Mentor
- Messages
- 51,193
- Reaction score
- 27,210
PeterDonis said:I'm not sure this analogy holds; I'll have to take a bit of time to consider the rotating scenario.
I've thought about this case some more, and I'm still not sure the analogy holds.
To simplify things somewhat from the "beams inside a synchrotron" scenario, suppose we have a single object of charge q inside a sort of circular capacitor, which I'll call the "ring" for brevity: a device that can create an electric field directed radially. We put the charged object at the end of a massless arm that runs on a track on the inside surface of the ring. The arm holds the charged object at a particular radius r, which is between the inner radius r_i and the outer radius r_o of the ring. The whole thing is floating in free space (flat spacetime).
Our two observables are, again, a scale under the track (O) and a strain gauge on the arm (O').
First, we consider the case where the q+arm assembly is at rest relative to the ring. We turn on the capacitor and find that the scale and strain gauge show nonzero readings. Call this set of readings A. We expect the readings to be equal: O_A = O'_A.
Now we set the q+arm assembly to rotating around the ring with constant angular velocity omega, and therefore constant relative speed v relative to the ring (but with changing direction). At a given instant, we can set up two local inertial frames (MCIFs): one in which the ring+track is at rest and the q+arm assembly is moving at speed v in a direction orthogonal to the E field generated by the ring; and one in which the q+arm assembly is at rest and the ring+track is moving at -v in a direction orthogonal to the E field generated by the ring.
It seems to me that, locally, these two inertial frames are the same in almost all respects (I'll elucidate that "almost all" in a moment) as the two frames in the straight line case: the rest frame of the charge q, and the rest frame of the capacitor. There is one key complication, though; in the rotating case, there is no longer an exact "force balance" in both frames, because the motions are no longer unaccelerated; the instantaneous relative velocity of the two is orthogonal, but the instantaneous acceleration of q+arm is not zero, it has an inward radial component.
This, to me, means we can't draw an exact analogy between the two scenarios, because we no longer have an exact force balance in the direction of the E field. The reasoning that led to O = O' depended on there being an exact force balance. So I don't see the two cases as analogous.
