Is it 2nd order polynomials, or 2nd order quadratics?
  • Context: Undergrad
  • Thread starter Thread starter Mol_Bolom
    2nd order Polynomials
4 replies · 5K views
Mol_Bolom
I thought this was rather odd, and wanted to just show it to see what you all thought of it. Well, also, if anyone knows what I should read to exactly understand what I did.
1: Let's define each answer of a polynomial such as (ax + b)(cx + d) as x1 = (-b/a), x2 = (-d/c).
2: The polynomial written out is qx^2 + rx + s
3: Change the polynomial from qx^2 + rx + s to where x = s, and rewrite the problem as qS^2 + rS = S.
4: Devide S out, which leaves qS + r = 1
5: subtract r, qS + r - r = 1 - r. qS = 1 - r
6: Devide q, qS/q = (1 - r)/q. S = (1-r)/q
7: Now if the equation (q x1 + 1)/q is subtracted from S will solve for x2. Or if x1 is replaced with x2 the equation then solves for x1.
(1-r)/q - (q x1 + 1)/q = x2
(1-r)/q - (q x2 + 1)/q = x1
I did simplify this, but I still think it is rather interesting as to 'how' I did this, rather than the 'simplicity' of it.
(Darn it, I forgot what these kinds of polynomials are called. Is it 2nd order polynomials, or 2nd order quadratics?)
Thanks
Mathematics news on Phys.org
I just ran it through a couple of problems but it seems that in the third order...
qx3 + rx2+sx+t
(ax+b)(cx+d)(ex+f)
x1 = -b/a
x2 = -d/c
x3 = -f/e
(1-r)/q - (q x1 + 1)/q = x2 + x3
(1-r)/q - (q x2 + 1)/q = x1 + x3
(1-r)/q - (q x3 + 1)/q = x1 + x2
The original polynomial is 0 only at its roots. x=s is NOT a root, so your rewrite is wrong. Also you put in a sign change in the S term.
To what?? Isn't that a crucial part of the problem?
Thanks
Yikes...I had thought I did a better job at explaining it, I guess not...Well back to the drawing board...
I just thought it was interesting how I came up with it...
I'll try one more time, though...
qx2 + rx = s, and 'Falsely' implying s as the value of x (Actually, I consider this change as 'False' and call the new variable formed as 'False x', however, I use s instead here)
qx2+rx = s...Making S = x (Yes, I know there is a change in the variable, that is what I find interesting)
qS2+rS = S...Deviding S out then leaves qS + r = 1.
qS = 1 - r, then divide q out.
Thus S is the 'False' x.
(Which is the reason that I started using the capital letter S instead of the lowercase s when I was expressing that in the first post. Perhaps I should have mentioned that...)
Then using the 'False' x in the equation
(FALSE X) - (qx2 + 1)/q = x1
