projjal
- 39
- 2
Is electric potential always continuous in an electrostatic field? I mean, does it suffer from discontinuity at any point?
Electric potential is continuous in an electrostatic field except at points where electric field sources, such as charges, are located. The scalar potential is defined up to an additive constant, allowing for flexibility in its value, which is determined based on the system under study. While the electric field may exhibit discontinuities due to surface charges, the potential itself remains continuous. The relationship between electric potential and electric field is expressed mathematically as v = -∫E dl, emphasizing that potential differences can be calculated even when the electric field is not well-defined at certain points.
PREREQUISITESStudents and professionals in physics, particularly those focusing on electrostatics, electrical engineers, and anyone interested in the mathematical foundations of electric fields and potentials.
The scalar potential is continuous everywhere for physical sources, however its first derivative need not be.Joey21 said:Potentials are defined up to an additive constant. This means that there is a certain freedom in the value it takes. What I believe is done is that this constant is defined depending on the system of study, so that it is continous. The reason why we do this is contained in this post:
https://www.physicsforums.com/showthread.php?t=84646
A clue: What relation is there between the electrostatic potential and field?
projjal said:Is electric potential always continuous in an electrostatic field? I mean, does it suffer from discontinuity at any point?
To make its concept clear, we need to look at the definition of the electric potential.
v = -∫Edl
Obviously, if E vector, the electric field, exists, then we can know the difference of electric potential between the given two points. Next, we let the electric potential at one point be any number we want. So, we get the electric potential at the another one point.
projjal said:What if E vector is discontinuous at one point?
