Is Consciousness Beyond Physical Explanation?
  • Thread starter Thread starter Q_Goest
Are you a dualist?
  • Total voters
    33
246 replies · 38K views
Q_Goest said:
That's primarily a religious definition of dualism.
I didn't say "A dualist thinks He is the one controlling his body and mind". So no. I don't think its a religious definition. Its just a natural thought process expected from a dualist. The non-physical component of the situation is just the person's consciousness. Attributing another unrelated non-physical component does not bring about much of a difference between that and the 'almost-physical' gravitational force acting upon us.
If my experiences are going to be governed by a third party, I won't give a damn whether its physical or non-physical. I'd just hate it!
If we can't explain it in physical terms, then some kind of dualism seems appropriate.
The mistake obvious in this argument and other related posts of yours is that we don't yet have a complete idea about this 'physical' thing itself. Aren't we being impatient here to change tracks and look at ad-hoc non-physical theories?
As a speculative idea, it can be considered that, possiblly the conscious mind does actually have some role in the making of decisions for an organism. That is, we can consider that "mind" is something that at higher levels of complexity in organisms emerges as a means to simplify or more efficiently make decisions for adaption. Something like once the organism gets to a certain level, the synthesis of the various relevant elements of "the external" into a coherent subjective representation enable the organism to make abductive inferences and accurate analagous jumps to situations. It may seem to serve beneficial for organisms who have a more active lifestyle where in their everyday environment they encounter many changes and challeneges and a quick response is needed. Which is essentially learning and associative learning, so maybe conscious representation is tied to the learning process in some way, at some level.
I haven't read through the whole discussion, but from what you mentioned about the phenomena that can not be explained by physical means, take smelling a rose for instance: Some compound in the flower diffuses into the air and finds its way into your nose. Then it binds with some sort of receptor in your nose and the result of that is converted into an electrical signal.
Now, because of the uniqueness of the molecule that causes the rose to smell like a rose, a certain response is triggered in your brain. This response causes some other chemical to be released into your brain which has a characteristic effect. The overall effects of this chemical released into your brain is what is characterised as the 'rose smell'. Thus, whenever the same chemical(s) are released into your head, you remember the rose smell and categorise it as such.
What aspect of this process cannot be explained on the basis of physical means? There is no dualism.
Qualia aren't explained by explaining the physical process. There is no need to resort to describing qualia when describing a physical process. Furthermore, describing the physical process leaves something out. Why should any physical process be accompanied by an experience of it? And why only certain physical processes?
Just to make the issue that much more difficult to explain, if the process is merely a physical one, how can qualia be reported at all? (see Knowledge Paradox as discussed earlier in one of my posts).
Q_Goest said:
Note that we're not talking about explaining the configuration or physical state of the brain - that's not good enough.
We use fluid dynamics to describe the behavior of gases. However, we also have the kinematic description of gases as being a big collection of molecules bouncing around.
How analogous is this to what you vision dualism as?
Insert standard charge of "explaining" as a loaded term.
What follows seems more like a denial of the standard methods of analysis and synthesis than actually arguing any particular point.
Whether true or not, what is the point of this assertion? (it is a little awkward -- maybe what was said isn't what was meant?)
For example, the fact we can talk about frequencies and superpositions of photons without referring to subjective human experiences does not imply it is useless to do so. In fact, it is particularly useful when applied to the task of designing televisions and computer monitors. And it is useful studying both from the bottom-up (doing the physics and chemistry to predict how combinations of photons will trigger cones and rods to produce visual experiences) and from the top-down, using human feedback to validate and calibrate models for producing color.
Why?
This charge is levied against all sorts of analyses. Most of the time, it comes from people who have made no attempt to connect the analysis to an understanding of what is being analyzed. Should I think differently of this particular charge?
A fairly meaningless question. You might as well ask "Why should electrons repulse each other?"
Or "why isn't mass attracted to electric charge?"
Fairly easily, if qualia are a physical process.
The analogy doesn't hold. Both descriptions are descriptions of the dynamics of 'stuff' whether that stuff be modeled as balls bouncing around, Navier Stokes equations, or some other description. They are all objectively verifiable descriptions of a phenomenon that can be described in various ways.
The wing flutter example is the same, it can be described in various ways (at the molecular level or at much higher levels).
What aspect of your argument for dualism fails to apply to the kinematic description of gas? Or to the case of wing flutter? What, aside from the conclusion, is different, and what is the same?
Most of the objections to dualism here tend toward an appeal to new physics. We’d like to think there is a physical explanation for everything. Conscious experience however, is the only phenomenon I’m aware of that resists any reductive explanation. Rather than explain again in my own words, I’ll use those of David Chalmers:
Sometimes it is held that the key to the explanation of consciousness may lie in a new sort of physical theory. Perhaps, in arguing that consciousness is not entailed by the physics of our world, we have been tacitly assuming that the physics of our world is something like physics as we understand it today, consisting in an arrangement of particles and fields in the spatiotemporal manifold, undergoing complex processes of causation and evolution. An opponent might agree that nothing in this sort of physics entails the existence of consciousness, but argue that there might be a new kind of physical theory from which consciousness falls out as a consequence.
It is not easy to evaluate this claim in the absence of any detailed proposal. One would at least like to see an example of how such a new physics might possibly go. Such an example need not be plausible in the light of current theories, but there would have to be a sense in which it would recognizably be physics. The crucial question is: How could a theory that is recognizably a physical theory entail the existence of consciousness? If such a theory consists in a description of the structure and dynamics of fields, waves, particles, and the like, then all the usual problems will apply. And it is unclear that any sort of physical theory could be different enough from this to avoid the problems.
The trouble is that the basic elements of physical theories seem always to come down to two things: the structure and dynamics of physical processes. Different theories invoke different sorts of structure. Newtonian physics invokes a Euclidean space-time; relativity theory invokes a non-Euclidean differential manifold; quantum theory invokes a Hilbert space for wave functions. And different theories invoke different kinds of dynamics within those structures: Newton’s laws, the principles of relativity, the wave equations of quantum mechanics. But from structure and dynamics, we can only get more structure and dynamics. This allows the possibility of satisfying explanations of all sorts of high-level structural and functional properties, but conscious experience will remain untouched. No set of facts about physical structure and dynamics can add up to a fact about phenomenology.
Chalmers, “The Conscious Mind” pg. 118
Hurkyl said:
What aspect of ... dualism fails to apply to the kinematic description of gas? Or to the case of wing flutter? What, aside from the conclusion, is different, and what is the same?
I think what you're asking is, why isn't phenomenal experience analogous to pressure or temperature of a gas or wing flutter in the same sense as a description of the physical state of a brain analogous to the description of the physical state of the molecules - in the gas; or the air flowing over the wing and molecules in the wing of an aircraft? Why isn't phenomenal experience just a 'shorthand' way of describing a brain's physical state? If that's your question, the answer below applies.
In short, it is taken as fact that phenomenal experience is subjective and not objective. Qualia are not phenomena that can be measured objectively. If you have nothing to measure other than the physical states of material things, we have everything we need to produce various descriptions of nature at various levels (such as descriptions of gases like pressure or temperature; or wing flutter), but nothing to describe that which we can't measure. The property of what we experience when we experience the color red for example, is not a property of some wavelength of light that's being captured by our eye. Red isn't a property of stop signs or fire trucks. It is a property that our brain creates that is not objectively measurable. Sure, we can claim it corresponds to a given physical configuration, but we can't claim that the physical configuration thus described (in any way we want to describe it) will give us even a glimmer of hope in understanding what the property of red is that we experience. We can't reduce qualia to the physical constituents on which the experience is had (on which it supervenes).
As far as the experience of it goes, you've been subjected to a wide variety of experiences over the course of your life, ever since you were an infant. The various experiences and the reactions that you've had to them have been categorized in your brain. So, whenever you have an experience that is similar to one you've already had, it is easier for you to categorize it. On that basis, you can explain observations like the color red, what you think of music, the taste of the foods you like etc.
I think, the only thing that you can not explain on purely physical phenomena is creativity and the origin of ideas and the miracle of life. There is a boundary beyond which science is slightly helpless, but it isn't restricted by the experiences you have.
Q_Goest said:
I think what you're asking is, why isn't phenomenal experience analogous to pressure or temperature of a gas ...
That is not my question. I'm not asking about arguments that have dualism as a hypothesis -- I'm asking about arguments that have dualism as a conclusion.
Why, for example, doesn't one insist that reducing a gas to a physical arrangement of molecules leaves something out, or rhetorically ask "Why should an arrangement of molecules be accompanied by fluid behavior?"
The cynical answer is that the kinetic theory of gas has been "finished', but the "reductive explanation" of consciousness is still in progress.
You asserted that consciousness "resists reductive explanation" -- without assuming that as an axiom, how does one defend that position against progress in research into the brain?
We don't really understand the nature of anything. We accept it, we are raised into it, we make use of how things are, but it doesn't mean we've understood their nature.
Take Quantum Mechanics. None of us... even those of us that have taken the classes and digested the applications and manifestations of it... none of us understand it. We have accepted it. We shrug now, as the familiarity trigger switches in our brain.. "oh, I've heard about this before." We may even take up work or research that deals heavily with the mechanisms of quantum mechanics. We get an intuition for the mechanics of what is. We construct our own emotional bond (and interpretation) of the "what is", each of us individually, and we know it. But this hasn't brought us any closer to understanding the nature of it, we have only been desensitized to how things are.
But my question to dualists is why? Why in Cthulh's name does it matter whether it's physical or not? What is it that's so restricting and containing about physical systems that our minds somehow shouldn't/couldn't be governed by them? This isn't reasonable at all. It's already been demonstrated to us how bizarre and majestic the physical reality is. Realtivity, Qauntum Mechanics... Life itself! So what's the reason to start looking outside of the physical reality when a) we don't even completely understand it b) it's proven to be the only agent of action, change, and existence in the known universe. Occam's razor.
Trial and error.
Take one conscious entity, stop time, copy it. Now you have two entities with identical qualia. Run time - not any more. Their different experiences contribute in different way to their qualia.
I can never know exactly what other people experience when they say "I see red". I assume their experience is very similar to mine because we are built pretty much in the same way. We can reduce this question to the hopeless philosophical muddle of "Do I know anyone else even exists?"
What does a dog experience when it sees a red light? Dogs are color blind, so they won't have the same experience a non-color blind human has. Color blindness can be explained in neurophysiological terms. Where's the dualism? Qualia are personal. We would need to inhabit every sentient creature in the universe to know how the color red is experienced in individuals. So why even talk about "dualism"? It's really a hopeless "polyism".
EDIT: There are ways to evaluate color perceptions in relative terms, such that orange is "closer" to red than blue. However 'red' cannot be described to a person who was born blind. If an alien being sensed a very different part of the electromagnetic spectrum then humans, how could we ever imagine that experience? It's a hopeless question. Why even ask?
So the non-dualist's take is that everything about them is controlled by laws. Two people conversing excitedly about the bizarreness of quantum mechanics or Life are like two systems exchanging files. When a person sees his father hit by a speeding car, the emotion and the sadness he experiences is analogous, if not exactly same as, a pc whining "Battery low!".
Laws can control the sensations i perceive but not my response to them. Everyone could be seeing the same thing, say a truck going down the road. but it is my consciousness, or rather ME, that contemplates and pictures the rolling motion of those wheels as continuous toppling(i did automobile engineering), smile at it for a moment and continue driving the other way.
My senses could give me the sight of mountains and rivers. It is ME, who decides to sit down, take in the moment; experience and cherish it. Of course, there could be opposing signals from the brain-
"ah we have seen these mountains all these years. Step on the gas pedal. speed up dude!" "Wheels, toppling,.. hell! Let's think about the girl we saw yesterday. her curvy hips,pouted lips.. and those beautiful pair of.."
"Shut up-!" that's ME.
The Shut up is not bound by any laws. Its plain ME. Like you don't have any reason for a single atomic particle undergoing radioactive decay, like you can't say through which slit the photon came, here I AM! and my "Shut up!"
Call it dualism or whatever.
On a side note, the girl did indeed have a beautiful pair.. of eyes!
the "ME" you talk about is your mind and your mind is made up of physical matter. your reaction to the truck going down the road, the mountains, and the rivers, are determined by your genetics and your environmental conditioning, and both are controlled by physical laws.
"Die!" said the VIRUS. It was the VIRUS, not its RNA.
The fundamental idea behind what a physical theory is, is nicely explained by Chalmers in my last post. Any such theory regarding the structure and dynamics of physical processes is objectively measurable.
Clearly, phenomenal experience, qualia for example, are not objectively measurable. If anyone disputes this, they have to explain how in principal, one might be able to objectively measure qualia. Note that this is not a description of the "structural dynamics" on which the phenomena supervene, it is a description of the qualia or phenomenal experience. In other words, we need a way to compare one instance of qualia with another such as an ability to compare one person's experience of the color red with another person's experience of it. We need a measure of some sort, but the best we can do is provide a measurement of the structure and dynamics of the objectively measurable physical processes.
If a phenomenon is not objectively measurable, it is not quantifiable. If it is not quantifiable, we can't create a physical theory of it. Note also that physical theories are all describable using mathematics, but without an ability to quantify the phenomenon we can't use mathematics to describe the phenomenon. Without a mathematical description, we have only a qualitative description. If all we have is a qualitative description, and making the assumption of the causal closure of the physical, we don’t even have a way of verifying this qualitative description per the Knowledge paradox.
It would seem that calling phenomenal experience a physical phenomenon is based solely on there being a physical substrate. Even dualism doesn't reject this basic premise. But to catagorize phenomenal experience as a physical phenomenon is to place it in the same category as the kinetic theory of gasses, or to call it a phenomenon analogous to wing flutter. Without a physical theory to quantifiably describe conscious phenomena, calling it physical might be considered a catagorical error, thus dualism.
Pythagorean said:
I think the idea of a zombie is flawed. The closest thing to a zombie is somebody that is dead (they have all the brain matter, but no thought process). But they're still not a zombie, because there's definitely a physical difference (in terms of events and interactions) between a live and dead person.
Why should the concept of a p-zombie be flawed? In my view it is perfectly logical. A zombie is simply the physical process less the phenomenal experience.
Pythagorean said:
If things are measurable in a consistent way, they have a physical basis. If they're not... then we're pretty much screwed on understanding it.
I agree it’s tough to understand how we might incorporate consciousness into a physical description of the world. If mental phenomena have a causal influence over the physical, we might not be screwed but it might be a bit difficult to reconcile.
Fascinating.
How one makes objective measurement? Let's say you have a battery and you want to measure objectively its voltage. You get a multimeter, connect it to the battery and there it is, it shows 1.48V. Then you realize that the multimeter can be malfunctioning, so you decide to repeat your measurement with another multimeter. It shows 1.47V. You decide that you have made objective measurement.
But did you look inside your multimeters? They are quite different. One of them is digital and the other is analog. They have "experienced" the measurement quite differently. Their "qualia" is different. Did you care? No.
Then why try to do that with us? What you care is the objective measurement, which is "red". How the measurement is done is of no consequence to the objectivity of that fact.
Upisoft said:
Fascinating.
I think that's quite in line with what the http://en.wikipedia.org/wiki/Behaviorism" were getting at in their heyday in the 1950s and 1960s. What could be observed and measured was important, but unobservable mental events and respresentations were trivial, and for all scientific purposes, meaningless.
There can be an objective measurement of the properties of red, specifically as a wavelength range of visible light. But the "experience of red" still falls into the subjective.
Math Is Hard said:
I think that's quite in line with what the http://en.wikipedia.org/wiki/Behaviorism" were getting at in their heyday in the 1950s and 1960s. What could be observed and measured was important, but unobservable mental events and respresentations were trivial, and for all scientific purposes, meaningless.There can be an objective measurement of the properties of red, specifically as a wavelength range of visible light. But the "experience of red" still falls into the subjective.
I didn't say there are unobservable mental events. Nor the events in analog and digital multimeters are unobservable. If you want to study and understand the digital multimeter you don't get the Analog Electronics textbook. The same is valid for us. If you want to understand what is going in someone's head you don't compare it with something else. Even if that something else is quite similar. The best you can get is to find the parts that perform similar functions. But still, how they perform these functions could be quite different in the details.
An experiment to determine how well a specific television and RGB combination reproduces a specific color would be to grab 100 people, show them both the original color and the color on the television, and ask them if they are the same.
Voila -- you have an objective measurement that X of your 100 test subjects reported having the same color viewing experience.
This doesn't tell you that they see the same thing you do. A person will learn to associate a sensation caused by light from the lower end of the visible light spectrum with a name and behave in a consistent way regarding that particular sensation. They will stop at red lights and follow the red line marked on floors when asked. That tells us nothing about what they "see". The private sensation they experience cannot be observed by others. They probably do "see" the same thing other humans with normal anatomy and neural function see, but this is an assumption. In any case, IMO such sensations can only be described as the perceived signature of a physical effect.
My point is that dualism vs a monist physicalism is simply a version of the physical/metaphysical issue;questions that can be answered (in principle) and those that cannot be. In my previous post on this thread I asked how we could imagine the sensations of an intelligent alien who was able to sense wave lengths in the radio spectrum. IMO this really isn't about dualism but about observer-observed interaction and whether the observer can make statements about what is inherently unobservable (other observers' qualia).
SW VandeCarr said:
This doesn't tell you that they see the same thing you do. A person will learn to associate a sensation caused by light from the lower end of the visible light spectrum with a name and behave in a consistent way regarding that particular sensation. They will stop at red lights and follow the red line marked marked on floors when asked. That tells us nothing about what they "see". The private sensation they experience cannot be observed by others. They probably do "see" the same thing other humans with normal anatomy and neural function see, but this is an assumption. In any case, IMO such sensations can only be described as the perceived signature of a physical effect.
The question "how do others experience something" is based on an assumption. You assume there is something different than your brain (name it soul) which is experiencing the sensations. You imagine it can somehow enter someones's head replacing their soul with yours, and then asking the question how your soul will experience what they see. So you assume something unknown as true (do we have a soul?) and conclude there are things that cannot be known. Bravo! What did you expect?
I assume no such thing. Where did I say anything about souls? I said that our sensations are the perceived signatures of physical effects. Moreover I believe that there are observable correlates of all aspects of what we call mind. I do believe there are limits to what we can know from observer-observed interactions and that I cannot prove to a metaphysical certainty that the world is not an illusion that exists only in my mind. But then again, what are the metaphysical standards? How do you prove a negative? IMO debating metaphysical questions is usually a waste of time. There are no answers, only opinions and beliefs. Choose what you like.
You made your assumption here. When I say I cannot sing (quite true), I assume there is someone else that can sing. When you assume that private sensations cannot be observed by others (humans), you assume that they can be observed by something else (God?). You cannot have the negative without the positive.
