Is E in a Vacuum Considered Free Space?
  • Thread starter Thread starter robert25pl
    Properties Vacuum
The discussion revolves around the characterization of electric fields (E) in a vacuum versus free space, particularly in the context of electromagnetic theory. Participants are exploring the implications of these definitions while attempting to derive related quantities such as magnetic field (B), charge density (ρ), and current density (J).
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are attempting to clarify the definitions of vacuum and free space, questioning the implications of these terms on the values of charge density and current density. There are discussions on the relevant equations governing electromagnetic fields and their relationships.
The discussion is active, with participants providing insights into the differences between vacuum and free space. Some guidance has been offered regarding the use of specific equations, but there is no consensus on the implications of these definitions for the problem at hand.
Participants are working under the constraints of electromagnetic theory, referencing specific equations related to electric and magnetic fields. There is an emphasis on the definitions of charge density and current density in different contexts.
robert25pl
Given E in a region of space ( [tex]\epsilon_{o} , \mu_{o}[/tex])
I should think of it as a free space or vacuum?
This is vacuum.
I have to find [tex]B[/tex], [tex]\rho[/tex] and [tex]J[/tex]
[tex]\nabla \times \vec E= -\frac{\partial \vec B}{\partial t}[/tex]
[tex]\nabla \cdot D=\rho[/tex]
In free space J = 0 so for J in vacuum I should use
[tex]\nabla \times H =J+ \frac{\partial D}{\partial t}[/tex]
or something else?
or something else?
You probably want to use
[tex]D = \epsilon_{o} E[/tex]
[tex]B = \mu_{o} H,[/tex]
to eliminate D and H. Don't know if you will need it, but you can round out your set of equations with
[tex]\nabla \cdot B=0[/tex]
I think I got B, D, H and [tex]\rho[/tex] and using
I get J
What is the difference between free space (J = 0) and vacuum?
Vacuum means [itex]\mu_{0},\epsilon_{0}[/itex].If you're speaking about "free space",then u should assume no charge density [itex]\rho=0[/itex] and no charge transport [itex]\vec{J}=0[/itex].
So we can have sources in vacuum.But not in free space.
Free space is typically a vacuum in which electromagetic waves (radiation far away from the sources) propagate.
Daniel.
Thanks, So in my problem I will get J not equal 0
Please post the text of your problem in its exact form.
Daniel.
In the region of space [tex]\epsilon_{o} , \mu_{o}[/tex]
[tex]E = (6z\vec{i}+10y\vec{j})cos500t \vec{j}[/tex]
Find [tex]B, \rho, J[/tex]
[tex]\nabla\cdot\vec{E}=\frac{\rho}{\epsilon_{0}}[/tex] (1)
[tex]\nabla\times\vec{E}=-\frac{\partial\vec{B}}{\partial t}[/tex] (2)
[tex]\nabla\times\vec{B}=\mu_{0}\vec{J}+\mu_{0}\epsilon_{0}\frac{\partial\vec{E}}{\partial t}[/tex] (3)
Daniel.
  • · Replies 30 ·
