Is free fall really acceleration or standing still?
  • Level: Undergrad
  • Thread starter disregardthat
    Fall Free fall
89 replies · 21K views · last reply
marlon said:
yes but in that case you have a mass distribution that is varyin over a certain distance. The earth, and planets in general do not have this property in classical physics. Treating them as point particle, as proven by Newton (go check this out !) gives an accurate description of what's going on.
Off-topic,
Marlon, you are now speaking outside your area of expertise. Your statement would be correct if the mass distributions of the planets was spherical. However, the Earth, the Moon, and Mars cannot be treated as point masses because their mass distribution is not spherical. One needs to account for the deviations from spherical mass distribution to attain "accurate description of what's going on". We use spherical harmonics to model the static gravitational field of a planet and a rather ad-hoc thingy called the "tidal Love number" to model how the plasticity of a planet effects the gravitational field.
The http://www.csr.utexas.edu/grace/" is an ongoing experiment to develop an accurate model of the Earth's gravitational field.
Back on topic,
Jarle said:
And I have read about the U=-GMm/r in 'hyperphysics', I understand that, at least reasonably. I guess and assume it is correct, and I am not saying I am correct, I am just questioning in because I thought radius would matter in this.
I am assuming you meant the planet's radius when you said "radius". That only comes into play if the mass distribution is not spherical. In Newtonian physics, an object with a spherical mass distribution exerts the exact same gravitational field as does an equally massive point mass.
The Earth does not have a spherical mass distribution. The point mass approximation (for which U=-GMm/r) is correct to "zeroth order".
Jarle said:
What 'propety' don't they have, I didn't excactly get that.
Well, that mass varies locally through a planet's volume. Planets are considered to be point particles in classical physics and that works just fine.
marlon
D H said:
Off-topic,
True, but that does NOT change the fact that planets (like the moon and earth) are considered to be point particles in classical physics. I know this is an approximation but it is an approximation that gives correct results, so no problem. Even F=mg assumes that the Earth is a perfect sphere and all results with this law are correct. So, within our "earthly" observations and their required accuracy this approximation works just fine. That is all i am saying.
marlon
For many purposes it's OK to treat planets as point particles, but for other purposes it would be ludicrously inaccurate. (Try explaining the tides using a point particle model of Earth and moon.) I doubt you mean it this way, but someone can take your words as implying that treating planets as point particles is some fundamental assumption of classical physics, which of course it is not. What you are pointing out is that many of the standard "results" used in elementary physics are based on this practical approximation--which is certainly true.
Well, so basically you mean that a sphere with a radius of x and a mass of y, has the same gravitational effect on objects (treating everythign as point particles) as a sphere of x\1000 with a mass of y? Unless the mass is concentrated enough to create an even horizon.
(This is excactly what i mean, It is the concentration of mass in a little volume that gives the black hole the extreme gravity (at least at small distances from it) so I just can't see why spheres with a lower readius but same amount of mass would not act in the same way)
Agreed
Indeed, but that's why i wrote "approximation" each time i mentioned this.
Exactly.
marlon
In classical mechanics yes, in relativity no.
I will say this again (as other have said). In classical physics, any sphere can be treated as a point mass provided you are outside the sphere, this turns out to be a good approximation for most uses.
Apologies for butting in Marlon et al.
Ok, got it. Essentially you are right : you would evolve to a "black hole type situation" if an object has a lot of mass contained in a smaller volume or if you would take a certain amount of mass but lower the volume in which it is contained. But again, my point is that black holes require a tremendous amount of gravity, and thus a very big collapse of mass. This kind of behaviour is not described by classical physics (ie the formula's we have been discussing). I wanted to point out that there is a distinction to be made here : classical physics versus general relativity. One cannot just take a general relativity phenomenon and expect it to be properly described in terms of classical physics. That's all.
marlon
Indeed, that's what i have been trying to say as well.
Actually, i don't understand why "people" make such a fuss about this. This "system" or approximation makes life a lot easier and gives correct results, so what's the problem ? If it ain't broken, don't fix it :wink:
No problem.
marlon
I see, I see.
As I have understood: We can use the same equation for the force of the Earth's gravitational field, if it is a perfect sphere and the same density all over, and will get the same correct answer undependent on the radius of the object.
It depends on what you mean by "most uses". Orbital mechanics is used primarily to track and predict the location of the objects mankind has placed in orbit around the Earth. Secular effects arise from the Earth's non-spherical mass distribution; in other words, the point mass model is broken. We have worried about these effects since the beginning of the space age.
D H, the point mass is not broken, it just cannot be used on the Earth since it is not a perfect sphere. At least that's what Marlon's saying.
It can be used on earth, depending on the degree of accuracy required. For example, if you wish to calculate the trajectory of a bullet fired from a gun do you think that because we treat the Earth as a point mass and ignore that fact that it is non a uniform sphere will make a significant difference? How about calculating the terminal velocity of a falling object on earth?
There is very little the this universe which is perfectly spherical (or perfect in any geometric sense), all that is important is that the error due to any assumptions is very small in comparison to the required accuracy.
As an aside and further to DH's comment; we don't used classical physics to track orbiting satellites, we must use relativistic physics so we obviously don't treat the Earth as a point mass.
Ah, finally. So what's the realitivistic equation for the force of gravity? It must be something else than F=GMm/r^2
There is not one equation, but ten known as the Einstein field equations. Basically they describe the curvature of space time which results in the observed gravitational force. They can be written down as a single tensor equation. There are a few tutorials available on the Internet, you should search for the "Einstein Field Equations".
We do not use relativistic physics to track orbiting satellites. I ought to know. I have been working with satellites (guidance, navigation, and control) for 26 years. The errors induced by using the Newtonian approximation are tiny, much smaller (for example) than the errors induced by imperfectly modeling exoatmospheric density.
We do need to account for relativity for one thing. The clocks on any satellite run at a slightly faster rate than those on the Earth (38 microseconds per day or about 1 millisecond per month). That effect is negligible on most satellites; a calibrated quartz clock is accurate to a few seconds per month. The GPS satellites, however, need very accurate timing and thus carry atomic clocks. The relativistic effect on those clocks must be taken into account. The state (position and velocity) of a GPS satellite is still propagated using Newtonian mechanics.
My apologies, I did not intend my comment as a personal attack in any way.
D H said:
We do need to account for relativity for one thing. The clocks on any satellite run at a slightly faster rate than those on the Earth (38 microseconds per day or about 1 millisecond per month). That effect is negligible on most satellites; a calibrated quarz clock is accurate to a few seconds per month. The GPS satellites, however, need very accurate timing and thus carry atomic clocks. The relativistic effect on those clocks must be taken into account. The state (position and velocity) of a GPS satellite is still propagated using Newtonian mechanics.
This is what I meant by my comment, I should have been more specific (i.e. specified that relativity is used to correct the clock times); not to model the position of an orbiting satellite.
No, that is NOT what i have been saying. What i said is that the earth, although not being a perfect sphere, is considered to be a point particle (just like any other planet) in classical physics. C'mon, i have been saying this over and over again.
marlon
This is very true yet it does not change the fact that spherical objects (like planets, or at least like the idialization of them) are considered to be point particles in classical physics. Hootenanny already gave some examples, which i am sure, you will not deny. In light of Jarle's original comments on gravity, i wanted to make sure he understood this. That is all.
marlon
I agree. There is no difference between the gravitational potential for a point mass and a spherical mass in classical physics for all points outside of the spherical object.
Well, I agree, the Earth could be looked upon as a point particle. BUT, what I meant that that does not makes the equation 100% correct due to it's non-sphere like form... But it is probably insignificant...
Anyway, I believe that there must be another factor involved here, since a black hole is evidence that the smaller the volume the mass is spreaded on, is making a difference in the gravitational effect. Since the blakc holes density made the gravitational force exceed the speed of light (you know what I mean...) means that the density DOES matter, or what? The factor might be pretty insignificant when comparing planets to stars and such, but in the end, it would really matter. :\
I am not saying it works like this, I am saying that I believe it should work like this, even though it is not taken in consideration in classical physics.
Anyway, I believe that there must be another factor involved here, since a black hole is evidence that the smaller the volume the mass is spreaded on, is making a difference in the gravitational effect. Since the blakc holes density made the gravitational force exceed the speed of light (you know what I mean...) means that the density DOES matter, or what? The factor might be pretty insignificant when comparing planets to stars and such, but in the end, it would really matter:\
I don't quite understand what your point is here. In the fields/applications where the effects of GR / non-uniformity of the Earth is not significant, then why should we over complicate calculations, when the result from a much simpler calculation would be sufficiently accurate? In the fields where such effects are significant, then they will already have been taken into account (Check DH's orbital mechanics). What your saying is in essence correct, '[insert assumption here]' matters in some applications. However, for many 'everyday' applications classical physics and the assumption that [insert assumption here] is more than sufficiently accurate (as is treating the Earth as a uniform sphere and point mass and ignoring GR). The reason we make assumptions is to simplify calculations, without losing any significant degree of accuracy.
Well, that was kind of what i said... That the calculations would indeed be accurate enough, even if we treat the planet as a point particle.
Anyway, it didn't have much to do with my other question.
I meant that if you put 1000 kg of material in 1m^3. This would create LESS gravitational energy for a point outside the sphere than if the volume was 1cm^3. I know it does not work that way in classical physics, but I thought that the black hole would be a good example of gravity working this way. but please, TRY to understand my point instead of just saying it doesn't mean anything if I haven't defined it totally correct.
Yes, what you are saying is in essence correct. I would point out that Gravitational Energy in GR is a bit of a fuzzy subject (as far as I know Marlon feel free to chip in), so it is better to talk in terms of curvature of space-time.
Ah, the acknowledge I was waiting for! puh...
So, you say that this is correct, why did Marlon (as I presume knows a good deal about this) deny it?
Clearly, you are not a good reader. It is not the first time i have been thinking this about you. In post 68 i wrote this as a response to your above question :
"Ok, got it. Essentially you are right : you would evolve to a "black hole type situation" if an object has a lot of mass contained in a smaller volume or if you would take a certain amount of mass but lower the volume in which it is contained. But again, my point is that black holes require a tremendous amount of gravity, and thus a very big collapse of mass. This kind of behaviour is not described by classical physics (ie the formula's we have been discussing). I wanted to point out that there is a distinction to be made here : classical physics versus general relativity. One cannot just take a general relativity phenomenon and expect it to be properly described in terms of classical physics. That's all."
marlon, sighs bigtime...well...whatever...
All right, sorry, I understood now fairly enough after intensive reading. Well, I guess my point is proven then...
And your misconceptions have been replaced by proper physical knowledge :wink:
marlon
Misconceptions and misconseptions...
I was asking why it wasn't like so and so, not saying that it WAS like that. You see the difference?
I can see this thread takes circular path... I don't think we need to be so pedantic about the language, do we chaps?
