame they appear. Notice I used dp/dt = F in (2) - not dp/dtau. Important difference. No wiggling out that non-covariant expression (2) was clearly the form being discussed earlier!
My sole error in #73 was of the typo type - forgetting to use parenthetic enclosure around both E and vxB rather than the qE+vxB as shown. Pardon my oversight, but the pertinent issue is whether your 'relativistically corrected' version with the added gamma factor is right as you interpret it - to be applied directly to the E field and charge velocity appearing in the capacitor rest frame. Stop and think what that would mean. Action and reaction would be out the window, as would conservation of energy. Why bother to build huge superconducting magnet array monsters like at Cern LHC, when a simple bank of capacitors with holes in them would accomplish the task far better! Do I need to supply yet another gedanken arrangement or two to illustrate the truth of that? To again ease your pain, I promise not to use here the following smarty smiley's - :-p :devil::-p:rolleyes::smile::rolleyes:. Promise!
So what is the correct usage for expression (1)? To be honest, not being conversant with covariant formulations, I'm at a loss. Appears to quite simply yield the proper force dp/dtau - as seen in the moving charge's rest frame, in terms of the lab frame E, B, and u parameters. Trouble is, it just can't work in general on that basis. For example no proper force gamma factor applies for an E field component parallel to u, and that's simply not represented in (1), where implicitly all components are operated on equally. Hmmm.
Still sure about that? :smile:
Maybe - but enough said for now.
It's true that dP/dt = q (E + 1/c v x B) is the nonrelativistic form of the Lorentz force law, but that doesn't mean that it's an approximation.
The relativistic form is
dPα/dτ = q Fαβ Uβ
where τ is proper time.
Using U0 = γ
Uj = γ vj
F0k = Ek
Fij = Bk
this implies
dP/dτ = q γ (E + v x B)
But d/dτ = γ d/dt, so this becomes
γ dP/dt = q γ (E + v x B)
or
dP/dt = q (E + v x B)
So the latter is exactly equivalent to the relativistic form, not an approximation. The factors of γ cancel.
Well, in general physics is described by a class of equations known as differential equations. The differential equations, by themselves, cannot be solved. In order to solve them you must also include a set of conditions, known as boundary conditions. The boundary conditions describe the physical situation that is being modeled, and the differential equations then describe how the physical laws make that situation evolve.
So, for example, Newton's 2nd law: [itex]f=mx''(t)[/itex] and Newton's law of gravitation: [itex]f=G m_1 m_2/r^2[/itex] govern the motion of projectiles in vacuum. However, by themselves they cannot tell you where a given projectile will land. For that, you need to specify the initial velocity and initial position, which are the boundary conditions describing a particular projectile. Once you do that you can solve the system of differential equations and boundary conditions together to make specific predictions about a given projectile.
So, in this scenario the differential equations of interest are the Einstein field equations and Maxwell's equations. The boundary conditions could be a spherically symmetric E-field at some specified radius outside of the EH (represented by Q), and the spherically symmetric spacetime curvature at some specified radius outside of the EH (represented by M). The differential equations can then be solved together with those boundary conditions to determine the curvature and E-field at other locations.
I will see if I can dig up a derivation and then we can take a direct look at the assumptions and see if any are indeed improper or doubtful.
I understand that you want to work in Schwarzschild coordinates, and I agree that inside the EH is meaningless in those coordinates. That is a known limitation of Schwarzschild coordinates, but there is nothing wrong with using them as long as you stick to regions of the manifold where they are not meaningless. To do so, we can just specify the field at some radius outside the EH as the boundary condition and not worry too much about how it got there. E.g. we can suppose, if we like, that we are simply dealing with the fields outside a uniformly charged spherical planet rather than a BH.
Once we agree on the physics outside a charged planet then we can discuss the BH case.
If I interpret the two equations as you've just said, they say the same thing:
dp/dtau = dt/dtau dp/dt = gamma dp/dt
Which is fine; if by "force" you just mean the "coordinate force" dp/dt, then you're correct, the equation you wrote is always valid, because it's just a different way of writing the equation I wrote, a way which makes the relativistic covariance more obscure.
The question is, what do we actually measure? The answer is, we actually measure dp/dtau. That's what, for example, a strain gauge attached to the arm that is holding the charge q in place would read. And that observable has to be invariant; it can't be frame dependent, because it's a direct observable. The reading on the strain gauge attached to q can't depend on which frame we decide to calculate it in. I thought that by "force" you meant the actual measured force, the force the strain gauge would read, which is why I thought your version of the force law was incorrect. You're right, it's not incorrect; it just doesn't mean what you think it means. :rolleyes:
Indeed. Try the most general covariant version, using the EM field tensor, which appears in the Wiki article (I'm giving it in a slightly different form which will be easier to work with):
[tex]\frac{dp^{a}}{d\tau} = q F^{a}_{b} u^{b}[/tex]
This equation is valid in any frame, so you can just read off the frame-dependent versions by transforming the tensor components and the 4-velocity appropriately.
For example, in the rest frame of the capacitor, we have [itex]F^{0}_{1} = F^{1}_{0} = E[/itex], with all other EM field tensor components zero. We also have for the 4-velocity of the charge q [itex]u^{b} = (\gamma, 0, \gamma v, 0)[/itex]. We have oriented the spatial axes so the capacitor's field is in the "1" direction and the charge is moving at velocity v in the "2" direction (perpendicular to the capacitor field, as was my understanding).
The only nonzero component of the above equation is the "1" component of the 4-acceleration:
[tex]\frac{dp^{1}}{d\tau} = q F^{1}_{0} u^{0} = q E \gamma[/tex]
which is what I wrote. And, of course, we can obtain what you wrote by just writing dp/dt = dtau/dt dp/dtau, which removes the factor of gamma.
Now do the same thing in the rest frame of the charge q. Obviously the 4-velocity is just [itex]u^{0} = 1[/itex] in this frame, all other components zero. But perhaps it's worth writing out the Lorentz transform of the EM field tensor explicitly, since you actually have to transform twice because the tensor has two indexes. And because we're using the "mixed" form of the tensor, with one upper and one lower index, we need two versions of the transform, one for each kind of index. I haven't found a good online reference for all this, but it's in the textbooks (I'm working from MTW).
A given EM field tensor component transforms like this (indexes are primed or unprimed according to which frame they refer to):
[tex]F^{a'}_{b'} = F^{c}_{d} \Lambda^{a'}_{c} \Lambda^{d}_{b'}[/tex]
where repeated indexes are summed over, and the two transformation matrices are (you do have to keep careful track of which indexes are primed and which are unprimed):
"Forward" matrix (primed upper index):
[tex]\Lambda^{0'}_{0} = \Lambda^{2'}_{2} = \gamma[/tex]
[tex]\Lambda^{0'}_{2} = \Lambda^{2'}_{0} = - \gamma v[/tex]
[tex]\Lambda^{1'}_{1} = \Lambda^{3'}_{3} = 1[/tex]
"Inverse" matrix (unprimed upper index):
[tex]\Lambda^{0}_{0'} = \Lambda^{2}_{2'} = \gamma[/tex]
[tex]\Lambda^{0}_{2'} = \Lambda^{2}_{0'} = \gamma v[/tex]
[tex]\Lambda^{1}_{1'} = \Lambda^{3}_{3'} = 1[/tex]
If you take each of the above matrices individually, and work out how it acts on a vector, you will see that it's saying the same thing as you're used to with Lorentz transformations: x' = gamma (x - vt), t' = gamma(t - vx), etc., with the sign of the v terms switched for the inverse matrix.
Now we need to apply the matrices to the tensor components as shown above. This looks like a lot, but if you work through the possible combinations of indexes, you will see that there are only four nonzero components of the primed EM field tensor: [itex]F^{0'}_{1'} = F^{1'}_{0'} = \gamma E[/itex], and [itex]F^{1'}_{2'} = - F^{2'}_{1'} = \gamma v E[/itex]. The first two terms correspond to an electric field in the "1" direction, as before, but now you can see that it is stronger, in "coordinate" terms, than it was in the rest frame of the capacitor, by a factor gamma. The last two terms correspond to a magnetic field in the "3" direction, i.e., perpendicular to both the electric field and the relative velocity of the charge and the capacitor. This is what you're used to seeing written out, in 3-vector form, as v x E.
Now read off the force in the primed frame from the index equation above; you will see that there is again only one nonzero component, that for the "1" component of the 4-acceleration:
[tex]\frac{dp^{1'}}{d\tau} = q F^{1'}_{0'} u^{0'} = q \gamma E[/tex]
which is the same number as in the other frame. So the observable quantity is the same in both frames, as required.
But you could "interpret" the two equations differently. You could say that, in the rest frame of the capacitor, the "E field" is just E, and the "coordinate force" on the charge q is qE, but to obtain the observable number, the "4-force", you have to multiply by gamma to convert dp/dt to dp/dtau. Whereas, in the rest frame of the charge, the "E field " is already gamma E, so dp/dt and dp/dtau are the same (because t = tau for the charge in its own rest frame). This is all just "interpretation" and doesn't change the physics.
What you *can't* do is say that somehow the "real force" is different in the two frames, because that leads you to a false prediction: it leads you to predict that the reading on the strain gauge would differ depending on which frame you calculated it in.
Yes, I saw that when I realized that by "force" he meant the "coordinate force", dp/dt, not the actual observed force, dp/dtau. See my post in response.
