Is Every Metric Space Regular?
6 replies · 11K views · last reply
Homework Helper
To prove that every metric space is regular. :)
So, a regular space satisfies the T1 and T3-axioms.
For T1: Let a, b be two distinct points of a metric space (X, d). Then d(a, b) > 0, and let r = d(a, b)/2. Then the open ball K(a, r) is a neighborhood of a which doesn't contain b, and K(b, r) is a neighborhood of b which doesn't contain a.
For T3: Let A be a closed subset of X, and let b be in X\A. Since we proved that T1 holds, for every x in A and for b there exists a neighborhood of Ux which doesn't contain b. A is a subset of the union U of these neighborhoods (U is a neighborhood of A). Now, define r = min{d(x, b)/2: x is in A}. Then K(b, r) and U are disjoint.
I hope this works.
You probably should justify why r in your second argument is non-zero.
Also, your U is picked too generally. Knowing that singletons are closed, we could have picked U to be everything except for b, which obviously wouldn't work. You need to pick the balls surrounding the points in A more carefully
OK, here are three other attempts.
i) T3: Let r = d(A, b) = inf{d(a, b) : a is in A}, where b is in X\A. Since A is closed, Cl(A) = A, and d(A, b) = 0 if and only if b is in the closure of A (i.e. in A), which contradicts our assumption, so d(A, b) > 0. Take r = d(A, b)/2, and take the union U of the family of open balls {K(x, r) : x is in A}. Then U and K(b, r) are disjoint.
ii) Since every metric space is Haussdorf (one can easily show this in a similar manner like showing that it is T1), for every x in A, and for b in X\A, we can find disjoint neighborhoods of x and b respectively, Ux and Vx. The intersection of all Vx and the union of all Ux are disjoint neighborhoods of A and b, respectively.
iii) Since every metric space is normal (i.e. it's T1 and T4), it's regular, too (since, for every two disjoint closed sets one can find disjoint neighborhoods of these sets, and a singleton is closed in a metric space). Of course, this proof assumes that normality is proven :)
Your argument (i) suffices, assuming you can take it as known that [tex]d(b, A) = 0[/tex] if and only if [tex]b \in \overline{A}[/tex].
Yes, I went through the proof of that argument, it was part of another assignment. Thanks.
You don't know know that an intersection of open sets is open when there are infinite of them.
Good point, thanks.
