Is ##\frac{0}{\infty}## equal to 0 or infinity in mathematics?
  • Context: High School
  • Thread starter Thread starter Rectifier
    Infinity Limits
The discussion revolves around the expression ##\frac{0}{\infty}## and whether it can be considered equal to 0, undefined, or treated in some other way within mathematical contexts. Participants explore the implications of treating infinity as a number and the conditions under which limits involving this expression are evaluated.
  • Some participants argue that ##\frac{0}{\infty}## is equal to 0 in many contexts, particularly in limits.
  • Others contend that ##\frac{0}{\infty}## is undefined because infinity is not a number and should not be treated as such.
  • A few participants suggest that while ##\frac{0}{\infty}## can be interpreted as 0 in limit contexts, it remains undefined in general mathematical operations.
  • One participant notes that as n approaches infinity, the expression 0/n approaches 0, reinforcing the idea that in limits, ##\frac{0}{\infty}## can be treated as 0.
  • There is a discussion about the implications of defining operations like ##0 \cdot \infty## and ##0/\infty##, with some suggesting that defining these could lead to inconsistencies.
  • Participants mention that in measure theory, ##0 \cdot \infty## can be defined as 0, but question why this is not universally accepted in other areas of mathematics.
  • Some participants express confusion about the treatment of infinity in mathematical operations and seek clarification on the rules governing these expressions.
There is no consensus among participants regarding the treatment of ##\frac{0}{\infty}##. Some believe it is equal to 0 in specific contexts, while others maintain that it is undefined. The discussion reflects multiple competing views on the nature of infinity and its role in mathematical expressions.
Participants highlight limitations in defining operations involving infinity, noting that treating infinity as a number can lead to contradictions. The discussion also touches on the specific contexts where limits are applied, which may not generalize to all mathematical situations.
Rectifier
Is ## "\frac{0}{\infty}"=0 ## ?
Mathematics news on Phys.org
No, it is undefined because you are treating infinity as though it was a number. It isn't. You can't, in most circumstances, use infinity in normal math and expect meaningful results.
## \infty ## isn't a number, so you shouldn't be dividing by it.
That said, in most contexts, yes, ## \frac{0}{\infty}=0 ##
No, it's still undefined in most contexts, I think. What IS true is that as n approaches infinity, 0/n approaches 0.
EDIT: I hasten to add, I don't do any math where there IS any meaningful context for 0/infinity, so I could be wrong. What contexts did you have in mind?
OK, in most meaningful contexts.
As a matter of practicality, if someone ended up with infinity in the denominator, they were probably using shorthand in dealing with a limit. The type of nomenclature is commonly used to explain limits - with the caveat that it is not proper general-use nomenclature. Since the OP put the fraction in quotes, I believe the he already knows about this.
The symbol ## \infty ## can be used in other more proper contexts, none of which would allow it to be in a denominator. One is to indicate the result of a limit. Another is to indicate the cardinality of a set, although Aleph is better at that. In cases where the order of Alephs is important, the omega symbol is used. Division can be defined for the omegas, but significant caveats are needed.
I was trying to calculate following limit:
## \lim_{x\rightarrow \infty} \frac{x^4 + x \ln x}{x + \left( \frac{2}{3} \right)^x} = \lim_{x\rightarrow \infty} \frac{x^4 \left( 1 + \frac{\ln x}{x^3}\right) }{ x \left( 1 + \frac{ \left( \frac{2}{3} \right)^x }{x} \right) } = \lim_{x\rightarrow \infty} x^3\frac{1 + \frac{\ln x}{x^3} }{ 1 + \frac{ \left( \frac{2}{3} \right)^x }{x} } ##
## \lim_{x\rightarrow \infty} x^3 = \infty ##
## \lim_{x\rightarrow \infty}\frac{\ln x}{x^3}=0 ##
## \lim_{x\rightarrow \infty} \left( \frac{2}{3} \right)^x = 0 ##
## \lim_{x\rightarrow \infty} \frac{ \left( \frac{2}{3} \right)^x }{x}
= "\frac{0}{\infty}"##
HERE-----------------^
That last limit is 0. Don't write it as ##\frac 0 {\infty}##, either with or without quotes.
BTW, I am moving this thread to the technical math section, as it is more of a conceptual question than an actual homework-type question.
I don't understand why the last limit is 0. :,(
I think I got it.## \lim_{x\rightarrow \infty} \frac{ \left( \frac{2}{3} \right)^x }{x}
= \lim_{x\rightarrow \infty} \frac{ 1 }{x} \left( \frac{2}{3} \right)^x ##
## \lim_{x\rightarrow \infty} \frac{ 1 }{x} = 0 ##
as for me, this notation is completely clear. If we have two functions ##f(x)\to 0## and ##g(x)\to \infty## as ##x\to a## then ##f/g\to 0##
That approach is much better, because 0*0 is defined in the real numbers.
You are wrong. In most contexts where the OP makes sense, it is indeed true that ##0/\infty = 0##.
0*0 is undefined?
micromass said:
0*0 is undefined?
Why do you think so? 0 is a number, and multiplying any number by 0 is 0.
micromass said:
0*0 is undefined?
Huh? I said it is defined.
micromass, than you for that correction, but I wonder if you could expand on it for me a bit? I'm confused as to how it is that "0/infinity = 0" is not treating infinity like a normal number
If you treat infinity like a normal number, you should be allowed to multiply by it, but then you get ##0=0\cdot \infty## which is not well-defined any more.
But that's my point. I've always been told that you CAN'T normally treat infinity like a normal number. Is this wrong?
Correct. You can still perform some limited operations in most contexts, and 0/infinity=0 is one of them (e.g. for limits). That is not treating it as normal number, that is a specific rule for this operation.
OK, thanks.
I'm sorry, I must have misread undefined instead of defined.
Why is it that we don't define operations like 0*infinity and 0/infinity etc.They do occur in maths.Is it because defining these things causes inconsistencies?
Like I said, ##0/\infty## is defined in math to be ##0##. As for ##0\cdot \infty##, how would you define it?
You could define it as 0
Right, and this is done in measure theory, where you rigorously define what an area is. The logic is that a straight line has length ##\infty## and width ##0## and has an area of ##0##. So if you define ##0\cdot \infty = 0## then this is consistent.
But why is this not done in the rest of mathematics. Consider ##f(n) = 1/n## and ##g(n) = n^2##. Then ##f(n)\rightarrow 0## and ##g(n)\rightarrow +\infty##. But ##f(n)g(n)\rightarrow +\infty##. So in this sense at least, ##0\cdot \infty = \infty## also makes sense.
And if ##f(n) = 1/n## and ##g(n) = n##, then ##f(n)g(n)\rightarrow 1##. So ##0\cdot \infty = 1## also makes sense in this sense.
In the first example, the limit is that of a sequence of finite length lines becoming longer without any limit so the result is a limit on 0.n=0 as n becomes infinite. In cases like this you must always consider the underlying sequence that leads to the expression.
  • · Replies 40 ·
11K
  • · Replies 17 ·
  • · Replies 66 ·
  • · Replies 30 ·
