Is L a Self-Adjoint Operator with Non-Negative Eigenvalues?
2 replies · 2K views
brkomir
We have a linear differential operator ##Ly=-y^{''}## working on all ##y## that can be derived at least twice on ##[-\pi ,\pi ]## and also note that ##y(-\pi )=y(\pi )## and ##y^{'}(-\pi )=y^{'}(\pi )##.
a) Is ##0## eigenvalue for ##L##?
b) Is ##L## symmetric? (I think the right English expression would be self-adjoint)
c) Find all positive eigenvalues and corresponding eigenfunctions. What is the dimension of eigenspace?
d) Does ##L## have any negative eigenvalues?
a) No idea how to do this one. Here's my version:
##Ly=-y^{''}=\lambda y## which gives me ##y^{''}+\lambda y=0##. Solution of this differential equation is obviously ##y(x)=Acos(\sqrt{\lambda }x)+Bsin(\sqrt{\lambda }x)##
Using this we find out that the boundary conditions for ##A\neq 0 ## and ##B\neq 0## are fulfilled only when ##\lambda =0##. Therefore the answer to question a) is YES.
b)
##L## is symmetric if ##[PW(y,x)]\mid _a^b =0##. Note that originally the DE is ##P(z)y^{''}+Q(z)y^{'}+R(z)y=0## and where ##W## is Wronskian determinant.
Obviously ##P=-1##.
##[PW(y,x)]\mid _a^b =[-\begin{vmatrix}
y & z\\
y^{'} & z^{'}
\end{vmatrix}]\mid _a^b##
After short calculus and knowing that ##a=-\pi ## and ##b=\pi ## we find out that the equation above is equal to ##0## and therefore the linear operator ##L## is symmetric.
c)
##Ly=-y^{''}=\lambda^2 y## where I used notation ##\lambda ^2## for eigenvalue instead of ##\lambda ## just because I don't want to write square roots every time.
Anyhow, solution to this DE is ##y(x)=Acos(\lambda x)+Bsin(\lambda x)## using boundary conditions:
##y(\pi )-y(-\pi )=2Bsin(\lambda \pi )=0## and of course for non trivial solutions ##B\neq 0## than:
##\lambda =n## for ##n\in \mathbb{Z}^{+}## where i suspect these are all the positive eigenvalues.
And accordingly, I assume that ##y(x)=Acos(\lambda x)+Bsin(\lambda x)## are eigenfunctions where for each ##\lambda ## the dimension of the eigenspace increases by ##1##, therefore the dimension of eigenspace is ##n##.
(or do I have to consider ##\lambda =0## here too?)
d) Hmmm, if ##\lambda <0 ## than the differential equation ##y^{''}+\lambda y=0## changes to ##y^{''}-\lambda y=0##.
Now ##y## that solves the equation above is ##y(x)=Ae^{\sqrt{\lambda }x}+Be^{-\sqrt{\lambda }x}##.
Again, taking in mind that ##y(-\pi )=y(\pi )## leaves me with
##(B-A)(e^{-\sqrt{\lambda }x\pi }-e^{\sqrt{\lambda }x\pi })=0## which is only true if ##(B-A)=0##.
Therefore the answer is NO, ##L## does not have negative eigenvalues.
The correct observation is that setting [itex]\lambda = 0[/itex] gives you [itex]y(x) = A \cos 0 + B \sin 0 = A[/itex]. But why not just solve [tex] Ly = -y'' = 0[/tex] directly to get [itex]y(x) = Cx + D[/itex], where [itex]y(-\pi) = y(\pi)[/itex] requires [itex]C = 0[/itex] but [itex]D[/itex] can be anything?
b)
Obviously ##P=-1##.
y & z\\
y^{'} & z^{'}
[itex]L[/itex] is self-adjoint with respect to an inner product, presumably [itex]\langle f,g \rangle = \int_{-\pi}^{\pi} f(x)g(x)\,dx[/itex] if we're dealing only with real-valued twice-differentiable functions, if and only if [tex] \langle Lf, g \rangle = \langle f, Lg \rangle[/tex] for all relevant [itex]f[/itex] and [itex]g[/itex]. So you need to show that for all twice-differentiable [itex]f[/itex] and [itex]g[/itex] which satisfy the boundary conditions, you have [tex] \int_{-\pi}^{\pi} -f''(x) g(x) \,dx = \int_{-\pi}^{\pi} -f(x) g''(x) \,dx.[/tex]
c)
Best then to set [itex]\lambda = k^2[/itex] for [itex]k > 0[/itex].
The eigenvalue is now [itex]\lambda^2[/itex] rather than [itex]\lambda[/itex], so the eigenvalues are [itex]\lambda_n^2 = n^2 > 0[/itex] for [itex]n \in \mathbb{Z}^{+}[/itex].
Each eigenspace is two-dimensional: the linearly independent eigenfunctions corresponding to the eigenvalue [itex]n^2[/itex] are [itex]\cos nx[/itex] and [itex]\sin nx[/itex].
If you want to do that, then you need to write [itex]y'' + \lambda y = y'' - |\lambda|y = 0[/itex]. It would be easier to define [itex]\lambda = -k^2[/itex] for [itex]k > 0[/itex].
So far you've only shown that you must have [itex]B = A[/itex]; you have yet to show that [itex]B = A = 0[/itex].
That is a lot easier, I agree. So the conclusion is that if ##\lambda =0## we can find a function that satisfies boundary conditions. In this case ##y=D## is a constant function, therefore ##\lambda ## can also be ##0##.
b) Is ##L## self-adjoint?
##<f,g>=\int _{-\pi }^{\pi }f(x)g(x)dx## for real functions.
##<Lf,g>=<f,Lg>##
##\int _{-\pi }^{\pi }-f^{''}gdx=\int _{-\pi }^{\pi }-fg^{''}dx##
##\int _{-\pi }^{\pi }(fg^{''}-f^{''}g)dx=0## That here is still a question. We are trying to prove that the LHS of the equation is 0.
##\int _{-\pi }^{\pi }(fg^{''}-f^{''}g)dx=\int _{-\pi }^{\pi }[(g^{'}f)^{'}-f^{'}g^{'}-(f^{'}g)^{'}+f^{'}g^{'}]dx=[g^{'}f-f^{'}g]\mid _{-\pi }^{\pi }##
##[g^{'}f-f^{'}g]\mid _{-\pi }^{\pi }=0## for given boundary conditions. Nice, so yes, ##L## is self-adjoint.
c)
Ok, I will do that.
So for ##n## eigenfunctions the eigenspace is ##2n## dimensional? I assume that is because ##sin## and ##cos## are already linearly independent, therefore for each ##\lambda \neq 0## I get two additional linearly independent functions.
But, is it really ##\lambda _n^2=n^2## ?? Because, if I am not mistaken for [itex]\lambda = k^2[/itex] for [itex]k > 0[/itex] I get
##2Bsin(k\pi )=0## therefore ##k=n## and if anything, than ##\lambda _n=k^2=n^2##. Or not?d)
The second part of course comes from second condition, which gives me ##(A+B)(e^{\sqrt{\lambda }\pi }-e^{-\sqrt{\lambda }\pi })=0##
Now we have both conditions saying that ##A=B## and ##A=-B## which is only possible if ##A=B=0##
