Is Covariant Derivative Notation Misleading in Vector Calculus?
124 replies · 14K views · last reply
PeterDonis said:
Hm. I think I see what was confusing me. The required commutation property is not that the basis vectors have to commute, but that the covariant derivative has to commute with contraction, since the contraction operation is what "extracting the components of the tensor" involves. AFAIK that commutation property is always true.
I'll elaborate (sorry if this is belaboring the obvious) by restating the original issue: we have a notation ##\nabla_\mu V^\nu## that can have at least two different meanings. Using Wald's abstract index notation, the two meanings are:
(1) ##\left[ \left( e_\mu \right)^a \nabla_a V^b \right]^\nu##, i.e., the ##\nu## component of the vector obtained by taking the directional derivative of the vector ##V## in the direction of the vector ##e_\mu##;
(2) ##\left( \nabla_a V^b \right)_\mu{}^\nu##, i.e., the ##\mu##, ##\nu## component of the (1, 1) tensor obtained by taking the covariant derivative of the vector ##V##.
Writing out the "taking the component" operations explicitly, we have:
(1) ##\left[ \left( e_\mu \right)^a \nabla_a V^b \right] \left[ \left( e^\nu \right)_b \right]##
(2) ##\left( \nabla_a V^b \right) \left[ \left( e_\mu \right)^a \left( e^\nu \right)_b \right]##
As long as the ##\nabla## operator commutes with contraction, these will be equal, since we just have to swap the contraction with ##e_\mu## and the ##\nabla## operation on ##V##.
So they are always equal?
vanhees71 said:
##\nabla V## is a (1,1) tensor and ##\nabla_{\mu} V^{\nu}## are the tensor components. From the context we discuss here it's the components with respect to the holonomous coordinate basis and dual basis, though also some posters seem to also discuss non-holonomic bases
MTW sometimes uses the notation ##\nabla_\hat{\mu}{}^\hat{\nu}## to denote the components with respect to an orthonormal (non-coordinate) basis, to distinguish them from the components ##\nabla_\mu{}^\nu## with respect to a coordinate basis.
cianfa72 said:
In other words in slot notation do we reference first the set of covector slots (instances of ##V^*##) and then the set of vector slots (instances of ##V##) ?
No. The slots can come in any order, and, strictly speaking, the order of the slots is part of the definition of a particular tensor, so, for example, there are really two possible kinds of (1, 1) tensors, a (lower index slot, upper index slot) tensor and an (upper index slot, lower index slot) tensor. In a space with a metric (which is all we ever deal with in GR), you can always raise and lower indexes, so this fine distinction doesn't really matter.
IIRC MTW puts the "covariant derivative" slot first, not last.
PeterDonis said:
In other words, we have ##\left[ T ( \hat{e}_0 ) \right]^\nu \neq T_0{}^\nu##. The extra factor in ##\hat{e}_0## makes the two unequal.
Although, wouldn't ##\left[ T ( \hat{e}_0 ) \right]^\nu = {\hat{T}_{0}}^{\nu}##, where I called ##{\hat{T}_{0}}^{\nu}## the components of ##T## in this non-coordinate basis? In other words I'm not so sure what this example is trying to show, because of course if you insert the ##e_{\mu}## basis vectors you get those 'un-hatted' components and if you insert the ##\hat{e}_{\mu}## you get those 'hatted' components, and we have no reason to believe these are equal anyway!
Some sources put the hat on the tensor, others (such as MTW, as I mentioned before) put the hats on the component indexes, to indicate that the components are being taken with respect to a non-coordinate (usually orthonormal) basis.
Yes, that was part of my original issue: if we interpret "un-hatted" indexes as components with respect to a coordinate basis, then equating ##\nabla_\mu V##, i.e., the ##\mu## component of the covariant derivative of ##V##, with ##\nabla_{e_\mu} V##, i.e., the directional derivative of ##V## in the ##e_\mu## direction, is only valid if ##e_\mu## is a coordinate basis vector, not a non-coordinate basis vector. But forming the directional derivative works fine for a non-coordinate basis vector, and extracting components works fine with respect to a non-coordinate basis (just insert the non-coordinate basis vector in the appropriate slot of the covariant derivative tensor), and if the covariant derivative commutes with contraction those two operations give the same result regardless of whether we are using a coordinate or non-coordinate basis, so the only real issue remaining is whether we should write ##\nabla_\hat{\mu}## (or ##\hat{\nabla}_\mu##) instead of just ##\nabla_\mu## when we are using a non-coordinate (usually orthonormal) basis.
All these different conventions are really a nuissance. The only thing I don't like about MTW is precisely putting indicators on the indices and not on the symbol. For me that's almost confusing, because if ##\mu## and ##\hat{\mu}## run through the values 0...3 (or 1...4 ;-)) ##V^{\mu}## and ##V^{\hat{\mu}}## simply denote the same four numbers ##V^0\ldots V^3##.
One just has to be careful to find out what each author means with his notation not to get confused...
If the covariant derivative commutes with contraction, yes. The discussion in Chapter 3 of Carroll's online lecture notes [1] indicates that this property will always hold for the covariant derivative used in GR, although it strictly speaking does not have to hold for a general covariant derivative (one that only satisfies the linearity and Leibniz rule properties); the primary benefit of requiring the property to be true appears from his discussion to be that it means we can use the same connection coefficients for transforming tensors of any rank.
[1] https://ned.ipac.caltech.edu/level5/March01/Carroll3/Carroll3.html
But the symbol symbolizes the geometric object itself, which is independent of any choice of coordinates; it's the indices that (at least with MTW's convention--Wald's abstract index convention is different) are supposed to convey information about the choice of coordinates. So putting the hats on the indices makes sense given MTW's general approach. Putting the hat on the symbol itself would imply that something about the geometric object changes when you change coordinates.
The components aren't numerically the same, since they are components taken with respect to two different choices of basis. The index numbers are the same, but that's just because we number them by dimensions without taking into account anything about the particular coordinate choice. But if we were to designate indexes by coordinate instead of by index number, we would have, for example, ##V^t##, ##V^r##, ##V^\theta##, and ##V^\phi## for a coordinate basis as compared with ##V^T##, ##V^X##, ##V^Y##, and ##V^Z## for an orthonormal basis.
I cannot believe there are 100 posts here about a simple pure mathematics issue (albeit with application in GR).
##\nabla## is a linear operator called covariant derivative which can be applied to any ##(n,l)## tensor to bring it to an ##(n,l+1)## tensor. It generalizes what in (pseduo-) Riemannian manifolds is called "affine connection".
In mathematics ##\nabla_{\mu}V^{\nu}## is ill defined (and from your long debate, it's certainly controversial in physics (!)). However, in order to connect the mathematical definition of a covariant derivative of a tensor with physics (in the GR tensor approach à la Einstein/Levi-Civita/Hilbert/Weyl, i.e. the old-school GR), we can define this dubious object appearing in physics texts as:
$$\nabla_{\mu}V^{\nu} := \left(\nabla V\right)_{\mu}^{~\nu}, \tag{1} $$
that is, the LHS are the components of the (1,1) tensor ##\nabla V## (with ##V## being a (1,0) tensor a.k.a. vector) in the basis ##dx^{\mu}\otimes \partial_{\nu}## (a coordinate basis in the tangent space of each point of the curved manifold).
So regarding the original "bracketing" issue brought up by @stevendaryl and its ensuing discussion, ##(1)## is the only reasonable definition of that object which appears in the "old-school" GR works. Modern (after 1960) GR uses the so-called "abstract index notation" which is meant to make more sense when analyzed from a pure math perspective. However, when the so-called "abstract tensors" are projected onto bases of directional derivatives and differential one-forms, the dubious objects of the LHS of ##(1)## appear again.
P.S. The directional derivative of a vector ##Y## along a vector ##X## is a vector. In formulas:
$$\nabla_{X} Y =: \nabla_{X^{\mu} \partial_{\mu}} \left(Y^{\nu}\partial_{\nu}\right) = \quad ... \quad =\\
\left[X^{\mu} \left(\partial_{\mu}Y^{\nu} +\Gamma^{\nu}_{~\mu\lambda} Y^{\lambda}\right)\right] \partial_{\nu} \tag{2} $$
In the round brackets of ##(2)## one recognizes the object defined in ##(1)##.
Actually, looking at MTW again, I think their "hat" convention actually has nothing to do with a non-coordinate basis; I think it has to do with components with respect to a local inertial coordinate chart, as opposed to components with respect to a general coordinate chart. As far as I can tell, MTW don't write equations in component form at all unless they are using a coordinate basis.
That again depends on how you define your symbols. For me a tensor (e.g., a vector ##V##) is an invariant object (under transformations under consideration, i.e., rotations in 3D Euclidean vector spaces, Lorentz transformations in 4D Lorentzian vector spaces, general linear transformations for a general vector space, general diffeomorphisms in all kinds of differentiable manifolds,...). Then there are the components wrt. a basis. Then the index notation comes into play, and we write e.g., for a vector (field) on a manifold wrt. the holonous basis of some coordinates, ##V=V^{\mu} \partial_{\mu}##. For me the indices just count from 0 to 3 (in GR), no matter which ornaments I put on them. That's why I have to write the components in another holonomous basis derived from the "new" coordinates ##\bar{x}^{\mu}## as ##\bar{V}^{\mu}##. Then of course you have ##V=V^{\mu} \partial_{\mu}=\bar{V}^{\mu} \bar{\partial}_{\mu}##.
It's of course possible to do it like MTW and put some ornaments on the indices to indicate wrt. which basis vectors you decompose your tensors. It's just a matter to stay consistent, but I think a notation should also be as "error resistant" as possible, and then this notation is in my experience less "save" than the other.
If you really want to be save you also have to obey the horizontal order of indices!
I don't see, what's the advantage to complicate the notation by writing ##{(\nabla V)_{\mu}}^{\nu}## instead of the usual notation ##\nabla_{\mu} V^{\nu}##, which is simply the same thing. Mathematicians are sometimes in a disadvantage if it comes to practical calculations in comparison to physicists who tend to write things in a way that facilitates such calculations. I took a lot of pure-math lectures, and usually when it came to just calculating something my notation was way easier and quicker than the mathematicians'. My disadvantage was that I had to translate my sloppy physicist's notation to the more rigorous but combersome notation of the mathematicians. There's no free lunch! ;-)).
Interesting. I thought it's usually put in the definition of a derivation operation on vector spaces that they should commute with contraction. Otherwise you could have a different connection on the co-vector space than the vector space, but that's a bit confusing then. It's easier to have the commutability between contraction and taking some kind of derivative. Then the definition of a specific kind of covariant derivative on the vector space implies a unique one on the co-vector space and vice versa. If you need different kinds of derivatives you can just introduce them. In GR you have not only the usual covariant derivatives (implying parallel transport) but also, e.g., Lie derivatives (implying Lie transport), etc.
It's amazing which variety is in the definitions of standard mathematical objects in the literature. Fortunately in standard GR everything is pretty unique, i.e., the usual connection is the unique metric-compatible connection in a torsion-free Lorentzian manifold ;-)).
My point is that it is ambiguous: Are you operating on a vector ##V## and then taking component ##\nu## of the result, or are you operating on the component ##V^\nu##?
With my personal convention for such things, ##\nabla_\mu## is just shorthand for the operator ##\nabla_{e_\mu}##. With this convention, plus linearity and the Leibniz rule for derivatives, we can write:
##\nabla_\mu V = \nabla_\mu (V^\sigma e_\sigma) = (\nabla_\mu V^\sigma) e_\sigma + V^\sigma (\nabla_\mu e_\sigma)##
Taking components of both sides (by operating with ##e^\nu##) gives:
##(\nabla_\mu V)^\nu = \nabla_\mu V^\nu + \Gamma^\nu_{\mu \sigma} V^\sigma##
So rather than saying ##(\nabla V)^\nu_\mu = \nabla_\mu V^\nu##, I would say it's equal to ##\nabla_\mu V^\nu + \Gamma^\nu_{\mu \sigma} V^\sigma##
I guess @PeterDonis would say that this ambiguity is resolved by denying that ##\nabla_\mu## is an operator; it only appears in the context of the expression ##\nabla_\mu V^\nu## where the meaning is ##(\nabla V)^\mu_\nu##.
stevendaryl said:
My point is that it is ambiguous: Are you operating on a vector V and then taking component ν of the result, or are you operating on the component Vν?
My interpretation of the notation is that I'm operating on tensor components. In any case what's of utmost importance is to also take care of the horizontal positioning of the indices. I can accept a notation like ##{(\nabla V)_{\mu}}^{\nu}##, though I think it's utmost inconvenient. I don't like books, where they don't care about the horizontal index position. It's already a night mare if it's not obeyed for Lorentz-transformation matrices in SRT!
Of course at the end ##\nabla V## (which is also sloppy notation for ##\nabla \otimes V##!) is always the same tensor, which is independent of the choice of bases and coordinates. In my notation its
$$\nabla V=\mathrm{d} x^{\mu} \nabla_{\mu} V^{\nu} \partial_{\nu}$$
in the usual notation ##\partial_{\mu}## and ##\mathrm{d} x^{\mu}## for the holonomous basis and its dual given some coordinates.
As I said before, I think there's not much to argue about. It's all just convention and one must make sure to understand the notation of each book/paper right.
Not necessarily, no. With your convention, where ##\nabla_\mu## means ##\nabla_{e_\mu}##, the directional derivative operator along ##e_\mu##, it is obviously an operator. With the convention I'm used to, ##\nabla_\mu##, used in isolation, is just a way of referring to the covariant derivative operator ##\nabla## itself--Wald would write it as ##\nabla_a##. But in either case it's an operator. The ambiguity in the convention I'm used to is, as you say, that sometimes (usually in expressions where it's combined with other things), ##\nabla_\mu## can mean the ##\mu## component of some tensor obtained by applying the ##\nabla## operator to something; that is indeed not an operator. (As we have seen, it ends up being the same as the directional derivative in the ##e_\mu## direction of the thing the ##\nabla## is operating on. But that still doesn't resolve all ambiguities; see below.)
The only real way to resolve ambiguity is to, well, resolve ambiguity, by adding more notation until the expression is unambiguous.
For example, in Wald's abstract index notation, the various objects you have given would look like this:
Directional derivative of ##V##:
\nabla_\mu V = \left[ \left( e_\mu \right)^a \nabla_a \right] V^b
(Note the brackets enclosing the contraction that denotes the directional derivative, to make it unambiguous that it denotes a single operator.)
Extracting the ##\nu## component:
\left( \nabla_\mu V \right)^\nu = \left[ \left( e_\mu \right)^a \nabla_a V^b \right] \left( e^\nu \right)_b
(Here I don't have a third bracket type to use, so I'm relying on the first expression above to make it clear what the directional derivative operator is, and using the brackets to make clear that the operator is only operating on ##V##; the operator produces a vector, and we contract that vector with ##e^\nu## to extract the component.)
Directional derivative of the ##\nu## component of ##V##:
\nabla_\mu V^\nu = \left[ \left( e_\mu \right)^a \nabla_a \right] \left[ V^b \left( e^\nu \right)_b \right]
Expanding out the above (since now the directional derivative is operating on both ##V## and ##e_\nu##, as the brackets in the above expression make clear):
\nabla_\mu V^\nu = \left[ \left( e_\mu \right)^a \nabla_a V^b \right] \left( e^\nu \right)_b + V^b \left[ \left( e_\mu \right)^a \nabla_a \left( e^\nu \right)_b \right]
Notice that this does not give the same result as above.
Covariant derivative of ##V##:
\nabla V = \nabla_a V^b
Extracting the ##\mu##, ##\nu## component:
\left( \nabla V \right)_\mu{}^\nu = \left( \nabla_a V^b \right) \left( e_\mu \right)^a \left( e^\nu \right)_b
As we have seen in previous posts, since covariant differentiation commutes with contraction, this is equal to the ##\nu## component of the directional derivative of ##V## in the ##e_\mu## direction, but it is not equal to the directional derivative in the ##\mu## direction of the ##\nu## component of ##V##.
Even in the case when just numbering the indices, this can be addressed by using ##0123## for an unprimed coordinate system and ##0' 1' 2' 3'## for a primed coordinate system.
Sorry to resume this thread. I've a doubt about the notation used by Wald for torsion-free condition of a covariant derivative operator, namely ##\nabla_a \nabla_b f = \nabla_b \nabla_a f## (Wald employes extensively abstract index notation).
It should be actually ##\nabla_a (\nabla_b f) = \nabla_b (\nabla_a f)##, I think: the result of the brackets () is a (0,1) tensor - a covector - and then the second instance of covariant derivative operator acts on it.
Is that correct ? Thanks
dextercioby said:
Yes, this is correct. But that bracketing is considered superfluous, so it's omitted.
ok good. I believe the two sides (LHS and RHS) with named abstract indexes ##a## and ##b## reversed make sense only if we think of (or imagine) each of them acting on (or contracting with) a given 'fixed' (2,0) tensor field (e.g. ##u^av^b##).
Otherwise what sense would it make ? The two sides are actually the same - the same (0,2) tensor object having just the 2 ordered slots with reversed names.
The covariant derivatives applied to a scalar indeed commute. In usual Ricci calculus that's very easy to see
$$\nabla_{\mu} \Phi=\partial_{\mu} \Phi$$
and then
$$\nabla_{\nu} \nabla_{\mu} \Phi = \partial_{\nu} \partial_{\mu} \Phi -{\Gamma^{\rho}}_{\mu \nu} \partial_{\rho} \Phi.$$
Since the partial derivatives commute (under the usual assumptions about the smoothness of ##\Phi##) and the Christoffel symbols are symmetric in a pseudo-Riemann manifold, you indeed have
$$\nabla_{\nu} \nabla_{\mu} \Phi = \nabla_{\mu} \nabla_{\nu} \Phi.$$
vanhees71 said:
$$\nabla_{\nu} \nabla_{\mu} \Phi = \partial_{\nu} \partial_{\mu} \Phi -{\Gamma^{\rho}}_{\mu \nu} \partial_{\rho} \Phi.$$ Since the partial derivatives commute (under the usual assumptions about the smoothness of ##\Phi##) and the Christoffel symbols are symmetric in a pseudo-Riemann manifold, you indeed have
I could be wrong but using Leibniz rule it should be (basically the partial derivatives order in the first term on RHS is reversed) $$\nabla_{\nu} (\nabla_{\mu} \Phi) = \partial_{\mu} \partial_{\nu} \Phi -{\Gamma^{\rho}}_{\mu \nu} \partial_{\rho} \Phi$$
Then, as you pointed out, since Christoffel symbols are symmetric and using partial derivative commutativity we get the result.
Well, yes, my order of the lower Christoffel-symbol indices should be switched in the first expression, but of course they are symmetric, which is why I usually don't care. You are right, in more general cases of spaces with torsion, one has to keep an eye on the order of those indices. I hope, here I get it formally right with the index ordering:
$$\nabla_{\nu} \nabla_{\mu} \phi=\nabla_{\nu} \partial_{\mu} \Phi = \partial_{\nu} \partial_{\mu} \Phi -{\Gamma^{\rho}}_{\nu \mu} \partial_{\rho} \Phi=\partial_{\mu} \partial_{\nu} \Phi -{\Gamma^{\rho}}_{\mu \nu} \partial_{\rho} \Phi=\nabla_{\mu} \partial_{\nu} \Phi=\nabla_{\mu} \nabla_{\nu} \Phi.$$
My point was actually about partial derivatives order in the first term on RHS.
I see, yes, but then we first apply ##\partial_{\mu}## and then ##\partial_{\nu}##, i.e., we have ##\partial_{\nu} \partial_{\mu}## in the first step. At the end it's right anyway, because the operators in question commute ;-)).
Sorry, I believe the sign of Christoffel-symbol should be '+'. Btw I believe we're mixing again the meaning of Greek indices ##\mu## and ##\nu## (tensor component indexes in a basis vs "which vector in the basis"). In a coordinate basis (holonomic) it should be fine, however.
$$\nabla_{\nu} \nabla_{\mu} \phi=\nabla_{\nu} \partial_{\mu} \Phi = \partial_{\mu} \partial_{\nu} \Phi + (\nabla_{\nu} \partial_{\mu}) \Phi = \partial_{\mu} \partial_{\nu} \Phi +{\Gamma^{\rho}}_{\mu \nu} \partial_{\rho} \Phi=\partial_{\nu} \partial_{\mu} \Phi +{\Gamma^{\rho}}_{\nu \mu} \partial_{\rho} \Phi=\nabla_{\mu} \partial_{\nu} \Phi=\nabla_{\mu} \nabla_{\nu} \Phi.$$ Note in fact that ##\nabla_{\nu}\partial_{\mu}## is actually the covariant derivative in the direction ##\nu## (i.e. in the direction ##\partial_{\nu}##) of the vector ##\partial_{\mu}##.
That’s not how covariant differentiation works.
Yes, it was wrong. I tried to do the complete job: the goal is work out the component ##\mu##, ##\nu## of the tensor ##\nabla(\nabla \Phi##) in a coordinate basis.
As tensor ##\nabla \Phi = (\partial_{\alpha} \Phi) dx^{\alpha}## then
$$\nabla (\nabla \Phi)= [\partial_{\beta} \partial_{\alpha} \Phi - \partial_{\rho} \Phi {\Gamma^{\rho}}_{\alpha \beta}] dx^{\alpha} \otimes dx^{\beta}$$ Contract it with ##\partial_{\mu}## and ##\partial_{\nu}## to get the ##\mu##, ##\nu## component:
$$(\nabla (\nabla \Phi))_{\mu \nu}= [\partial_{\beta} \partial_{\alpha} \Phi - \partial_{\rho} \Phi {\Gamma^{\rho}}_{\alpha \beta}] dx^{\alpha}(\partial_{\mu}) dx^{\beta}(\partial_{\nu})$$$$ \nabla_{\mu} \nabla_{\nu} \Phi = (\nabla \nabla \Phi)_{\mu \nu}= [\partial_{\nu} \partial_{\mu} \Phi - \partial_{\rho} \Phi {\Gamma^{\rho}}_{\mu \nu}]$$
Is that correct now ? Thanks
