Is M(x,y)dx + M(y,x)dy Always Exact?
  • Thread starter Thread starter Saladsamurai
The discussion revolves around the exactness of differential forms, specifically examining the expression M(x,y)dx + M(y,x)dy. The original poster presents a specific case and then queries whether this form is always exact in general.
  • Exploratory, Assumption checking
  • The original poster attempts to understand the conditions under which the given differential form is exact, questioning the implications of the structure of M.
  • Some participants suggest exploring the concept of exactness through derivatives and provide examples to clarify the relationship between M and N.
  • Others propose developing M into a Taylor series to gain insight into the problem.
  • There is a repeated inquiry about whether the question posed in part (b) is a typographical error, indicating uncertainty in the interpretation of the problem.
The discussion is ongoing, with participants exploring various interpretations and approaches to the problem. Some guidance has been offered regarding the testing for exactness, but no consensus has been reached on the generality of the statement regarding M(x,y)dx + M(y,x)dy.
Participants are considering the implications of the definitions of M and N and how they relate to the concept of exactness. There is an emphasis on finding counterexamples to test the hypothesis presented in part (b).
Saladsamurai
I thought that this was an interesting question.
(a) Show that (x^3 + y)dx + (y^3 +x)dy = 0\qquad(1) is exact.
(b)More generally, is M(x,y)dx + M(y,x)dy\qquad(2) exact? Explain.
Test for exactness: \left(\frac{\partial{M}}{\partial{y}}\right)_x=\left(\frac{\partial{N}}{\partial{x}}\right)_y[/itex]<h2>The Attempt at a Solution</h2><br /> (a) Applying the test is simple enough. 1 = 1. Exact.<br /> <br /> (b) Now this is how I am thinking about (b). Please correct me if I am wrong. M is simply a rule. It is in the form M(x<sub>1</sub>,x<sub>2</sub>). It tells us how to operate on whatever is in the x<sub>1</sub> and x<sub>2</sub> spot. In equation (2), in the first term, x<sub>1</sub> = x and x<sub>2</sub> = y , and in the second term x<sub>1</sub> = y and x<sub>2</sub> = x. Wouldn&#039;t this imply that the equation will always be exact? Is there a way to show that it is or isn&#039;t?<br /> <br /> Any thoughts?
Suppose there is a function z=f(x,y). Your M and N are partial derivatives of z w.r.t x and y
M = \left(\frac{\partial{z}}{\partial{x}}\right), N = \left(\frac{\partial{z}}{\partial{y}}\right)
By taking a derivative of M with respect to y, and taking derivative of N with respect to x, you are essentially testing for exactness. It is an exact differential equation if and only if:
\left(\frac{\partial{}}{\partial{y}}\right) \left(\frac{\partial{z}}{\partial{x}}\right) = \left(\frac{\partial{}}{\partial{x}}\right) \left(\frac{\partial{z}}{\partial{y}}\right)
Your objective is to find z.
I think to make it clear you need an example:
Suppose there are 2 functions, z1= 2*x^2 + y^2, z2 = x^2 + 2*y^2
M(z1) = 4x, N(z1) =2y M(z2) = 2x, N(z2) = 4y
My = 0, Nx = 0 My(z2) = 0, Nx(z2) = 0
So if I give you (4x)dx + (2y)dy = 0, your solution will be integral(M(z1))dx + integral(N(z1))dy =2x^2 + y^2 , and
if I give you (2x)dx + (4y)dy = 0, your solution will be integral(M(z2))dx + integral(N(z2))dy = x^2 + 2y^2.
This was only possible because both M and N were describing the same function z
Hi cronxeh :smile: I understand the test for exactness and how to find F(x,y) if it is exact. The question in part (b), is if equations of the form (2) are always exact. I am not sure how to apply what you have posted to part (b).
So wait you saying part b is not a typo? You actually want to find whether M(x,y)dx + M(y,x)dy = c is always exact?
You can try to see what happens by developing M(x,y) into Taylor series around (0,0) and try on M(x,y)=x^my^n. Once you are done, use (x_0,y_0) instead of (0,0). This may give you some insight and intuition to start with.
Indeed it is not a typo.
Notice that when you write
\frac{\partial M(x,y)}{\partial x} it can be written as well as
\left(\frac{\partial M(s,t)}{\partial s}\right)_{s=x,t=y}
or
\left(\frac{\partial M(t,s)}{\partial t}\right)_{t=x,s=y}
It's all the same. Now, you can do it.
Hint (Big hint): Find a counterexample. It's not hard.
