Is intrinsic momentum a fundamental property of particles?
  • Context: Graduate
  • Thread starter Thread starter wdlang
    Momentum
The discussion centers around the concept of intrinsic momentum in particles, exploring whether it exists alongside other intrinsic properties like spin and parity. Participants examine the implications of intrinsic momentum in various contexts, including theoretical frameworks and experimental observations.
  • Some participants question whether intrinsic momentum exists, suggesting that if it did, it would be undetectable due to the ability to choose an inertial reference frame where it equals zero.
  • Others propose the idea of "intrinsic lack of momentum" as a counterpoint to intrinsic momentum.
  • A participant mentions the intrinsic momentum of decay products in particle physics, citing a specific example involving a charged pion decay.
  • Concerns are raised about how momentum is measured, with a participant arguing that intrinsic momentum may not be physically meaningful or measurable.
  • There is a discussion about the momentum of photons, with conflicting views on whether it has intrinsic properties independent of the inertial frame.
  • Some participants suggest that intrinsic momentum could be related to mass, proposing that it might help establish relationships among the masses of different particles.
  • Another participant argues that while intrinsic momentum may be frame dependent, invariant mass is frame independent, leading to a discussion about the potential properties of intrinsic momentum.
Participants express multiple competing views on the existence and implications of intrinsic momentum, with no consensus reached on its definition or significance.
Discussions include unresolved questions about the measurability of intrinsic momentum and its relationship to other physical properties, such as mass and momentum in different frames of reference.
wdlang
is there intrinsic momentum for some particle?
there are intrinsic angular momentum (spin) and intrinsic parity, so why not intrinsic momentum?
Even if a particle did have intrinsic momentum, it would be undetectable, since we can always choose an inertial reference frame where this equals zero. Intrinsic angular momentum is detectable since in every inertial frame we agree that the particle possesses angular momentum.
but the particle does not move at all
it is surely a surprise that a static particle has momentum
If you include the "intrinsic" momentum of a decay particle in a two-body decay, then the decay of a charged pion at rest into a muon and a neutrino qualifies. The measured muon "intrinsic" momentum in pion decay is ~29.7877±0.0014 MeV/c. See
http://prd.aps.org/abstract/PRD/v20/i11/p2692_1
Bob S
How do we measure momentum? As far as I know, there is no simple way of measuring momentum by itself; we need to measure the velocity of the particle with respect to a certain frame, and multiply that by m (or by [tex]\gamma m[/tex]). This will give you the total momentum of the particle, not just the intrinsic or extrinsic parts, since we cannot break the 4-velocity into "intrinsic" and "extrinsic" parts. Then, how do we define the intrinsic parts of the momentum?
Another way of looking at it is, the product [tex]\gamma m u[/tex] where u is the 4-velocity cannot just represent the extrinsic momentum. If it does, then, how does the intrinsic momentum manifest itself?
To be sure, an intrinsic momentum could be defined, but it isn't measurable and is not physically meaningful.
As for the cited experiment, I do not believe that the muon was at rest after it was emitted. The "at rest" specifies the pion.
Hope that helps to explain my view,
fscman
Doesn't any photon have an intrinsic linear momentum p=hk ?
No dependency on inertial frame for a photon...
The photon momentum do have a dependency on an inertial frame.
According to relativity, E=pc. We also know that E=hf, so
p=hf/c.
The thing to know is, f is dependent on an inertial frame. In fact, f is the temporal part of a 4-vector with the wave vector k being the spatial parts.
So, the momentum does depend on a inertial frame. The question is, does that count as "intrinsic" momentum?
Ah yes... Doppler.
An idea bursts into my brain. Could intrinsic momentum be the "mass"? You know, they are nearly the same from the view that E square is the sum of m square and p square. Maybe by introducing the intrinsic momentum, we could find some relations among the masses of all particles.
Momentum and intrinsic momentum are frame dependent. Intrinsic (or invariant) mass, given by
(Mc2)2 = [E2 - (pc)2]½, is frame independent.
Bob S
Bob S
As we can change the orientation of an intrinsic spin, but cannot change its magnitude, it is likely that the magnitude of "intrinsic" moemtum is invariant, but its direction could be altered. If "intrinsic" momentum possesses this property, we can extend the perception of mass. A scalar "mass" becomes a vector "intrinsic" mementum. "mass" has directions. But it is just an alternative. It might not be better than the original mass. Anyway, everything needs to be tested in the experiments.
  • · Replies 19 ·
  • · Replies 17 ·
