Is Everything in the Expanding Universe Growing Along with It?
  • Context: High School
  • Thread starter Thread starter Gedanken
    Expansion Gravity
The discussion revolves around the concept of whether everything in the expanding universe is also expanding, focusing on the implications of cosmic expansion on various objects and fields. Participants explore theoretical aspects, implications of gravitational binding, and the nature of spacetime in relation to expansion.
  • Some participants propose that while the universe is expanding, the objects within it, such as planets and atoms, do not expand due to the strong forces binding them together.
  • Others argue that the expansion of space occurs primarily at the intergalactic level, with gravitationally bound systems remaining stable against this expansion.
  • A participant questions whether fields, such as the electrical and gravitational fields, expand in the same manner as space, suggesting that this could imply that objects also expand.
  • Another viewpoint suggests that electromagnetic fields inside atoms do not expand, while fields between larger structures, like galaxy clusters, might behave differently.
  • Some participants clarify that the expansion of the universe does not create new space but rather describes the geometry of spacetime, and that the distances between comoving objects increase without affecting the fields in a conventional sense.
  • There is mention of a small effect of dark energy causing a slight expansion of objects, but this effect is considered negligible on small scales.
  • Participants discuss the scale at which expansion becomes measurable, noting that gravitational binding dominates on smaller scales, such as within solar systems, while expansion becomes more significant on larger scales.
Participants express multiple competing views regarding the nature of expansion and its effects on objects and fields. There is no consensus on whether fields expand or how expansion interacts with gravitationally bound systems.
Limitations include the dependence on definitions of expansion and the scale at which it is considered. The discussion does not resolve the complexities of how expansion interacts with different physical systems.
  • #31
PeterDonis said:
Not in a "B" level thread; that's why I pointed out the thread level. If you are genuinely curious about the complexities, please start a separate thread at the "I" or "A" level.
I am fully aware of the physical complexities and advanced features of atoms and the solar system, by the way.
I just challenge that they are relevant here.
Still, I was unaware that the threads have actual levels. My mistake.
My argument ends here and now as I don't do "B" discussions.
Space news on Phys.org
  • #32
my2cts said:
"trying" to expand ? And how would "other factors [] override this"?
Okay, here's a thought. Hydrogen atoms formed when the universe was much smaller than it is now. Let's assume that these atoms expand as the universe does. So, these hydrogen atoms today would be several times larger than they were when they formed. So:
Hypothesis: there are hydrogen atoms of all different sizes, depending on when they formed. Ones that formed in the early universe would be larger than ones that formed more recently - having expanded with time.
Is there any evidence for hydrogen atoms of different sizes? No. The energy levels (which are implied by the "distance" between the electron and the nucleus) are standard.
Theoretically, a hydrogen atom can only exist in certain discrete energy levels. The atom cannot exist in some intermediate state, caused by an expansion. The atom is either in one energy level or the next. It can't slowly expand into a continuous series of intermediate energy levels.
Therefore, the hydrogen atom cannot expand, regardless of what space is "trying" to do to it.
Note that the same would be true of, say, stars themselves. Even if stars "tried" to expand due to spatial expansion, gravity would just immediately pull everything back together again.
It's the same if the Earth "tries" to drift away from the Sun: gravity just won't let it go!
  • #33
I'll give my standard 'rant' on this. Expanding universe just means there is always room for comoving bodies to continue moving away from each other, not that space is pushing them, or that two 'positions' are moving apart (except in particular coordinates). Also, there is no difference in origin between the redshift between two distant comoving bodies versus a similar red shift between two distant arbitrary non-comoving bodies in the same universe. In each case, relative motion in GR is fundamentally ambiguous, but redshift between distant bodies is a function of curvature between them and what their motions are.
An analogy is lines drawn up from the apex of a cone, with the apex down. Consider the vertical time, with circles being slices for each cosmic time. Without doubt, the circles grow with cosmic time. However, angles (motion) between lines originating at the apex (comoving observers) is no different from angles between arbitrary lines on the cone. Further, two lines that start parallel will remain parallel. That successive circles are larger in no way causes lines that start parallel to move apart. This feature corresponds to what has been alluded to that without dark energy, if you had two small bodies far apart in a giant void that happen not to have any red shift between them, then even over cosmic time scales, they will continue to have no redshift, and the radar distance between them will not grow, irrespective of their not being bound.
The case of dark energy can be analogized by assuming the cone flares out from the apex. Then, two lines that start parallel will diverge, due to the hyperbolic geometry. In this geometry, if two lines remain constant distance, at least one must not be a geodesic. In the GR case with dark energy, this means that for two distant small bodies in a giant void to remain constant distance, at least one must be non-inertial. Similarly, there is a tiny affect on gravitationally bound systems.
  • #34
PeterDonis said:
Please give a reference for the experimental results that demonstrate this.
In my knowledge there do not exist any real experiments, in which contraction was directly proven. But contraction has to be assumed in special relativity to avoid conflicts. So it follows indirectly from dilation and the constancy of c. As well the contraction of fields. - One can find this in every textbook about special relativity. My favorite is: A.P French, "Special Relativity".
If space would contract in motion but fields would not follow this, then the principle of relativity should be violated. Because the observer in a moving system would see different conditions than an observer at rest.
  • #35
PeterDonis said:
Same comment here: please give a reference for the specific experimental results that demonstrate this.
The same situation here. Contraction follows indirectly.
Imagine a light clock in a gravitational field. The time indication of such clock has to show the dilation which happens there. This can only work correctly if (1) the speed of light is reduced as given by GRT and (2) the distance of the mirrors is reduced.
Again: any different behaviour would violate the principle of relativity.
  • #36
PeterDonis said:
No, it doesn't. That is pop science, not real science. Real cosmology tells us that comoving objects in our universe are moving apart. That is not the same as "space expands".
Sorry but I have learned that differently. Wrong? In my knowledge Lemaitre has used Einstein's general concept of space to describe the development of the universe. He has related the expansion to space. - Not true? And in the discussions about Dark Energy, the argument (also in univerity discussions) is always that the "extension of space" goes on in an accelerated way. Stars are only measured to proof this.
  • #37
PeterDonis said:
No, it isn't. It has nothing to do with length contraction in SR.
The rest of your post just builds on these misconceptions.
It was my understandig of Einstein that he has developed a generel concept about space. Also in his later papers about, what he called "new ether", he discussed general properties of the space and did not differentiate between the space in SRT, in GRT, or in cosmology.
  • #38
Comoving bodies are moving away from each other but the two ' positions' are not moving apart. Could you explain what you mean by this?
  • #40
PeroK said:
Thanks for the link. If we imagine galaxies plotted on some come cosmic size coordinate system then yes I understand that the galaxies are at rest wrt that coordinate system (comoving galaxies) and the points on the coordinate grid are moving further apart (expansion).
But what I was interested in is what is powering the expansion of the grid? I understood dark energy to be a sort of negative 'pressure' that caused expansion but it seems most tend to model expansion as objects "free falling" like in a gravitational field, just away from each other.
What confused me is that in Leonard Susskind's lectures on cosmology he does describe dark energy as a kind of negative pressure and not as a type of anti-gravity. In fact he describes all bound systems being very slightly and equally effected by expansion in that the the point of equilibrium the systems end up in is very slightly more expanded then it would be without dark energy. (excuse my poor terminology!)
Hence my confusion to this:
as that's exactly how I understood it. That dark energy was applying a negative pressure to matter / energy and causing matter in non bound systems to move apart.
  • #41
Hence my confusion to this: as that's exactly how I understood it. That dark energy was applying a negative pressure to matter / energy and causing matter in non bound systems to move apart.
That would be normal positive pressure. A model where a gas is expanding and pushing things with it. That's not what's happening here.
Negative pressure means that energy is required to expand the vacuum - rather than energy required to compress it.
Note that vacuum energy is positive: if a vacuum expands and its energy density remains constant - as it must, assuming vacuum is vacuum and you can't dilute a vacuum - then that implies more total energy.
The other energies (matter and radiation) have the obvious property that as space expands, their energy densities must decrease. Vacuum energy has what seems the extraordinary property that this does not happen and, as space expands, the total vacuum energy goes up and up.
As I understand it, that is where we reach the mystery of dark energy.
  • #42
Simple. Comoving bodies, by any reasonable definition, are moving away from each. Meanwhile, position has no meaning beyond coordinate choice in relativity. Consider just SR: every distinct frame entails a different definition of what constant position means, and they are all equally valid. Constant position cannot possibly have more meaning in GR than it does in SR. Expansion is the feature of spacetime geometry that makes it possible for comoving bodies to continue moving apart. Using my simple 1x1 analogy, if the universe is cone shaped, you are able to have comoving bodies moving apart forever. A cylinder, or a cone whose sides bent to asymptote a cylinder would not allow this.
Specifically, it is trivial to define constant position such that positions don't move apart. Pick a particular galaxy. Define that world lines that show no redshift as seen by this galaxy are lines of constant position. Just as valid as any other choice. No matter how far away some other comoving galaxy is, if a light source in that galaxy is moving towards us with a speed relative to that galaxy (this relative velocity, being local, is well defined) corresponding to the galactic redshift interpreted as SR Doppler, then light from that source will show no red shift. Define constant position lines by such light sources rather than comoving galaxies. Even with Dark Energy, this is still possible, but such light sources will need to move more and more non-inertially to maintain absence of redshift as observed by us, the more Dark Energy there is. But as long as we can see a comoving object, there is colocated non-superliminal velocity trajectory which would have no redshift as observed by us.
Note, this is also a justification why I consider the phrase "superluminal recession velocities" misleading.
  • #43
Note, I stated the same as Susskind, that with Dark energy there is tiny shift of equilibria even for bound systems. The difference in how we phrase interpretation is a matter of which side of an equation we are focusing on. Assuming you put the cosmological constant on the right hand side of the GR field equation (e.g. to allow the possibility for it to be a dynamical field rather than a constant), then as a field contributing to stress energy it has a natural interpretation as negative pressure. However, possibly paradoxically, the effect of negative pressure on the metric corresponding the Einstein tensor (the left hand side of the equation) is to produce a homogeneous tendency of geodesics to diverge (and positive pressure produces the opposite gravitational effect). To me, this is just as much gravity as the tendency of geodesics in Schwarzschild spacetime to converge in two directions while diverging in the third. Gravity is effect of the metric tensor on inertial stucture. Negative pressure produces a certain form of gravity.
  • #44
"Space" doesn't contract in SR. Objects appear to have shorter lengths to observers moving relative to them.
Once again: I agree that electromagnetism is consistent with SR. That's not the issue. The issue is that you are using the word "contraction" to refer to how electromagnetic fields transform under a Lorentz transformation. That word is not appropriate because fields do not have a "length" or a "size", so they can't contract. So there's no point in you continuing to say that SR has to be valid; nobody is disputing that. You need to show what property of fields can be properly said to be a "length" and to "contract".
You are confused. Spacetime is curved in the presence of gravity. You are trying to use intuitions from SR, that only work in flat spacetime, in the presence of gravity. That doesn't work.
Also, the "speed of light" you refer to is a coordinate speed, not a physical speed. You don't appear to understand the distinction; it's crucial.
From where? Can you give an actual textbook or peer-reviewed paper as a reference?
Where are you getting this understanding from? Again, can you give an actual textbook or peer-reviewed paper as a reference?
Einstein developed GR as a theory of spacetime, not space.
Are these actual peer-reviewed papers, or popular articles? Please give specific references.
  • #45
Fields cannot contract? How can you say this?
Example: There may be a field E of a charge q described by the equation: E = q/r2. Then assume that conditions change so that now there is E = q/(2r). So, if one looks to the spatial distribution of the field, the field (i.e. its shape) is contracted by a factor of 2. What is the problem here?
Historically Oliver Heaviside has in 1888 deduced from the Maxwell equations that an electrical field contracts for a moving charge by the equation E --> E' = E / gamma, where gamma = sqrt(1/(1-v2/c2)). This was a well known result and an important step towards relativity.
This fact of a "contraction of a field" is well known and was never questioned by the physical community to my knowledge.
  • #46
Of course I know the distinction. All this is the view of an observer from outside the field. For the observer in the field there is no difference visible. This is demanded by the principle of relativity.
First about time: There is time dilation in a gravitational field. An observer can put a clock into the field and after a time take it back again. The clock in the field compared to a clock which stayed outside is retarded according to the dilation formula for gravity. And now the case of contraction; here again as said for SRT: the contraction can only be determined indirectly. I have proposed the case of a light clock. This light clock has to represent the dilation in gravity. And this dilation can only be explained if contraction is assumed and a reduction of the speed of light. Where speed of light means of course the coordinate value. And that is appropriate because all this is viewed by an observer outside the field.
You say correctly that space-time is curved. This curvature includes of course the contraction of space in the radial direction for a radial field (like for a star). In case of the light clock the calculation depends on the orientation of the clock.
  • #47
That is in general correct. But as said before: in a radial field or in general in a radial situation curvature means contraction.
And in the case of the expanding universe: this is also a radial situation and so the change of the space means expansion.
  • #48
Einstein died in 1955. So there are no actual papers from him.
In the years 1925 until 1955 he developed his understanding of space which means his understanding of those properties of the space which he called the "new ether". He published a series of papers and also books about this topic. I do not know which of his papers were peer-reviewed. But I know that Einstein did not like this peer-reviewing. Because he said "I am Einstein and any peer-reviewing is inappropriate".
I do not have a list of his papers and books about this topic at hand. But university libraries should have them.
  • #49
Because, as I have said several times and you have apparently not grasped, "fields contract" is not the same as "fields transform according to Lorentz transformations". You keep giving arguments for the latter. Those are not arguments for the former.
Which does not describe "contraction" unless E is a length. Which it isn't. It describes the relativistic transformation of the field strength when you change frames. Field strength is not length.
  • #50
Yes.
No, it's not appropriate because it's just a coordinate effect. No physics can depend on how you choose your coordinates.
No, it doesn't. The coordinate effect you are describing is not "contraction of space". It's just a coordinate effect. No physics can depend on how you choose your coordinates.
If you actually look at the "space" in question, and compare it to a Euclidean space enclosed by a 2-sphere with the same surface area, you will find that it is more appropriate to describe the "space" around a massive body as "expanded" rather than "contracted"; the 3-volume enclosed by a 2-sphere of a given surface area is larger if there is a gravitating mass inside the 2-sphere than if there is only vacuum there.
No, it doesn't. See above.
I'm not sure what you mean by "a radial situation". The universe is homogeneous; spacetime around a gravitating mass is not. They're not the same.
Also, as I have already said, the expansion of the universe is not properly described as a "change of space".
  • #51
Um, you do realize that Einstein published scientific papers for at least 50 years before he died, right? Apparently you do, since you go on to say:
Again, please give specific references.
Please give a reference for where you got this quote from.
Then how can you so confidently assert what Einstein said or didn't say? Either you have references to support your claims, or you don't. Either give specific references or stop making the claims.
  • #53
The thread has run its course and will remain closed.
  • · Replies 76 ·
  • · Replies 20 ·
  • · Replies 19 ·
