Is it possible to calculate the magnetic force between magnets?
Calculating the magnetic force between magnets is complex and often requires numerical simulations, as analytical approximations depend on specific setups. The strength of a magnetic field is influenced by factors such as magnet size, distance, and orientation, but velocity does not affect the force unless at relativistic speeds. While some online calculators provide theoretical estimates based on flux density, these often do not align with experimental data, suggesting the need for practical testing. The Lorentz force law applies to moving charges rather than permanent magnets, making it less relevant for direct calculations of magnetic force. Understanding the energy density of the magnetic field can help derive the force when magnets are in close proximity.
mohau tshekoeng
Hello
I am a a grade 11 learner and I am trying by all means to calculate force between magnets.
I know that the strength of a magnetic field is determined by the size of the magnet.
In general this is a very complicated problem and needs numerical simulations. Sometimes it is possible to get good analytic approximations, but it depends on the setup.
Likes mohau tshekoeng
+1
For some situations the equations have been done for you. Example...
https://en.m.wikipedia.org/wiki/Magnet#Force_between_two_bar_magnets
However I remember reading a comment once on a magnet manufacturers web site. Basically it said that their own experiments suggested such equations rarely matched reality very well. They advised that you may need to do your own experiment if the exact force is important.
CWatters said:
+1
Magnet manufacturers??
Well one thing for sure is that force is impacted by size,distance at which magnets are placed from one another and velocity...
If a formula can be constructed by those 3 factors there might be progress
The force does not depend on the velocity, unless we are talking about relativistic speeds.
It does depend on the relative orientation between the magnets, and of course on the magnets itself and their distance.
I was referring to comments like this...
https://www.kjmagnetics.com/calculator.asp
Many online calculators we've seen determine pull force based on a theoretical calculation of the flux density. With a few assumptions, flux density (in Gauss) can be related to the expected pull force. Unfortunately, this simplification often fails to match experimentally measured data.
This page calculates expected pull forces based on extensive product testing.
Does this mean I interpreted Lorenz force law in another way??
<Mod note: deleted email addresses>
The Lorentz force allows to find the force between a magnet and a moving charge. Your magnets are not moving charges. If you have an electromagnet, then in principle you can apply the Lorentz force to the electrons moving in the conductor - but then you need the speed of the electrons in the object, not the speed of the object itself. A permanent magnet does not have moving charges in the classical sense, so even the approach with internal velocities does not work there.
A magnetic field ( between two magnets ) has an energy density,
Edens= ½ * B * H [ J/m3 ].
If the magnets are close to each other, the magnetic field in the airgap will be almost homogenous. So the force on the magnets will be:
F = dE/ds , where s is the width of the airgap, and E = Edens * (volume of airgap).
In the above line 2, remember that H = B/μ0 ( in air ).
