Is dx Negative in Non-Standard Analysis?
  • Level: High School
  • Thread starter Thread starter etotheipi
    Dx Negative
49 replies · 11K views · last reply
etotheipi
This is more of a "housekeeping" question, though I haven't studied much in the way of infinitesimals so apologies in advance for my lack of rigour!
As far as I'm aware, an infinitesimal can be thought of as a small change in some quantity. Changes can be either positive or negative, so subsequently it also seems reasonable for ##dx## to potentially represent a negative change. Of course, there is no ambiguity since we always consider one infinitesimal in conjunction with another (e.g. ##dy=-3 dx##) so the signs "cancel appropriately".
In thermodynamics, for instance, it's common to use infinitesimals like ##dU## and ##dV## (I'm not going to worry about the problems with đQ/dQ etc, since that's a different story!), and evidently ##dU## and ##dV## can take both positive and negative values.
Thank you.
##dx## can carry a sign, so there is also a ##-dx##. But the term itself is an abbreviation for various things, depending on the context. Your question is a bit as if you had asked whether ##x \longmapsto x^2## can be negative. It allows a sign. If you want to know why and where then we will have to discuss the context.
The context you described is an infinitesimal change, and this allows a sign depending on the orientation of your coordinates. Change itself is something absolute as speed is. Velocity, however, has a direction.
etotheipi said:
This is more of a "housekeeping" question (i.e. it's not particularly interesting), though I haven't studied much in the way of infinitesimals so apologies in advance for my lack of rigour!
Without rigor (i.e. a precise definition of infinitesimal) it's impossible give a mathematical answer to your question. As far as a hazy intuitive notion of a infinitesimal goes, I'd say yes, an infinitesimal can be imagined as a small positive or negative change.
Does an answer to your question have any consequences? What consequence would it have if you always imagined an infinitesimal to be positive?
If I were to completely and utterly abuse convention/mathematical rigour, but just to convey the meaning, when you say for ##dx## we also have a ##-dx## that, to give an example, $$dx = -0.00001 \implies -dx = 0.00001$$
Indeed, it makes no difference. It's just out of interest!
etotheipi said:
If I were to completely and utterly abuse convention, but just to convey the meaning, when you say for ##dx## we also have a ##-dx## that, to give an example, $$dx = -0.00001 \implies -dx = 0.00001$$
You're giving an example where an infinitesimal is a variable representing an ordinary real number. Yes, such variables can represent negative real numbers.
etotheipi said:
... and utterly abuse convention ...
In deed. ##dx## is a linear transformation, so the better wording would be
dx=L_{−0.00001} \Longrightarrow -dx=L_{0.00001}
where ##L_c## denotes the left multiplication by a constant ##c##: ##L_c\, : \,x \longmapsto cx\,.##
  • Love
Non-zero can be positive in some cases and negative in others -- my teacher told me that the infinitesimal was 'treated as' zero.
Awesome, thanks for the speedy replies!
I'm finding it a little tricky to formalise infinitesimals since I'm quite used to thinking of them as normal algebraic quantities (i.e. "multiply by ##dx##", etc.) from the Physics side of things. So I get a little nervy about stuff like this!
I'll try and get hold of a copy of Spivak to iron things out a little.
This is not really a good idea. Strictly speaking it is a differential form, which is a linear transformation. Zero is a differential form but not the other way around. Furthermore considering as zero will lead to an entire zoo of misunderstandings and false conclusions.
Have a look at the 10 point list at the beginning of
https://www.physicsforums.com/insights/journey-manifold-su2mathbbc-part/
and the word slope wasn't even on the list. ##dx## is also used in integrals. If you want to read about the entire jungle, see
https://www.physicsforums.com/insights/the-pantheon-of-derivatives-i/
I like what you said, @fresh_42 -- my teacher, who was teaching single-variable calculus to a bunch of kids, wanted to explain to inquiring minds like mine, what to do about the infinitesimal.
Call me simple-minded but what if your definite integral is taken from 1 to -2 ? Does this not imply a negative increment?
Actually, I've just thought of one example where it might matter, namely integration. In the following, $$\int_{a}^{b} f(x) dx$$ isn't it required that ##dx## be greater than zero? It's like when we set up the Riemann sum as $$\sum_{k=1}^{n} f({x_k}^{*}) \Delta x$$ then ##\Delta x## represents a length.
Edit, or as @hutchphd mentioned, if the limits are reversed ##\Delta x## is indeed now negative!
Yes, it is indeed context sensitive. It certainly makes no sense to talk about differential forms or sections or tangent bundles or or or at school. So "a little change" is often enough to know, but a little change is not necessarily no change. I like the comparison with a car: If you are too fast for a curve, then ##dx## is the direction where you fly to, and it is definitely not zero!
That's the hen and egg question: is it ##d(-x)## or is it ##-dx##?
no calling hutch simple
I think that no-one should be calling you simple-minded -- not even you -- the main thing that I see as simple that I can see about your mind is that you exhibit a simple preference for what you see as the truth.
Yes. It is a positive length in this picture. Or the sum of infinitely many infinitely small positive lengths to be exact. You see, infinite times infinite makes no sense, and here is when the comparison to lengths come to an end. The picture gets wrong and you have to dive into the details. It is only a heuristic possibility to see it as a length. If we resolve the heuristic we will get limits. And if we resolve the limits, we will get differential forms. And so on ...
Well, in apparently rejecting infinite times infinite, you appear to my not-as-good-at-math-as-you person to be rejecting the idea of the cardinality of the power set of the reals being strictly greater than that of the reals, so I think that maybe I'm wrong.
I'm still a little confused about this point. If we let ##a<b##, then for the two formulations $$\int_{a}^{b} f(x) dx$$ and $$\int_{b}^{a} f(x) dx$$##dx>0## in the first example whilst ##dx<0## in the second example. How do we rationalise this? I might be thinking too "naively" but how does the integral "know" whether the limits are in increasing or decreasing order?
In the development of the Riemann interval, for example, ##[a, b]## will be an interval with ##a < b##. Then, by definition:
$$\int_b^a f(x)dx = -\int_a^b f(x) dx$$
The integral knows because lower and upper makes the difference. The underlying sign comes from the orientation of the ##x-##axis. So the coordinate has a direction and the integral respects orientation, or better: differential forms respect orientation. That is why volume ##dx\wedge dy \wedge dz## has an orientation, too.
Okay, I think I have a better understanding. I suppose we could say ##dx## and by extension the differential form ##f(x)dx## is positive/negative depending on the direction of integration, so that the integral respects orientation. I'll need to do a bit more study to get a better hold of this!
Thanks for all your help!
If you want to get from ##x = a## to ##x = b##, with ##a < b##, then the simplest way is to have ##dx## positive. In the finite sum if you had some negative ##\Delta x_n## terms, then these would be canceled out by needing more positive ##\Delta x## terms.
PS I've never taken ##dx## in an integral too literally.
  • Love
If you have a look at the series I quoted above, you will get an impression how complex it gets the more you study it. The infinitesimal lengths is what it all started with when Newton and Leibniz found the concept. But that was 300 years ago and many more have recognized since then how strong the concept is and developed it further in a few directions. Before you get lost, keep in mind: it is always a directional derivative, a tangent.
I often find it interesting to try and look at little things that are often taken for granted, but always end up regretting it because it inevitably gets way too complicated and just becomes a self-esteem killer!
Perhaps in a few years I'll be able to understand a little more. Luckily for now, "small change" seems to do the trick.
Also, on a completely unrelated note, TIL that Newton formulated calculus whilst Cambridge was closed due to the Bubonic plague... so the benchmark for the next few weeks has been set! Anyone up to the challenge?
That's why I like the historic perspective! Mathematicians usually tried to solve a problem, often a physical one, or a class of problems. We tend to forget this view and learn things as they are today, but they usually didn't start that way. There have been major steps: Newton and Leibniz with the infinitesimal quantities, Graßman with the orientation, Riemann with the coordinate free description. And in between, there were a lot of efforts from great mathematicians like Cauchy, Legendre, Lagrange, Bernoulli, Gauß, and many more. It was a long way from that infinitesimals to pullbacks and sections. Dieudonné wrote a great book about the history of mathematical achievements from (roughly) 1700 to 1900. Unfortunately I haven't seen an english translation.
I'm not sure that the dx used in Riemann integration is an infinitesimal number in the literal sense of being an element of a non-standard, uncountable model of the Reals. It is instead, a Real number that goes to zero . If it was an infinitesimal and the function was Real valued, the value of the integral would itself be an infinitesimal and not a Real number. Sorry if you , OP, meant the use of 'Infinitesimal' informally, but you need to ne careful because it also has a precise technical meaning.
Perhaps you didn't phrase this precisely, but a real number is either zero or it's not. It can't "go to zero". In any case, ##dx## in the integral is not a real number.
Edit:Well, not the dx itself but the values dx assumes. Yes, by the Archimedean principle, a Real number cannot be indefinitely small without being 0 but in doing Riemann Integration , AFAIK, we are just requiring that the partition width dx <=||P|| goes to 0 but I don't see how we're requiring that dx be less than _every_(rather than any) Real, forcing the AP to kick in or else allowing dx to take non-standard Real values. If we used non-standard values, I believe by closure properties , the integral itself would be non-standard -valued. I see dx as a function dx:=x_{i+1}-x_i, a difference of Real values, under the so how would it assume anything other than Real values? We don't expect it to be smaller than _every_ Real, but that it be smaller than _any_ given Real, unless I am making some false assumption. If dx does not assume Real values, then what kind of values does it assume? It is a width, so are widths, Physical measurements in general expressed as any thing other than ( standard) Real numbers?
